Old 05-05-2013, 10:20 AM   #15
Frs300
Frs300's Avatar
Drives: Pile of junk
Originally Posted by charged86 View Post
Is there a way to put it on Japan's gt86 forum? Or was that a dumb question lol
think the gtx35 would be a better choice over the 30 400-7xx hp gives me room to do some upgrades. where as the gtx30 does not.
Frs300 is offline   Reply With Quote
Old 05-05-2013, 11:03 AM   #16
charged86
charged86's Avatar
But you need to consider the boost efficiency ranges. Like on a 35r it Really doesn't provide huge power untill after 20 psi. People run up to 30psi on that turbo I was running 25psi on my 30 I know you have a built motor but is it capable of handling that much boost. And then there's added temperature of the the ,35 in the engine bay as well as your intercooler. And after about 15 psi regular screw type c clamps can't hold that pressure with that much cfm. T bolt clamps will be needed. And then there's the whole deal about hooking up 600whp. In a car that weighs as much as a miata. It would break loose at high speeds in a straight line
INSTAGRAM @Rcf_700 www.youtube.com/boostindub
The Following User Says Thank You to charged86 For This Useful Post:
cf6mech (05-11-2013)
Old 05-05-2013, 11:16 AM   #17
s2d4
s2d4's Avatar
So lowered compression and bigger turbo?
What are you trying to achieve?
Old 05-05-2013, 11:20 AM   #18
Frs300
Frs300's Avatar
raw power lol...na i want to go to the track here and kill these mustangs
The Following User Says Thank You to Frs300 For This Useful Post:
lbroskee (05-06-2013)
Old 05-05-2013, 11:35 AM   #19
mad_sb
Drives: 2013 Asphalt FR-S
You really need to look at spool characteristics and decide where you want the power.
The Following 2 Users Say Thank You to mad_sb For This Useful Post:
cf6mech (05-11-2013), charged86 (05-05-2013)
Old 05-05-2013, 12:10 PM   #20
Frs300
Frs300's Avatar
going with the 35 and the head work im having done if i can rev to 9k like @NomoreNA said i will still have a strong power band
Old 05-05-2013, 12:25 PM   #21
NomoreNA
NomoreNA's Avatar
Drives: Raven FRS
With your built longblock and a good wmi kit a 35 will be the perfect combo.
NomoreNA is offline   Reply With Quote
Old 05-05-2013, 12:25 PM   #22
jamesm
i'd prefer the 2867r for the sake of response, but then i've never driven them back to back so i can't say that i know there is much difference in that area. since you have a built motor, i think the 3076r would be better as it would allow you to take advantage of the build and make big power.
these things aren't quite as cut and dry as they were before the gtx's came out, though. the little 2867 moves a whole bunch of air, especially for a 2750lb car.
The Following User Says Thank You to jamesm For This Useful Post:
Old 05-05-2013, 02:13 PM   #23
SmsAlSuwaidi
Boosted
SmsAlSuwaidi's Avatar
Drives: Not a supra....yet
Had a gtx35 on a built STI that thing was so epic ! Closest thing to the legendary t51R
Old 05-05-2013, 02:36 PM   #24
Jesse@JDLAutodesign
Jesse@JDLAutodesign's Avatar
Drives: 2013 Raven Black FRS
The compressor on thd gtx3076 is too big for that turbine wheel. Go gtx3071 or gtx3576.
Jesse@JDLAutodesign is offline   Reply With Quote
The Following 2 Users Say Thank You to Jesse@JDLAutodesign For This Useful Post:
cmss2000 (05-06-2013), Coheed (05-05-2013)
Old 05-05-2013, 02:40 PM   #25
Frs300
Frs300's Avatar
i was thinking gtx3576 that way i have some room to play with later
Old 05-05-2013, 03:14 PM   #26
uspspro
Drives: DGM BRZ, MR-S 3.5L V6 swap (sold)
3071 is a great turbo. Capable, but with decent spool. The compressor and turbine are well matched.
uspspro is offline   Reply With Quote
Old 05-05-2013, 05:38 PM   #27
Coheed
Coheed's Avatar
Drives: DGM BRZ Limited
someone had to say it. the 3076r has pretty extreme wheel choices. turbine is too small imho. go .82ar and you will make decent power with good response. the gt3582r is too big for most any track with turns. you will have a hard time getting traction. but it will be fun as hell. you need to draw a line of where you want to make power, and how you want to enjoy the car. you dont need even 400whp to smash most mustangs, even modified ones. move up to the next larger size only after you've tapped the potential of your current setup. otherwise, you could end up over your head.
Coheed is offline   Reply With Quote
Old 05-05-2013, 11:03 PM   #28
mad_sb
like @charged86 said, the 35r won't be in it's efficiency range till after 20psi.. Don't get me wrong, 35r's are great turbo's... if you can spool them if not it gonna be slow and laggy around town and tank slap you when it hits.
As much money as your dumping into this rebuild i would hate to see you end up with something un-driveable..
I say start with a 3071. Your break in tune is not going to push the limits in the least. put the break in miles on it, get the full tune on pump and e85... I'm willing to bet it will be fast enough to scare the fack out of you.
Then again , i don't know your car history so....
The Following User Says Thank You to mad_sb For This Useful Post:
charged86 (05-06-2013)
