Sam Strano
Old 05-22-2015, 11:14 PM   #3081
ksconekiller
Drives: Subaru BRZ
Originally Posted by SeanRTR View Post
http://sololive.scca.com/timeslip/73CS.html
Fenter and Harvey lead the Lincoln Pro solo right now, and Harvey especially is killing all the twins in '60 fit times.
Ogburn III is in third, and Manfred in 4th.
Manfred is the only twin driver remotely close to the NC Miata on 60' times. What is your launching RPM and strategy, and what do you think of the Rival-S tires? Which size did you go with? Good luck this weekend guys.
Looks like most of the BFG drivers went with 245/40, and the Bridgestones seem to be split pretty evenly between 225/45 and 245/40. Most Scions are on the TRD springs and bars.
ksconekiller is offline   Reply With Quote
Old 05-22-2015, 11:23 PM   #3082
Laloosh
Laloosh's Avatar
Drives: 2014 BRZ
It's obvious, it took me all of 5 seconds to ask an owner how he got so much camber up front. I would never protest it but just a heads up as people will. So if you are doing it and running towards the front...be careful.
2014 BRZ C-Street #11 245/40/17 RE71R's, Camber Bolts, Koni Shocks, Perrin 19m Bar, 5mm Spacer/Longer Studs, Berk Track Pipe, KNN Drop In, Fancy alignment
Laloosh is offline   Reply With Quote
Old 05-23-2015, 12:54 AM   #3083
Cueman
Cueman's Avatar
Drives: In Perfect Control At All Times
Originally Posted by Laloosh View Post
I loosened everything and jacked the hub up before torquing everything down. Nowhere near 2 degrees.
The TRD springs help. I went from 1.4 to 1.9 up front.
Cueman is offline   Reply With Quote
Old 05-23-2015, 04:17 AM   #3084
mpicher
Autocross Nut
mpicher's Avatar
Drives: Argento 2013 Scion FR-S - MT
I think that change in the geometry is where I made up a bunch of my camber. Before the springs I could only get 1.4 / 1.5 ish.
mpicher is offline   Reply With Quote
Old 05-23-2015, 09:24 AM   #3085
MTeator
First 86
you guys are lucky. After the springs my LCA's are almost parallel with the ground now and I only gained a tenth-ish.
Scion First 86 in Lexington KY - Firestorm 6MT - Delivered May 17, 2012
Mods: Motegi 17x7 TrakLites, BFG Rivals, K&N 33-2300 Filter, Nameless Perf. Track Pipe, TRD springs & rear bar, Hotchkis front bar (eh), Kask trailer hitch
MTeator is offline   Reply With Quote
Old 05-23-2015, 09:41 AM   #3086
vroom4
Seriously anything more than 1.5 ish up front is cheating, the OEM struts with crash bolts are barely -1.2 if you're lucky.
vroom4 is offline   Reply With Quote
Old 05-23-2015, 09:44 AM   #3087
YawMomentRacing
YawMomentRacing's Avatar
Drives: 2013 Red 6MT Scion FR-S
Agreed. The TRD springs barely affect front camber b/c of the strut front suspension. The multi-link rear gains much more camber with the lowering springs.
Dave Ogburn | Yaw Moment Racing
2013 Scion FR-S - C-Street
http://yawmomentracing.blogspot.com/
YouTube Channel
YawMomentRacing is offline   Reply With Quote
The Following 2 Users Say Thank You to YawMomentRacing For This Useful Post:
Biggins (05-23-2015), Laloosh (05-23-2015)
Old 05-23-2015, 12:54 PM   #3088
solort
Drives: Series 10 FRS
Originally Posted by ksconekiller View Post
The Koni full replacements allow too much camber up front. If you are using the full Koni struts along with the smaller camber bolts maxed out, you will have an illegal amount of front camber. I'd say over 2.5 degrees is easily possible. I personally wouldn't have a problem with someone using the replacements as long as they keep the camber where it's possible with OEM struts (1.5 or less).
Has someone measured the spring perch height and other dimensions between a stock FRS front strut and the full Koni strut to see if there are differences?
solort is offline   Reply With Quote
Old 05-23-2015, 07:58 PM   #3089
xwd
What is off on them? Are the holes on the ears in the wrong place? When I got my MCS shocks originally they just had slotted holes, so I contacted MCS and they quickly made inserts to locate the shock in the exact right spot. If it ain't exactly the same as stock it is illegal.
Old 05-24-2015, 12:24 AM   #3090
markw
Drives: 2014 FR-S
Is 1.9 with the stock strut? What's the camber curve of the front suspension? It very well could be that just changing the springs may give you up to a half degree, putting you over 1.5 degrees on stock struts. As for the Koni's, as long as you pull the camber back into the range you would get with stock struts, you should be good. This is why I'm curious as to if 1.9 was TRD spring + crash bolts + stock strut.
Mark
markw is offline   Reply With Quote
Old 05-24-2015, 12:55 AM   #3091
renfield90
The Stig's German cousin
Most? Haha my codriver and I were the only ones on BFGs in CS. We ran the 245/40/17.
The RX8 and M3 (IIRC) were on 245 stones. Everyone else was 225 or 235. Harvey/Fenter were on 225, they have the same size wheel as us.
The tires were pretty mushy, but otherwise I like them a lot. I'll probably go with the 225 next time, because an already-not-super-communicative tire getting pinched and mushy makes reading the tire that much harder. That said they make good grip, and holy hell they are EASY to launch!
I am not good at launching the car, mind you - go check my El Toro 60' times, or any of my times from last year (El Toro, Mineral Wells, Finale). These tires just made it way easier. Procedure was this:
1. Rev to 5k
2. Launch. Slip the clutch, keep throttle steady
3. At 10-20 feet, full throttle
4. At 30-40 feet, dump clutch
I didn't play with revving higher because it was working really well, and I didn't want to snap axles or burn my clutch. I'm sure 2.0 is possible with someone who is better at launching. Hard to say how much is the compound and how much is the extra width of the tire.
I'm not able to stay for the tour, so good luck to Dave and the other twins still there!
Old 05-24-2015, 11:41 AM   #3092
YawMomentRacing
Thanks Manfred. Safe drive home
Very wet today. Should be interesting.
YouTube Channel
Old 05-24-2015, 02:38 PM   #3093
Cueman
Cueman's Avatar
Mark
Still on the stock strut and using Toyota crash bolt: SU003-02818. Everything is by the book. I did loosen the two lower control arm bolts, pull and tighten, and then use the hub, jack method before tightening the two strut bolts. I am 100% confident it is legal... but maybe less confident that my camber gauge is accurate.
I had between 1.3 and 1.4 on all four corners prior to the springs. Now 1.9 front and 2.1 rear.
Old 05-24-2015, 05:43 PM   #3094
RMP
Drives: 1992 Isuzu PuP, 2014 FR-S
Has anyone checked the camber curve for our cars or know of a graph that is available online?
RMP is offline   Reply With Quote
Search this Thread:
Advanced Search
Cinco De Mayo SCCA SOLO Ryeong86 NY / NJ / CT / PA 0 04-23-2013 06:22 PM
Koni Sports in SCCA SOLO Ryeong86 Tracking / Autocross / HPDE / Drifting 4 04-22-2013 01:58 PM
2013 Preliminary SCCA SOLO and PRO SOLO National Schedule Scooby South Tracking / Autocross / HPDE / Drifting 13 12-05-2012 09:08 AM
Houston SCCA Solo #9 - 5 FRS, 1 BRZ hankster Tracking / Autocross / HPDE / Drifting 0 10-09-2012 02:35 PM
SCCA Solo Car Class for the FR-S/BRZ? MrVito Scion FR-S / Toyota 86 GT86 General Forum 31 06-15-2012 11:03 AM
