#3753 |
Drives: 2015 CWP BRZ
Never mind. I didn't realize that the Rival S and HoosierStone were not available in that size.
#3754 |
Drives: 2013 Subaru BRZ
Not sure if anyone is still interested, but I've been on the Dunlop Direzza ZII Star Specs all season and LOVE them. My 13 BRZ was able to touch 1.2 Gs during a combination of braking and cornering forces.
This was in C Street. The only other mod was a Whiteline rear bar.
#3755 |
I love my Star Specs as well. According to Harry's Lap Timer I did 1.1g's at MSR 1.7CCW. That's in my CS BRZ with just a front Perrin 19mm bar on soft.
They still don't have the ultimate grip that the HoosierStones have. I drove my friend's BRZ with just 225/45 RE71's and could tell the laters grip was definitely higher. |
#3756 |
Drives: Scion, Honda
The Star Specs are a good tire, but we've established all year that they're just not as fast as the Bridgestone, BFG, and Kumhos. I don't run real "data," but when I tested them at the beginning of the season, they were only on-par with my year-old Yokohamas and almost a full second slower than the new Bridgestones on a 60 second course.
I think my Bridgestones will last into the first few local events for next year, but I want to play around with sizing a bit. I ran 235/45 last year with the Hankooks which worked well on National style courses, but they were not ideal for many locals. I was on 245/40 BFGs at Nats and adjusted okay, but I'd need more seat time to fully adjust my driving style to them. Was anyone running 245/40 Bridgestones this year with good results? |
#3757 |
My local club has an ace C Street driver who went 20mm wider than factor this year without wider wheels (totally legal).
He says that the difference was absolutely incredible and the tiny amount of extra width provided much more grip. He doesn't use data so there aren't any hard numbers, but he's won his class at almost every event this year. It sounds crazy that 20mm could make such a radical difference. But you can't argue with results and I'm going to try the same thing in 2016.
#3758 |
Drives: Series 10 FRS
So what was the tire solution at Nationals? Was Dave on the 245/40 or 225/45 (or 235/45 on back for gearing)? Does the 245/40 turn in slower and require higher psi? I am setting up my FRS for CS and been running 28/28 on 225/45-17 RE71Rs with good grip and turn in but this is my first venture back into RWD in several years. Was going to order a set of new tires this month for next year as rains till my worn tires are gone. Any input (especially from you fast CS drivers) is greatly appreciated, and i look forward to running with you guys next year!
Car seems perfectly balanced with Konis at 1/4 from stiff front and 1/3 from soft rear and Cusco front bar/stock rear bar. TRD springs and 1/16 toe out front/ 1/16 toe in rear with appx -2 deg front camber (with home camber gauge and toe bar gauge)... Would larger rear TRD bar with larger front bar be any help? Car seems super flat... |
#3759 |
Drives: 2013 Scion FRS
Hi everyone! I am new to the FRS. I just purchased a 2013. I am prepping it for C-Street. I am not new to autocross but I am very new to this car and class. I just ordered some wheels and looking st tire options. I have always been in the theory wider is better which I know may not be the car but was wondering if anyone has tries the RE71 245/40/17? Reading this looks like some have just making sure that they fit. I am looking at the clearance and with the factory offset wheel a wider tire would be getting very close to the shock. Right now my car has all stock suspension but I will be putting OFS Koni's and and the TRD stuff on the car. Thanks for the advice and I look forward meeting some of you all in the future.
Thanks, Mark McCrary |
#3760 | |
Drives: frs
#3761 | |
Was good to see you and Robert driving at Nats in the well set up Carpenter/Eley 99 Miata Sport. Hope to see you at the SE events. Our region is in the process of getting a National Tour next year at Hoover Met in Birmingham. We will have a couple more events this year if you get a chance to attend. www.alscca.net Clay |
#3762 | |
I should be involved with our last 2 events and will be glad to help with any questions or just ride along (driver or passenger). Next event in a couple of events. Please try to come or you can always PM for any questions. Ran #2/100 PAX right behind Nat Champ Chitt in the STF Mini at last event (shouldn't have let him use my last run to try my car out!) ![]() Our events at other site are shorter due to lot. New lot will allow 60 sec Nationals type and speed courses https://www.google.com/maps/place/Ho...!6m1!1e1?hl=en |
#3763 |
I've driven on all the relevant 17" sizes. I ran on 245/40 BFGs on codriver's car at Nats this year, 235/45 Hankooks and 225/45 Yokohamas in 2014, but I run 225/45 RE71Rs on my car right now. I ran 215/45 in 2012-13. I honestly can't tell what is best, but I think they will all work depending on your driving style and how you set up your car... oh, and how high the speeds are at your venue. I think I'd want 235/45s if every course were higher speeds like the Nats east course the past two years.
I'm planning to do some more tire testing at the beginning of next year, but it will be tough to decide between BFG and Bridgestone, having driven both now. I'm curious to see if any other brands/compounds come to market next year. I think I'll start with 245/40 next year though. |
#3764 | |
Drives: 2013 Asphalt Scion FR-S
The car is pretty flat without the TRD rear, but you will still want it. It is a step up and then you can play around with the front bar to get the balance how you want it. |
#3765 | |
Drives: 2014 FR-S
-Mike
#24 CS/CSR |
#3766 |
Drives: frs
has anyone seen the kumho v720 run firsthand yet?
| Cinco De Mayo SCCA SOLO | Ryeong86 | NY / NJ / CT / PA | 0 | 04-23-2013 06:22 PM |
| Koni Sports in SCCA SOLO | Ryeong86 | Tracking / Autocross / HPDE / Drifting | 4 | 04-22-2013 01:58 PM |
| 2013 Preliminary SCCA SOLO and PRO SOLO National Schedule | Scooby South | Tracking / Autocross / HPDE / Drifting | 13 | 12-05-2012 09:08 AM |
| Houston SCCA Solo #9 - 5 FRS, 1 BRZ | hankster | Tracking / Autocross / HPDE / Drifting | 0 | 10-09-2012 02:35 PM |
| SCCA Solo Car Class for the FR-S/BRZ? | MrVito | Scion FR-S / Toyota 86 GT86 General Forum | 31 | 06-15-2012 11:03 AM |
