#155 |
AutoX Nut
Drives: 2022 BRZ
So after owning an automatic limited BRZ for over a year, I decided that I had enough of the automatic action and got a manual FR-S. I know that seems kind of silly, but the extra/more expensive features of the limited BRZ didn't really do much for me, so I was able to break even on the deal and get the manual I always wanted!
Anyway, I swapped over my OEM crash bolts and Whiteline 20mm sway bar yesterday and unfortunately, my new FR-S will only give me -0.8 camber in the front (I got -1.4 with my BRZ). Any RTR legal adjustments I'm missing here? I just swapped the top bolt, pushed the rotors in as far as I could, and tightened everything down (had to adjust toe of course). Am I just unlucky? |
#156 |
Autocross Nut
Drives: Argento 2013 Scion FR-S - MT
Yea, I think so a bit... You might be able to losen the top hat and get a tad more but not likely.
Seems like you can get anywhere from .8 to 1.4 on these cars... I think I ended up at 1.1 being what I could get. If you are swapping wheels you may want to do ARP studs / Blox nuts (or something fancier).... I just did mine this weekend after stripping 2 studs. Got a smoking deal on some Koni's so they are on the way too... |
| The Following User Says Thank You to mpicher For This Useful Post: | jprice130 (08-15-2013) |
#157 |
AutoX Nut
Drives: 2022 BRZ
I hear ya on the lug studs. In the year I had my BRZ I did manage to strip one stud and had to get that replaced. Getting aftermarket studs will definitely be on my radar.
#158 |
Drives: 13 BRZ WRB
What lugnuts are you guys using that you are stripping studs?
#159 |
I use Muteki 32905N (open ended, long, not keyed) and haven't stripped a stud. I have ARP studs to put on the front yet for my spacers but I've changed the tires probably 20 times without issue. Torqued to 75ft lbs.
#160 | |
Drives: Some rust bucket
http://www.ft86club.com/forums/showp...3&postcount=19 |
| The Following User Says Thank You to ayau For This Useful Post: | jprice130 (08-15-2013) |
#161 | |
AutoX Nut
Drives: 2022 BRZ
#162 |
Overthinking it
Drives: BRZ in CS
I spoke with another owner at Fedex last Sunday. He said he got 1.8* with the OEM bolts. He put it on a rack, loosened everything and retightened it all down.
| The Following User Says Thank You to mla163 For This Useful Post: | jprice130 (08-15-2013) |
#163 |
Drives: 2022 BRZ
Let me know if one of you RTR guys are ready to take the jump into STX.
I am probably parting out my built STX Brz at Nationals when I am done running. It would be nice to sell Everything to one person, and they end up with a great STX car. Simmons
2022 BRZ 71 STR
Sponsors Xero-Limit//Karcepts |
#164 |
Looks like I'm going to make the jump to STX but unfortunately I've already amassed most of the parts to do so. I was going to just run CS next year and STX in 2015 but I don't think I can hold off. You definitely have some stuff I would be interested in though.
#165 |
Dodging cones
Drives: 2013 BRZ Limited, 93 Z28
Highly unlikely Ill be able to do anything quickly enough but let me know what the STX mods would cost.
#166 | |
Drives: 2022 BRZ
http://www.roadraceautox.com/showthread.php?t=45781 Simmons
2022 BRZ 71 STR
#167 |
Lost in Kansas
Drives: 2013 Scion FRS (Raven)
That exhaust is mighty tempting. I can't seem to find how much it weighs.
#168 | |
Drives: 2022 BRZ
12lbs Simmons
2022 BRZ 71 STR
| Cinco De Mayo SCCA SOLO | Ryeong86 | NY / NJ / CT / PA | 0 | 04-23-2013 06:22 PM |
| Koni Sports in SCCA SOLO | Ryeong86 | Tracking / Autocross / HPDE / Drifting | 4 | 04-22-2013 01:58 PM |
| 2013 Preliminary SCCA SOLO and PRO SOLO National Schedule | Scooby South | Tracking / Autocross / HPDE / Drifting | 13 | 12-05-2012 09:08 AM |
| Houston SCCA Solo #9 - 5 FRS, 1 BRZ | hankster | Tracking / Autocross / HPDE / Drifting | 0 | 10-09-2012 02:35 PM |
| SCCA Solo Car Class for the FR-S/BRZ? | MrVito | Scion FR-S / Toyota 86 GT86 General Forum | 31 | 06-15-2012 11:03 AM |
