Old 04-16-2014, 09:06 PM   #99
SniperNavy88
Drives: Camry and FRS(GT86)
Is anyone here who has the updated version TIS 9.00.026? Thanks
SniperNavy88 is offline   Reply With Quote
Old 04-18-2014, 06:52 PM   #100
regal
Originally Posted by accelerated View Post
Can anyone else confirm whether or not keys can be added with this using a tatrix2 cable? I tried via the older software on a WinXP machine as well as with the new 9.00.025 software and no dice with either.
@accelerated , I'm running into the exact same issue.
Also where is IT3System.ini ?
IMHO trying to use the Tatrix is not worth the $27 saved for a china cable. There are two issues. First is that the original crack no longer works and second you would have to use a different laptop than what you use for ECUFLASH because you have to use the std driver.
If I am wrong let me know.
2013 FRS Argento Silver 6MT
Mods:
Clear fender side lights
Tactrix ZA1JB01C 2014 Calib
regal is offline   Reply With Quote
Old 04-18-2014, 08:34 PM   #101
accelerated
Drives: Scion FR-S
Which key are you using? I was trying with a Toyota "G" key because they didn't have the correct Scion one in stock. The factory FR-S key has the "G" on the base of the key blade just like the Toyota key I had cut and tried to add but I was unable to do it with my TechStream and the dealer was unsuccessful with theirs as well.
accelerated is offline   Reply With Quote
Old 04-18-2014, 08:43 PM   #102
regal
I'm using the Scion key.
The tatrix should work if you download their J2534 open port 2.0 drivers. The problem with that is then you can't use ecuflash.
My laptop has Win7x64 and a small separate partition for winXP. Since techstream won't work with 64 bit and I don't have room for a second xp partition, I'm afraid it makes most since to just buy the china cable. I have ecutech on XP for 32 bit stability. Its to bad you can't have Ecuflash and the generic tatrix J2534 drivers under the same OS.
I may try the techstream on the win 7x64 partition with the Tatrix driver.
Mods:
Old 04-18-2014, 08:47 PM   #103
accelerated
Drives: Scion FR-S
Do you happen to have the part number for the Scion Key you're trying to use and does it have the "G" on the base of the key blade? Also, is it a master key or a valet key? Doesn't matter for programming, just curious if you had the part number and know which one it is.
Old 04-18-2014, 08:58 PM   #104
regal
G on the base,12BBY Denso.
Mods:
Old 04-19-2014, 11:12 PM   #105
J_kennington
Drives: 2013 asphalt scion FRS
[ame="http://www.amazon.com/Toyota-Techstream-J2534-Diagnostic-Scanner/dp/B00HETYRL8/ref=sr_1_2?ie=UTF8&qid=1397959464&sr=8-2&keywords=J2534+Toyota"]Amazon.com: Toyota Mini VCI TIS Techstream J2534 OBD2 USB Diagnostic Scanner: Automotive[/ame]
can anyone confirm this cable will work? and all I do is download the software on page 1 of this thread and everything is ready?
2013 raven frs(dd/grocery getter)
1990 mitsu eclipse gsx(street/strip car)
1995 gmc 1500 4x4(off road toy)
2005 Yamaha yz250f
J_kennington is offline   Reply With Quote
Old 04-19-2014, 11:15 PM   #106
FyeaFRS
Drives: 1992 Nissan Skyline GTS-t Type-M
Looks like the same cable I got. Works great with latest version posted.
Sent from Eva Unit-02
FyeaFRS is offline   Reply With Quote
Old 04-20-2014, 02:35 AM   #107
regal
Anyone find it strange that Tatrix cable owners aren't getting this to work? Aren't the china cables supposed to be a copy of that cable. We must be missing something.
Mods:
Old 04-20-2014, 03:05 AM   #108
accelerated
Drives: Scion FR-S
Do you know for sure that key is intended to be used with the FRS? I know they said they have a special key that has to be ordered when I first said lets try the Toyota G key.
That's the only thing that hasn't worked with my Tatrix/TechStream setup and it didn't work for the dealer so I'm guessing the issue isn't with the cable.
Also, correct me if I'm wrong but those with Tatrix cables are able to change TPMS while those with china knock-offs can not.
Old 04-20-2014, 05:17 AM   #109
regal
I didn't have any trouble with the key in using the Tatrix to flash the latest Rom? Man I would hate to have to buy a new key they are expensive.
Mods:
Old 04-23-2014, 11:51 AM   #110
SniperNavy88
Here is the latest version of TIS v9.10.037. Here is the link
http://www.toyota-tech.eu/GTS/Wizard...-Software.aspx
Old 05-08-2014, 08:08 PM   #111
J_kennington
where is the tis file you have to change? when I try to register using the code, it just keeps popping up the same box over and over. using the newest version that's posted on page 1
on the install instructions that come with it. it says "
Edit file c:\Program Files\Toyota Diagnostics\Techstream\bin\VerApp.ini
what do I edit in that file?
2005 Yamaha yz250f
Old 05-08-2014, 10:11 PM   #112
dsgerbc
Drives: BRZ(sold), STI
It's in \techstream\env folder
dsgerbc is offline   Reply With Quote
TPMS Tools developer Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 27 10-04-2021 02:28 PM
anyone with a shop or tools Tylub Southern California 0 05-14-2013 12:03 PM
Tools? Gost Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 35 04-03-2013 04:46 PM
Tools for DIY maintenance? F1point4 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 19 08-08-2012 08:47 PM
