#2423 | |
Senior Citizen
Drives: Scion FR-S
Put your mouse over the brake pads. It will say, "MSRP excludes tax and installation." This means the listed price does NOT include install, thus it is a dealer option. You do not pay separate installation charges for port options. You generally pay installation for dealer options. The only exception in the list to my explaination is the 18" wheels. Their description indicates port option. My dealer confirmed they are not port option and that items description is misleading because the tires are not part of the pricing in the package. Dealer will charge extra and only sell as wheel tire package which would generally cost about $2400. Go research on your own and ask your dealer or Scion direct. I'm not trying to convince you I am right. If I can ask the manufacturer and their sales dealers to confirm of the TRD sway bar and spring package was available in their ordering system as a port option and they both say YES, my next focus is on gathering documentation needed per SCCA guidelines. My focus from now is on documentation, not verification. I'm past that. |
#2424 |
I called a local Scion dealer up the street and the springs and swaybars are new options for the 2015, the website doesn't have performance parts as build options. Previously you could get the air filter or intake, but it looks like no one really looked into that one.
According to the guy I talked to, who didn't sound like a complete idiot, they are port installed options and the car is delivered to them with everything installed. Like simpleasbest said, dealer installed options usually have a disclaimer you may get charged more because the dealer WILL charge you to install them unless you negotiate it into the price of the vehicle. You can get them as just normal parts and have the dealer install them as well, it's the same spring and swaybar kit as has existed the last couple years. However, that would not be CS legal, you would have to prove you ordered the car with the parts on it. |
#2425 |
Senior Citizen
Drives: Scion FR-S
Correction: You only need to prove you CAN order the car with the parts. Perfectly legal to add the actual parts after yourself. Just go look up DS Mini S with JCW suspension or Corvettes with Z51 package. As long as the part was available for your make/model/year car as a Standard Part, you can run it. In our case its not a full trim conversion, just seperate line item optional parts.
#2426 |
Novice Autocrosser
Drives: Scion FR-S Red//MT
SCCA Solo C Street Discussion
This all sounds like great info. There is another thread that documents he spring rates that people have gathered and that one showed the TRD springs as 3.5k/5.8k. Are those the Japan only TRD springs versus what we get here as the USDM TRD springs?
http://www.ft86club.com/forums/showthread.php?t=8739 Sent from my iPhone using Tapatalk |
#2427 | |
The one sticky point I see is these are not Scion parts in any way, they are TRD parts and TRD manufactures them. I could see a "clarification" disallowing the use of them, but who knows. |
#2428 | |
Senior Citizen
Drives: Scion FR-S
Also, the part numbers are clearly labeled on the parts. |
#2429 |
There has been some talk lately regarding this stuff since the last Fastrack there is an item to make all "Porsche Exclusive" parts legal for stock. Porsche is very ambiguous about what all is included under that label, it could almost mean anything because as long as someone pays Porsche enough they will do just about anything under that label.
One proposal was to add a rule so no option accessories could be used not allowed to be changed under other street class rules. I would be in favor of that. |
#2430 |
Senior Citizen
Drives: Scion FR-S
Good luck with that. It's too wide spread with almost all the Miatas in ES with R package conversions and Hard S packages, HS/DS Minis with JCW suspension parts, and Corvettes with Z51 packages.
#2431 |
Package conversion isn't really the same thing. I think it will have traction to be honest and after the whole Porsche Exclusive thing in the April Fastrack.
#2432 | |
Drives: SSC #79
When I go to the Scion site, it gives me the option of building a 2014 or a 2015. The TRD Springs and Bars are available for both years. The one interesting thing is if I select the Cold Air Intake, a pop-up says that it is a Dealer installed option. I have a 2013, so I might be SOL anyway. ![]() Mike |
#2433 | |
http://www.scionchulavista.com/scion...sories-pricing |
#2434 |
Novice Autocrosser
Does any one have any additional methods of proof we can use. It would be great to have something beyond the port order form to show at national level events. There's just so many 86 drivers in the San Diego area.
#2435 | |
Novice Autocrosser
That makes it look like it's only a 2015 option or am I wrong? |
#2436 |
Drives: In Perfect Control At All Times
I dunno guys. Do we actually want this? If the springs are legal then aren't the TRD 18 7.5J +35 offset wheels legal, and the upsize rear sway bar legal? That would make a monstrous Hotchkis bar work a lot better too...
And then the FRS seems like a serious overdog in CS... A situation that wouldn't last long just based on the unbalance between it and the BRZ. That said, I'm going to go buy all that and a short shifter on Monday. I knew buying a brand new car was worth it...
| Cinco De Mayo SCCA SOLO | Ryeong86 | NY / NJ / CT / PA | 0 | 04-23-2013 06:22 PM |
| Koni Sports in SCCA SOLO | Ryeong86 | Tracking / Autocross / HPDE / Drifting | 4 | 04-22-2013 01:58 PM |
| 2013 Preliminary SCCA SOLO and PRO SOLO National Schedule | Scooby South | Tracking / Autocross / HPDE / Drifting | 13 | 12-05-2012 09:08 AM |
| Houston SCCA Solo #9 - 5 FRS, 1 BRZ | hankster | Tracking / Autocross / HPDE / Drifting | 0 | 10-09-2012 02:35 PM |
| SCCA Solo Car Class for the FR-S/BRZ? | MrVito | Scion FR-S / Toyota 86 GT86 General Forum | 31 | 06-15-2012 11:03 AM |
