#1625 |
I was going to play with my clunking sway bar tonight but I've officially given up on the Whiteline 22mm front bar and a Strano bar is on the way. Wish me luck.
#1626 |
Drives: 2013 Cayenne turbo
So our local club is having an autocross on a road course. From what I understand, it is the full course with some slaloms built into the straights to keep the speeds down.
Do I need to do anything different? I'm guessing not since the speeds are low, but maybe some brake pads and brake fluid change just for ha-ha's?
Chris
Track, Autocross & Daily Driver build thread - SOLD Another A&DD for my VW GTI - SOLD And finally, my YouTube channel |
#1627 | |
The Stig's German cousin
You probably have some rule saying 4 wheels off and you're done for the day, but if you let the fear of that limit your aggression you will be slow. That said you will want to look at runoff areas and decide what your risk tolerance is. |
#1628 | |
My general opinion is that it's really not much different. The speeds have been marginally higher at those events but you can go in expecting a normal SCCA autox. I went to a Corvette club event at the oval and they set the course up fast as hell.
| The Following User Says Thank You to qoncept For This Useful Post: | the new guy (09-09-2014) |
#1629 |
Pawn in game of life
Drives: 19 STX BRZzz
Chris - you won't have any problems. That is, unless it's raining and/or you go off. And those problems won't be related to pads/fluid...
Autocross nut
#1630 |
Drives: In Perfect Control At All Times
Is there a consensus tire size? I just picked up an FRS and a ditched my ESP WRX.
Sounds like most are on 17's with 235/40's all around... but there is occasional mention of 245's. Anyone taking advantage of the ability to change diameter? |
#1631 | |
You'd probably get more useful information by asking specific questions. As an example, the 235/40 you spoke of seems to be better for short courses. Therefore, a better question might be "Is the 235/40/17 tire useful for courses with long sweeping layouts?" ... to which the answer would be "Not usually because you'll run out of gear and have to shift into 3rd"
Chris
#1632 |
Seems that 225/235/245's all work. 225 and 235 with a stiff sidewall still provide good transient performance. 245 (at least on my car) suffers a bit on transients, but seems to work well for sweepers. The difference in gearing between the available tire sizes is too small to worry about, IMO.
Autocross nut
#1633 |
Drives: Scion, Honda
No consensus... I have 215/45, 225/45, and 235/45 from three different brands. People are competitive on each of these sizes and brands as well as 235/40 and 245/40. I'm back at the drawing board for next year, but my car feels best on 225/45. It has been faster on 235/45 and also on 215/45 though. Maybe I'll try 235/40, but I have 5-6 months to think about what I want to try next or see what else gets released...
#1634 |
Thanks all. My inclination was to order 245/40 17's... but I think I'll start with 225/45.
I also noted that 245/45 16 (a Bridgestone only size) has a recommended rim width starting at 7.5" so it's less of a squeeze than the 17" 235's. Might give that a shot if I can find some light 16" wheels. |
#1635 |
They will feel spongy compared to a 17" wheel.
#1636 |
i'm sorry, what?
Drives: Canada
one thing no one is talking about is going up to 18" wheels...
something I'm considering testing for next year assuming I can even find an 18x7 5X100 wheel :o
#1637 |
RE: potential class imbalance
I certainly am not taking sides regarding this, as I own one of the cars in question and feel it's already been discussed enough by car owners to the point that nobody wants to hear opinions of twin drivers anymore. Our reputation has taken a hit because of this. I believe my performance at nationals was hindered by 3 things - my own driving (mostly day 1), BRZ spring rates, and tires with poor transitional performance (too wide with soft sidewalls). The tire and spring concerns are a rather small thing compared to me not nailing a couple runs, but they definitely contributed to car comfort and as such have at least some of the blame for lack of pace. Not sure how much time differential is there, but the fastest twin time from each day would have placed 6th - still over 2 seconds back. Rant - There were past nationals trophy winners scattered all through CS, so I'm not really buying that the only talent in the class was the top 3 drivers. Excluding the time of the top 2 drivers, it was actually a pretty close battle. Are Stuart, Fenter, and McCelvey better drivers on average than the rest of the field - almost certainly. Could they have gone faster - most likely. Were the twins represented well at nats - I'd like to think so, but I know I left some time out there. Probably not 2 seconds, but maybe around 1. That brings the parity question to a point where a course design can easily shift the balance of power around. This was a rebuilding year for me, so next year, it's on
Autocross nut
#1638 | |
Dodging cones
Drives: 2013 BRZ Limited, 93 Z28
I considered it but found Im barely hitting the limiter at National events, timewise. The extra time accelerating wasn't worth it. Someone did the math for me based on Dixie where I RODE the limiter and showed in an ideal world, with instant acceleration from 59.2 to 62mph, I would net .1 second on that 45 second course. Acceleration hit all over the course wasn't worth it (maybe if I had enough power to cause wheel spin on acceleration but not in this car)
| The Following User Says Thank You to Kido1986 For This Useful Post: | 7thgear (09-09-2014) |
| Cinco De Mayo SCCA SOLO | Ryeong86 | NY / NJ / CT / PA | 0 | 04-23-2013 06:22 PM |
| Koni Sports in SCCA SOLO | Ryeong86 | Tracking / Autocross / HPDE / Drifting | 4 | 04-22-2013 01:58 PM |
| 2013 Preliminary SCCA SOLO and PRO SOLO National Schedule | Scooby South | Tracking / Autocross / HPDE / Drifting | 13 | 12-05-2012 09:08 AM |
| Houston SCCA Solo #9 - 5 FRS, 1 BRZ | hankster | Tracking / Autocross / HPDE / Drifting | 0 | 10-09-2012 02:35 PM |
| SCCA Solo Car Class for the FR-S/BRZ? | MrVito | Scion FR-S / Toyota 86 GT86 General Forum | 31 | 06-15-2012 11:03 AM |
