#1989 |
Senior Citizen
Drives: Scion FR-S
Stock lug nuts seem to have pretty soft threads. If you are constantly swapping out wheels, the threads seem to go bad pretty easily. If it gets too bad, it can even damage the stud's threads.
Switch to any conical type lug and things will easier. Personally I go for the steel ones, as the aluminum ones tend to stretch and lose torque. Not worth the risk, imo. If you want to get the best of the best, there's the Project Kics R40. I've used them and they are fairly lightweight and awesome!
#1990 | |
Dodging cones
Drives: 2013 BRZ Limited, 93 Z28
#1991 | |
i'm sorry, what?
Drives: Canada
I used to think the FRS/BRZ stud/lug problem was hearsay until it happened to me while changing to snow tires. So is it a nut problem more than a stud problem?
#1992 | |
Senior Citizen
Drives: Scion FR-S
I change wheels roughly 50 times per year and my original studs are still good. As for lug types, I try to keep things simple and just get ones that use either a 17mm or 19mm (I prefer 17mm) standard hex. Trying to search for your special lug key at an event or the fear that you will forget it when going for long distance event (where I would swap tires on-site) isn't worth it. (Street theft isn't on my list of concerns). If you are daily driving the car on the wheels, then I would recommend a closed end type lug nut, as the studs can get pretty rusty when exposed to wet elements. |
#1993 | |
AutoX Nut
Drives: 2022 BRZ
http://www.ebay.com/itm/20-GORILLA-S...1015c7&vxp=mtr |
| The Following User Says Thank You to jprice130 For This Useful Post: | Kido1986 (01-02-2015) |
#1994 |
Drives: 1991 honda civic si
The lug nut metal should be softer than the stud metal, but hand tightening and loosening shouldn't cause issue.
If you're swapping wheels 50 times a year, that's outside of normal usage life and it's probably time for ARP studs. |
#1995 | |
C-Street AutoX
I'm going to call on it on Monday when Buddy Club is open, but these look like a fantastic option for the price...how heavy are they? I like the way they look as well, available in gun metal, and white:
-2013 Scion FR-S C-Street
Gearhead Homes - Homes geared towards car enthusiasts: https://www.facebook.com/GearheadHomes.RealEstate |
| The Following User Says Thank You to SeanRTR For This Useful Post: | 7thgear (01-02-2015) |
#1996 | |
Senior Citizen
Drives: Scion FR-S
Buddy Club only has the SF Challenge version available last I checked. The SF Challenge has the rim strip. If they just had the basic version, I bet it would sell better. |
#1997 |
Drives: 2014 Subaru BRZ
The stock lug nuts are the issue, I had problems with the stock set up on my wrx and as soon as I switched to different lug nuts the problems disappeared (replaced 3-4 studs).
In the last 3 years I ran over 100 autocrosses events and swapped wheels from street to race and back to street for nearly every event without problems with the gorilla lugs and a biannual copper grease application. I recommend ditching the stock lug nuts to anyone who will listen. |
| The Following User Says Thank You to 14stu For This Useful Post: | VADERR (01-02-2015) |
#1998 |
Dodging cones
THe stock lug nuts don't work with a whole lot of different aftermarket wheels so I don't think many of us are using them. I'll be looking into the Gorilla ones for sure though
#1999 |
I've aways used cheapo mutekis no problem. We can get them in every color known to man
#2000 |
Completely Lost
Drives: 2015 CBS BRZ Limited
My CGLOCK came in! Anyone else use these?
#2001 |
I just use the seatbelt lock trick. Doing anything to keep you strapped in to your seat is a huge benefit though. You'll love it.
| The Following User Says Thank You to qoncept For This Useful Post: | VADERR (01-05-2015) |
#2002 |
Viceroy of these jams
Drives: 14 CBS BRZ
So doing a sound tube delete is no good by the rules I'm guessing, but what's everyone's take on whether someone would protest at a local event?
| Cinco De Mayo SCCA SOLO | Ryeong86 | NY / NJ / CT / PA | 0 | 04-23-2013 06:22 PM |
| Koni Sports in SCCA SOLO | Ryeong86 | Tracking / Autocross / HPDE / Drifting | 4 | 04-22-2013 01:58 PM |
| 2013 Preliminary SCCA SOLO and PRO SOLO National Schedule | Scooby South | Tracking / Autocross / HPDE / Drifting | 13 | 12-05-2012 09:08 AM |
| Houston SCCA Solo #9 - 5 FRS, 1 BRZ | hankster | Tracking / Autocross / HPDE / Drifting | 0 | 10-09-2012 02:35 PM |
| SCCA Solo Car Class for the FR-S/BRZ? | MrVito | Scion FR-S / Toyota 86 GT86 General Forum | 31 | 06-15-2012 11:03 AM |
