#2339 | |||
Drives: ND2, formerly BRZ (MT/CBS)
| The Following 2 Users Say Thank You to jdrxb9 For This Useful Post: | Jawnathin (03-09-2015), renfield90 (03-09-2015) |
#2340 | |||
Drives: Toyobaru FRZ
...and without understanding your formula and how each factor is weighted, I'm naturally a little skeptical. It isn't skepticism of you or your effort, I appreciate the contribute and discussion, its just this calculation is unknown and without validation of any type to ensure accuracy. Hopefully you understand where I'm coming from, but let's go with it and see where we end up. BTW, did you also factor in the gravitational pull of Mars? ![]() Quote:
If you wanna take a stab at my logs I can send them over. Let me know and I'll PM you with a way to get them. This might be going a little far, but if it isn't much to do three different events, I'd like to see how they turn out. One is from the long runway course (the course I described above) and the other is a 'square' site that is decently open but not quite as fast as the runway is. I should have some data from the 'fast' course on that site where I end up on the rev limiter a few times and data from a pretty slow course where I'm still a few hundred RPM off. I'd be curious to see what if any differences between the three different course/runs are. |
#2341 | |||
That said, I did compare the results to my data and also C&D's 5 mph - 60 mph data (which, btw, shows 0.5 sec variance for the same car) and added a correction factor to get it to generally match. I say generally, because the factor required to match 7.5s 5-60 is different than matching 8.0s 5-60 is different than all the different factors required to match all my different 'pulls'. In the end, I just had to pick one factor and let it be. Quote:
#2342 | |
Drives: 2013 Firestorm FR-S
Decided to stop stressing over the details/data, and ordered a set of 235/40/17 Star Specs. Gonna go pick them up in South Bend on the 21st and hope for the best!
"Shark_Bait88, the man who’s spent the most money modding his stock FR-S and it’s still stock." -@jdnguyen
#2343 | |
Drives: Some kind of Subaru
#2344 | |
If you had a Outback wagon winter beater we could totally carpool together and fit both sets of wheels and tires, maybe even bring along some dude named Karl too...
#2345 |
| The Following User Says Thank You to G_Ride For This Useful Post: | Shark_Bait88 (03-10-2015) |
#2346 | ||
Nice. I've got a set of RE71Rs on the way too. Curious to see what you think of them once you get some runs on them. So far I've heard some great things. Did you get 245/40s? |
| The Following User Says Thank You to Jawnathin For This Useful Post: | Shark_Bait88 (03-10-2015) |
#2347 |
I sent over my logs. Car is on 245/40 RS3s.
Here are the videos of those runs. This is our runway site, Crow's Landing. This was the Speedway CAM course on 3/7. I ran a little faster on the 2nd day (same course) but since I couldn't get a video, I just sent the logs of this video. Tires have about 300 runs at this point. [ame="https://www.youtube.com/watch?v=_T8V7zIS3co"]BRZ AutoX - 3/07/08 CAM - Jonathan - YouTube[/ame] This is our local 'paddock'/parking lot site. This course was a little faster than your typical course here, I hit the rev limiter three times. Fun course though. Tires had around 180-200 runs at this point. [ame="https://www.youtube.com/watch?v=jkE99yRSgXg"]Subaru BRZ AutoX - 10/26/14 AAS @ Marina- Jonathan - YouTube[/ame] |
#2348 |
Thanks! Yeah, I've heard good things so far and figured I'd give them a try. G_Ride lives near me and we hang out a lot, so I will get a chance to experience the RE71Rs too. My main concern was improving my driving and doing well within my region. Next year though, I'll likely get a set of 245/40s and try to make more national events.
#2349 |
#2350 |
Just based on the video, I took a look at the CAM event data first because it looked like it would have a lot of interesting analysis opportunities. Looking at the video and through the data, I pulled 9 distinct full throttle zones from the run. The first plot below (should be a clickable thumb) shows all the data as recorded by solostorm and the second plot shows just the 9 FT zones. I analyzed zones #2 and #4 as constant FT even though there are very momentary ‘lifts’ of the throttle – even if the data is good, we’ll say these could’ve been 100% on the later, quicker run
![]() One thing I noticed right away is that you have a lot of ‘repeats’ in your RPM data and a fair amount in your speed data as well. I think your OBD dongle is reading at a lower rate than what solostorm is recording at. The data required a little more interpretation, but it still provided a good sampling of initial speeds and distances. The full results are in the table/image at the bottom of the post. The various columns show the results from each pull and the total FT acceleration time is in the next to last column. The rows show the baseline 245/40-17 R-S3’s with the shifting as driven as well as various other comparisons. To summarize: Code:
gears used tire 1-2-3-2-3 245/40-17 R-S3 18.317 sec 1-2-3-2-3 235/40-17 ZII* -0.001 sec 1-2-3-2-3 225/45-16 ZII* +0.004 sec 1-2-3-2-3 225/45-17 Rival +0.004 sec 1-2 245/40-17 R-S3 -0.026 sec 1-2 225/45-16 ZII* +0.121 sec 1-2 235/45-17 RE-71R -0.061 sec Those 2nd-gear-only results are shown in the bottom 3 rows. I decided to go with the baseline tire and two extremes in the 225/45-16 and 235/45-17. To my surprise, holding 2nd was a bit quicker for the baseline size and also the tall 235/45-17, which I wouldn’t have guessed. Even more surprising is the 225/45-16 is only 0.121 slower despite being on the limiter for a total of 5.4+ sec! So this is indeed a case where taller is better. But for a fairly fast course with ~18 sec of full throttle acceleration over an ~60 sec run, the differences are small. My conclusion is still to make a reasonable choice and drive! I’m really suspicious that the gearing advantage is not worth the compromise in overall cg height and sidewall stiffness (though you could mitigate the latter with 235/40-18’s ).Definitely an interesting data set to look at. I do plan to also look at the AAS data as well, but I'm not sure when I'll get to it. ![]() ![]()
| The Following 3 Users Say Thank You to jdrxb9 For This Useful Post: |
#2351 |
Very interesting, thanks a bunch for taking the time and analyzing it. If it is too much effort, no worries about the AAS event, just wanted to provide two different data sets of your typical runway and 'parking lot' course and see how they pan out.
Doesn't get much closer than 0.001 I suppose. Interesting as I thought it would be favorable to the 245 than most other courses. I wonder what this means for a course that I thought was more favorable to a 235. Maybe 235/40 has a bigger gearing advantage than I thought? That AAS course is pretty 'neutral' I would think, as it did give three instances of briefly hitting the rev limiter even on a 245. Some other courses here it's still a few hundred RPM short of the rev limiter so the 235/40 has no downside on the FT zones. You are right, I did slow down a bit once I got into the slalom and may technically have not needed a shift into 3rd, but I figure the car was more settled down @ 5500rpm in 3rd vs 7200~ rpm in 2nd while in a high speed slalom. Also upon the exit of the slalom I'm already in the right gear in the acceleration zone, rather than spending time shifting when I got there. You do bring up a good point about leaving it in 2nd. I think I tried that for one of my earlier runs and I felt I was on the limiter too much, so I did the upshift to 3rd. Which brings up a quick question. You touched it a bit with analyzing what happened if I left it in 2nd, but I'm under the impression this data only represent FT zones. So with that in mind, how does your analysis account for the times I'm above 59mph and into 3rd, but not FT? I was 65mph at the exit of the slalom entering that turn around. There was a few moments of partial throttle/lift before it drops below 59mph. I would have liked to save the time on the shifts, but I'd hate to be giving up 6mph at any point on the course. |
| The Following User Says Thank You to Jawnathin For This Useful Post: | Shark_Bait88 (03-12-2015) |
#2352 | |||
| The Following User Says Thank You to jdrxb9 For This Useful Post: | Shark_Bait88 (03-12-2015) |
| Cinco De Mayo SCCA SOLO | Ryeong86 | NY / NJ / CT / PA | 0 | 04-23-2013 06:22 PM |
| Koni Sports in SCCA SOLO | Ryeong86 | Tracking / Autocross / HPDE / Drifting | 4 | 04-22-2013 01:58 PM |
| 2013 Preliminary SCCA SOLO and PRO SOLO National Schedule | Scooby South | Tracking / Autocross / HPDE / Drifting | 13 | 12-05-2012 09:08 AM |
| Houston SCCA Solo #9 - 5 FRS, 1 BRZ | hankster | Tracking / Autocross / HPDE / Drifting | 0 | 10-09-2012 02:35 PM |
| SCCA Solo Car Class for the FR-S/BRZ? | MrVito | Scion FR-S / Toyota 86 GT86 General Forum | 31 | 06-15-2012 11:03 AM |
