#197 | |
i'm sorry, what?
Drives: Canada
#198 |
Drives: Some kind of Subaru
My friends in their CS RX-8 that just had their konis revalved really felt the difference. It was worth the cost for them, especially since they got the konis revalved for free. They had them revalved when another friend brought the konis with him to Lincoln. I think my friends got the hookup for the revalving due to being a friend of friend type of thing. Like celica73 said, you need to know the valving unless the ones doing the revalving have done previous revalving for other BRZs or FRSs. In that case you could ask them to how they've revalved the previous cars.
#199 | ||
Dodging cones
Drives: 2013 BRZ Limited, 93 Z28
| The Following User Says Thank You to Kido1986 For This Useful Post: | jprice130 (09-11-2013) |
#200 | |
Drives: ND2, formerly BRZ (MT/CBS)
| The Following User Says Thank You to jdrxb9 For This Useful Post: | jprice130 (09-11-2013) |
#201 | |
AutoX Nut
Drives: 2022 BRZ
Also, thanks for the reminder on the +/- 1" wheel allowance. We have been looking at the various offerings for 15"/17" front wheels/tires and 16"/18" rear wheels/tires, but we already put a significant investment in the wheels we have now, so that would be hard to justify. We could resell I guess, but I think it would be tough to find a buyer and get much of our money back. |
#202 | |
Drives: Vroom Vroom
Whether the RX-8 was the car or not is debatable. DWX is right as I was second fastest and only a few tenths off Heitkotter Day 2. This with RS3's that arguably had one to many heat cycles and rear shocks on their way out. I also felt I left a ton of time by not attacking the back slaloms. So I had lots to think about going into this year. In regards to the R1R, there is no magic compound for specific sizes. All Toyo R1R's are made with the same. The tire has been campaigned for years in most STX/STR sizes. 235, 245, 255. First year STR winner was on 255's. Last years fastest Miata Day 2 was on R1R's, 245 I think. Day 1 may have been Z1's. For some reason, I don't think most were paying attention. I've been. In regards to construction, the 195 stands in a league of it's own. It's the only size that doesn't use a base which I've been advised can start anywhere below 2/32 (wear bars) for all other sizes, not necessarily at it. If you look up delamination and Dunlop on google images to see that Z1's may have used a base compound on certain sizes as well. It's not unheard of for tire manufactures to do this. The tires I won on were poorly shaved by Tirerack. Outside tread blocks are 6/32 and inside are close to 3/32 as they sit now. The used 235 set I started with on the practice course were 2/32 with some areas close to 1/32. Being advised by many Toyo users I needed a new set because of the tire going off around that point I heeded and had a set sent it. Because of the poor job by Tirerack I used one older one with the most tread and three of the new ones for competition. The R1R is a cheap tire and you can get a very usable life out of them if you set up your car properly for the tire. Not so sure I'd run a stock class car on the R1R though regardless of the size unless you can get a enough camber. At Lincoln the ZII and RS3 seems to be a great option for stock and touring. I know I saw the ZII switch occur in RTR as stated earlier and saw Heitkotter check out on us after session one when he switched to them from Rivals. The Rival was decent until the rubber was laid down and the sun was out. From that point on it felt like a rain event. I had a feeling this may occur and had somewhat of a contingency plan. Everywhere else the Rival has been fine. Even works great in the wet. One last note, I would be a huge proponent for a spec Street / Street Touring tire. With the new models being released next year its only going to become more frustrating as to choosing the best tire for a given surface and conditions. Last edited by JeffHNY; 09-11-2013 at 06:18 PM. |
| The Following User Says Thank You to JeffHNY For This Useful Post: | MTCRX (09-11-2013) |
#203 | |
i'm sorry, what?
Drives: Canada
also not sure why he needed a front bar, both front and rear bars have 3 holes for adjustment on each side left to right... maybe wasn't enough at stiffest setting? could have adjusted the rear to softest and front to stiffest.. from a technical point of view, the car is VERY well prepped for "stock" competition and honestly doesn't require that much work. my only petpeve are the different diameter wheels front to back, kinda a bummer.
#204 | |
AutoX Nut
Drives: 2022 BRZ
You're right about the exhaust, there's not much to lose but we did drop 10 lbs with our exhaust and it's good and loud! |
#205 |
Drives: 2013 Subaru BRZ
Why do you feel this is necessary?
-John L.
2011 BMW M3 - 57 FS 2007 Ford SGT - 57 FS 2013 Subaru BRZ - Sold |
#206 | |
Drives: 2013 Scion FR-S Firestorm
Of the Hankooks, Dunlops, and Rivals, it seems to be almost a dead heat between which is fastest, and all of them can be run full-tread without them chunking themselves to death. My problem with the Toyos is that it just isn't really a streetable street tire. I got into ST so I didn't have to change tires at an event, and that is exactly what I do. I like the idea of a "spec tire", but finding a consensus on that tire might be difficult - especially since the best choice might be different for each car. I'm not convinced the Rivals worth $50 more per tire than the Hankooks (even though most of my competitors who have switched to them have gone faster once they did - but they were previously running Dunlops or Toyos), and I'm not big on the "peakiness" I've heard about with the Dunlops (though I have not driven them). (and I don't even want to consider the expensive-ass Yokohamas - glad to see they've pretty much gone away). |
#207 |
i'm sorry, what?
Drives: Canada
because i've had off-the-shelf konis before and this time i would like to have a set of dampers all perfectly matched to each other and to the car.
Given that we currently have limited options in terms of damper-only upgrades, if the cost is reasonable it means we'll be that much closer to being optimized for our class without breaking the bank.
#208 | |
Lost in Kansas
Drives: 2013 Scion FRS (Raven)
#209 |
My friend and I will be trying Rivals. Most of our local events are on asphalt with a few on concrete.
#210 | |
-John L.
| Cinco De Mayo SCCA SOLO | Ryeong86 | NY / NJ / CT / PA | 0 | 04-23-2013 06:22 PM |
| Koni Sports in SCCA SOLO | Ryeong86 | Tracking / Autocross / HPDE / Drifting | 4 | 04-22-2013 01:58 PM |
| 2013 Preliminary SCCA SOLO and PRO SOLO National Schedule | Scooby South | Tracking / Autocross / HPDE / Drifting | 13 | 12-05-2012 09:08 AM |
| Houston SCCA Solo #9 - 5 FRS, 1 BRZ | hankster | Tracking / Autocross / HPDE / Drifting | 0 | 10-09-2012 02:35 PM |
| SCCA Solo Car Class for the FR-S/BRZ? | MrVito | Scion FR-S / Toyota 86 GT86 General Forum | 31 | 06-15-2012 11:03 AM |
