Old 02-05-2012, 06:06 PM   #29
ahausheer
Re-member
Drives: Toyota camry
This is about as good a hp graph as you could hope for. I don't mean total power, but in terms of power delivery this is very nice. Cant wait to see how aftermarket bolt ons change things, my guess is that this engine is very very efficient and bolts on's will not do much.
Nothing decays like progress, and nothing preserves like neglect.
ahausheer is offline   Reply With Quote
Old 02-05-2012, 06:16 PM   #30
carbonBLUE
Reverse Burnouts
Drives: 2013 Argento FRS
Originally Posted by bambbrose View Post
Freehand bitches :happy0180:
One is at wheels and the other is at crank. Can't compare, so I did it with 15% loss
yellow and purple are best guesses.
midrange torque is dramatically improved.
Its a good enough guess, ty
Power delivery is much better, its better than a stock gts, that's all I was hoping for, i'm 100% sold now
(wont forget you)
2013 Argento Scion FR-S
2011 Infiniti G37x
Old 02-05-2012, 06:51 PM   #31
SUB-FT86
86 Member
Drives: 2013 Toyota 86 2.0T (Asphalt)
Once that area(3200-4800) gets fixed this will be my favorite 2.0 liter engine. I wish my RSX made almost 100% of torque from 3k to 6.5k.
SUB-FT86 is offline   Reply With Quote
Old 02-05-2012, 08:24 PM   #32
ahausheer
Re-member
I doubt that area will get fixed without sacrificing something significant elsewhere. We have not just magically stumbled upon something that toyota and subaru missed.
Old 02-05-2012, 08:40 PM   #33
Buggy51
Drives: Put Put
So... if anyone's willing to explain in layman's term. Is this a good or bad graph? I have no idea what I'm suppose to look at lol
Buggy51 is offline   Reply With Quote
Old 02-05-2012, 08:58 PM   #34
tranzformer
Delights in pure handling
tranzformer's Avatar
Drives: Zoom Zoom
It is about area under the curve. Overall looks good but as others mentioned a few areas like 3200-4800 need some work. Flat torque is king so is area under the curve. Not so much peak numbers persay.
tranzformer is offline   Reply With Quote
Old 02-05-2012, 09:14 PM   #35
serialk11r
Drives: '06 AM V8V Coupe
It's rather impressive considering that it is a fixed cam profile. Very flat from 5000-7000, which is where you'll be if you're revving it. Also it's pretty remarkable that they are able to get so much torque at 3000rpm when the cam is "optimized" for 6000rpm.
The likely explanation for the dip is the intake tuning, a more sophisticated variable intake would help but that would be rather difficult to come up with.
Old 02-05-2012, 10:21 PM   #36
carbonBLUE
Reverse Burnouts
its really good for a 2L 4 cylinder engine that has no valve lift or extremely aggressive cams, gas mileage is also beyond expectations, they did a very good job
valve lift is noticed in the graph i posted with the jump in hp at 6200 rpms..
(wont forget you)
2011 Infiniti G37x
Old 02-05-2012, 10:25 PM   #37
ahausheer
Re-member
Lexus already has a more ''complex'' variable intake, its not that complex, just more expensive maybe a little larger/heavier.
Old 02-05-2012, 10:59 PM   #38
serialk11r
The issue would be tuning one and figuring out control systems for a car that doesn't come with it from the factory...can't just transplant a Lexus system over when it's made for an engine with much more displacement.
Old 02-05-2012, 11:06 PM   #39
ahausheer
Re-member
There is nothing to tune, other than activation point, on these variable intakes, they are either open or closed. We can only hope that MPG and noise constraints left a few HP to be ''unlocked''.
Old 02-05-2012, 11:10 PM   #40
serialk11r
Uh, what do you mean nothing to tune? I don't think Lexus has any 2L engines that you can just pull the intake off and move over. The pipes will be incorrectly sized if you do.
And yes they are either open or closed, but you have to have a separate controller because the ECU doesn't know what to do with a 3 stage intake.
Old 02-05-2012, 11:40 PM   #41
ahausheer
Re-member
I see what you mean. I thought you were referring to tuning Toyota variable intakes in general. I think it would be near impossible to use a three stage intake without spending huge amounts of money and making one off parts to adapt the system.
Old 02-06-2012, 06:01 AM   #42
Levi
Drives: Toyota
Here is some graph of the intake I think. Don't know what is it about but maybe there could be some relation between both this graph and the dip in torque.
Levi is offline   Reply With Quote
2013 Porsche Boxer is revealed early DIG1992 Other Vehicles & General Automotive Discussions 62 09-05-2012 01:26 PM
Next Gen Boxer Engine 4U-GSE WingsofWar Engine, Exhaust, Transmission 33 12-10-2011 01:04 AM
Toyota Reconfirms Production 2012 FR-S / FT-86 Boxer Engine, 6MT, 6AT, LSD Hachiroku Scion FR-S / Toyota 86 GT86 General Forum 30 05-02-2011 04:30 AM
Could this be the base FT-86 boxer engine? iff2mastamatt Engine, Exhaust, Transmission 2 02-10-2011 11:55 PM
More proof of FT-86 Boxer engine appears in logo Hachiroku Engine, Exhaust, Transmission 33 01-03-2011 02:47 AM
