#3809 |
Drives: 2015 Scion FR-S
Thanks for the information. I'm doing this more to learn right now than compete.
Sent from my XT1254 using Tapatalk
FRed-S
#3810 | |
Drives: 2014 BRZ
Thanks for the suggestion. We usually get five runs but club does allow about twenty double entries if you get there early enough. So more run time would definitely help determine best psi after learning course. A couple of guys running the re71-r's on other cars did suggest lowering the pressures but I didnt have time before making my last run. I usually try to avoid too much rollover to reduce wear on the shoulders but i may be giving up some traction. I was definitely impressed with the tires tho, grip was great. Reminded me of the 'r' compound tires I have run on other cars in the past. |
#3811 |
Custom User Title
Tell them STX. Your tune likely makes a world of difference over a C-Street car because of that mid-range torque.
LOCUST 2015 FR-S (STX) and 2012 Evo X MR Instagram: LocustAutoX Sponsors:DSGPerformance Drift Office Evil Apex Racing |
| The Following User Says Thank You to Locust For This Useful Post: | FRed-S (10-19-2015) |
#3812 |
Drives: 2014 FR-S
Email the organizers, and tell them what you have done to the car. Run the class they tell you. SCCA classing really isn't a haggling/bargaining thing. If you want it to be, NASA does it on modification points.
-Mike
#24 CS/CSR |
#3813 |
Drives: Scion, Honda
Has anyone else run against some ND Miatas yet (not counting the one in Lincoln)?
I think we have a tough match-up on many smaller, local courses. They seem to have a bit more torque in all the right places. It was too cold to get a real comparison, but they're definitely on par with us and the RX-8s. I'm not writing a letter (yet), but I'm a little worried about them. |
| The Following User Says Thank You to Biggins For This Useful Post: | Bimble Bamble (10-23-2015) |
#3814 | |
Drives: 2022 Toyota GR86
one will be Nationally competitive. until then they will help keep the class counts up. ymmv.
Eric
2022 Toyota GR86 Steel |
#3815 | |
The Stig's German cousin
Hell, with the right driver and course, bone stock + good tires is enough to turn it into a serious threat. Saturday in fun runs the local ND beat my competition time by 3 tenths after some coaching from me. It has Bridgestones and a disconnected rear sway. |
#3816 | ||
Drives: '14 FRS TT5
Part 1: http://www.conecoach.com/2015/03/11/...he-sweet-spot/ Part 2: http://www.conecoach.com/2015/03/24/...ire-pressures/ For me, I use the chalk method and get the "hot" pressures to allow the tires to roll right to the top of the triangle. Then I tune the car balance with the Koni's, and my driving. In cooler temps, I've learned dropping 1-2 psi all around can make a huge difference. I don't mind sharing my pressures/setup: -225/45-17 RE-71R's, 33 front (hot), 30 rear (cold). Sometimes 34/31 on warmer days. -TRD sways, springs -OTS Koni's, half turn from full stiff front, half turn from full soft rear. Sometimes full soft in the rear if it's cooler or I'm trying to calm down the rear end or if I'm still getting a lot of oversteer on corner exit. -this is on asphalt, but I used the same settings down at Lincoln. -FWIW, I usually win my class locally and am better than top 20 overall out of ~140. Not to brag, but I got my first top 10 finish locally at the last event Can't wait for next season!
Follow my NASA TT5 build here: JHill Motorsports
| The Following 2 Users Say Thank You to TMF For This Useful Post: | jdp530 (10-19-2015), strat61caster (10-19-2015) |
#3817 | |
#3818 | |
Custom User Title
One thing that those links don't mention that I've found is really helpful is tracking your tire pressure/temperature increase per wheel each run and then modifying your pressure to get the ideal contact patch at the point in the course where you most need it. If I'm on a course where the last two critical turns are hard rights then I'll drop my pressure lower on the front left tire before the run so that I'm closer to ideal pressure when I reach that point of the course. I've actually never used chalk. Next year I may give it a try but the triangles have been sufficient enough and with the Bridgestones it's been fairly easy to tell where the new tire wear is vs. the old. I do track my temps with a pyrometer on outside, center, and inside tread though.
| The Following 3 Users Say Thank You to Locust For This Useful Post: |
#3819 |
Looks like there will be a 235/40/17 RE71R available next year.
#3820 |
Drives: '14 FRS TT5
Thanks for the info. At first I thought, darn, I just bought another set of 225's, should have gotten these!
However, I think these may be a too short...they are quite a bit smaller than the 225's, and the 225's are already geared fairly short. For reference:
| The Following User Says Thank You to TMF For This Useful Post: | racinric95 (10-31-2015) |
#3821 |
C-Street AutoX
Dave proved at nationals you can up shift 3-4 times on course and still be fastest. I'll be trying the 235/40''s most likely.
-2013 Scion FR-S C-Street
Gearhead Homes - Homes geared towards car enthusiasts: https://www.facebook.com/GearheadHomes.RealEstate |
#3822 |
Seems like it would only make a difference on courses where you're right on the edge of 3rd gear (which is probably the majority of locals), slower ones and ones where you're gonna hit 3rd regardless it could prove to be an option worth considering. I'm making the jump to STX next year anyway, so 245's for me. Anyone want a set of 30 run 225s?
| Cinco De Mayo SCCA SOLO | Ryeong86 | NY / NJ / CT / PA | 0 | 04-23-2013 06:22 PM |
| Koni Sports in SCCA SOLO | Ryeong86 | Tracking / Autocross / HPDE / Drifting | 4 | 04-22-2013 01:58 PM |
| 2013 Preliminary SCCA SOLO and PRO SOLO National Schedule | Scooby South | Tracking / Autocross / HPDE / Drifting | 13 | 12-05-2012 09:08 AM |
| Houston SCCA Solo #9 - 5 FRS, 1 BRZ | hankster | Tracking / Autocross / HPDE / Drifting | 0 | 10-09-2012 02:35 PM |
| SCCA Solo Car Class for the FR-S/BRZ? | MrVito | Scion FR-S / Toyota 86 GT86 General Forum | 31 | 06-15-2012 11:03 AM |
