Old 02-21-2015, 03:24 AM   #141
Uplink
Uplink's Avatar
Drives: anything you let me
Has anyone seen v10 floating around yet? I believe 10.00.028 is the latest.
Uplink is offline   Reply With Quote
Old 02-21-2015, 11:17 AM   #142
Trap63
Trap63's Avatar
Drives: Brz WRB - Europe LHD
post#1 updated with latest release and MVCI driver.
Trap63 is offline   Reply With Quote
The Following 2 Users Say Thank You to Trap63 For This Useful Post:
Lonewolf (02-21-2015), Uplink (02-21-2015)
Old 02-21-2015, 07:24 PM   #143
Uplink
Uplink's Avatar
Awesome Trap! Thank you!
Old 02-26-2015, 01:10 PM   #144
G_Rossney
Drives: 2013 BRZ, Limited, 6spd MT, GBS
Send a message via AIM to G_Rossney Send a message via MSN to G_Rossney Send a message via Yahoo to G_Rossney
I downloaded the software and bought a cable. If I may make a few suggestions to your post that could help others out.
1. Most $25 cables work on 32bit OS. My 64 bit Win7 machine wouldn't recognize the cable. I had to use an old 32bit Win Vista machine (don't judge me, it's old and worked fine).
2. Install TechStream software first, Modify the IT3System.ini file, then install the drivers for the cable.
3. Launch Techstream, got to setup and click on "VIM Select", select the proper cable from the drop down box.
Just some tidbits that might be useful to other newbies! Thanks for the the software downloads and the write up! I needed this for the track car. Installed role cage and harness, removed seat belts and will want to disable airbags and such.
You Rock!!!
G_Rossney is offline   Reply With Quote
The Following User Says Thank You to G_Rossney For This Useful Post:
Imperius (02-08-2017)
Old 02-26-2015, 02:42 PM   #145
JF86Red
Drives: GT86 C7P
Will be very helpful, thanks !
JF86Red is offline   Reply With Quote
Old 03-01-2015, 05:18 PM   #146
Whitster
Drives: Highlander
Anyone know what Error (S302-05) is???
Finally got it working...Norton prevented me from loading/installing the drivers. I disabled the Norton granny and downloaded the drivers and it all came together...duh...
I get this error code along with "Unable to connect to VIM".
I'm running XP, 32-bit. I think I installed it OK, changed the 1 to a 0 on the .ini file,
and get an opening screen with a couple of the blue tabs missing down the left side of the page, but my Setup/cable test stays on the +B check forever and never gets off the yellow connection indication. Scrolling the Next button results in all red indications.
The red led in the plug lights up OK, I'm beginning to think I have a bad cable/firmware.
Does the same on my '15 Highlander and '09 Taco.
Trying to find a local to swap known good cables and see what happens...no joy.
Whit in Golden, CO
When downloading the drivers:
"These are drivers (transparent J2534, cheaper chinese): https://dl.dropboxusercontent.com/u/...LE%202.0.1.msi"
I get this:
Norton says it has problems and won't Run it.
Updated: February 15, 2012 3:15:47 PM Type: Other Risk Impact: High Systems Affected: Windows 2000, Windows NT, Windows Server 2003, Windows Server 2008, Windows Vista, Windows XP Behavior
WS.Reputation.1 is a detection for files that have a low reputation score based on analyzing data from Symantec’s community of users and therefore are likely to be security risks. Detections of this type are based on Symantec’s reputation-based security technology. Because this detection is based on a reputation score, it does not represent a specific class of threat like adware or spyware, but instead applies to all threat categories.
The reputation-based system uses "the wisdom of crowds" (Symantec’s tens of millions of end users) connected to cloud-based intelligence to compute a reputation score for an application, and in the process identify malicious software in an entirely new way beyond traditional signatures and behavior-based detection techniques.
Filename: mvci driver for toyota-cable 2.0.1.msi
Threat name: WS.Reputation.1Full Path: c:\documents and settings\whit\my documents\downloads\mvci driver for toyota-cable 2.0.1.msi
[IMG]http://www.ft86club.com/forums/data:image/png;base64,iVBORw0KGgoAAAANSUhEUgAAAuQAAAIYCAIAAAC qlm5QAAAgAElEQVR4nO3df3QdV33v/c0Nf8AioTQst70NTeBA2wduC6QO5AmQlvuwWigJKb33slrMk5r eaxEH0tUL5Wm4jXIJDcshWGKR3tUU2yFJIbFFfpFISXBAJnbsy CRRZEeJ5Th2ZMuyLCs+smX9sM+Rdc48f2xpZ2t+7LPPnDPnzGy 9X+u7skZzZvb8sKP5eM+eOeJLAAAAKSa+9KUvCQAAgFQirAAAg FQjrAAAgFQjrAAAgFQjrAAAgFQjrAAAgFQjrAAAgFQjrAAAgFQ jrAAAgFQjrAAAgFQjrAAAgETkcrlly5aFfvTWt771ne985xvf+ EabdggrAACgzs4555yWlpa1a9euXbv2U5/6lO/Tiy++eM2aNWvXrv36179+3nnnVWyNsAIAAOrs0ksvXav58z//c/XRxRdffOutt6qPPve5z1VsjbACAADq7BOf+MTaxWRe8SWVtWvX rly5smJrhBUAAJaiD3zgA5dW401vepN9429+85tvuOEGX1754h e/6Esq3/72t3/7t3+7YmuEFQAAlpw/+7M/W1ulr371q1Vt4vzzzw/mFd2aNWve+c532jRFWAEAYMn56le/Wm1YWbt27dvf/vaqtnL++ee3trZGJZVcLmfZDmEFAIAl5+/+7u9ihBWbJ3d8zj///G9+85u+dm699Vb7pCIIKwAALEG/+7u/++1vf7uqpKI/0WMvOKI2RmuEFQAAlqJzzjnnAmtvectbYmwiKqlUm1cIKwAAoP 7MSaWqvEJYAQAAdfY7v/M7vqSyZs2aD3/4w8HxtpdeemnF1ggrAACgzj71qU/5ksp73vMeEfZ80KpVqyq2RlgBAAB19vu///vBpCL53r/yiU98omJrhBUAAFB/l1122be+9a3rr78++JTy2972tmuvvXbNmjWf+cxn3vCGN1Rsir ACAABSjbACAABSjbACAABSrRFhxTPSl/GtUpft1thIjQ1WXGX16tX79u2rbb8AAHAZYSXZBiuuUvedBADA MY0LK0mvklAjSe9DGnYSAIA0I6wki7ACAECN0hJWKt4GWr9+/djYmJw/Nja2adOmarerfty9e3ehUPA8b2JiwtdOW1vbvn375JKFQmHfvn 3r1683H8imTZvkjhUKhS1btvgWU9NbtmyRGx0bG1Ntht4RAwAA umyElc7OTi9g9+7dMdpUiUdReWX9+vXBregLBA9k586dwb0Khh UVgBSZVwgrAABUlIGw0tbW5i3ukGhra5OZw9y/EtpmoVCQ7axevXpoaEi2LBeYmJjwPK+zs1OtIkPSxMREaINyx/RVNm3aJLtPfGGlUCjIXQ1ulJgCAIBZk58G8i0T+qPsq1i9erXe 5urVqz3PGxoaqrhd3496vpGNeIFbNpYNyh2Tt34U1QlUr40CAL DEZSCsyA6Pii1EbTfqx+BM2echh6p0dna2traaG5Q7FpqizFmE sAIAgL0M3AYyJJX6hpXW1lZ1E0eamJjQO05sGgzd+WoXAAAASm bCSu3brZgbpE2bNvnGw+7cudO+QZudJ6wAAGAvA2FF9na0tbXV uF3LsKKox5gLhULowtwGAgCgATIQVmRi8H2BjnpEKF6b9vtmCB ahA2y3bNlCWAEAoI4yEFbUE8LqxSptbW2yuyXGo8uGZYKPLss4 op458rUQfHRZfx+M5UbldHAwLwAAkDIQVoQQmzZt8gLivRTOsE zoS+EKhYJKEsEWgi+Fqzas6M86mQ8HAIClKRthRQjR2tqqvybf d/MlXpvBmevXr/e9bl/v8whtQb1u3/O8oaEhlXgsN9rW1ibzihoZAwAAdI0IK0uKzdvqAACAPcJKfLKD RB/jor5t0abjBwAA2CCsxBc1YMX8jBIAAKgKYaUmmzZtki/pVzFF72gBAAC1I6wAAIAqhD44UtXy1SKsAACAKhBWAABAqpnDS vDlYfrrPITdC018CCsAAKAKhrBiyCgi8AJ3+y0SVgAAQBVCn4R VH+mLRU0IwgoAAEiOuWfFkGAIKwAAoBEsbwOZPyWsAACApDBmB QAApBpPAwEAADfFfuEKYQUAANgKfRQoNsuNElYAAECqEVYAAEC qEVYAAECqEVYAAECqEVYAAECqEVYAAECqEVYAAECqEVYAAECqm cKKR1EURVEU1cAirFAURVEUleoirFAURVEUleoirFAURVEUleo irFAURVEUleoirFAURVEUleoirFAURVEUleoirFAURVEUleoir FAURVEUleoirFAURVEUleoirFAURVEUleoirFAURVEUleoirFA URVEUleoirFAURVEUleoirFAURVEUlepKNqzcJ8RjTaqfNvvMU hRFURRVl0o2rDwmRLlJdbTZZ5aiKIqiqLpUsmHlUSHKQpxteJW FGGr2maUoiqIoqi7ViLAy2/AqC3Go2WeWoiiKoqi6VCPCypmGV0mIwWafWYqiKIqi6lLJhpUu IeaEON3wOivEq80+sxRFURRF1aUSDyuzQkw3vIpC7G/2maUoiqIoqi6VeFg5I8Rkw+uMEK80+8xSFEVRFFWXSjasdAoxL cTJhte0EC83+8xSFEVRFFWXSjasPCLEpBDjxsoLcVyI40LkKy2 pFs5XWnhSiIFmn1mKoiiKoupSiYeViYUsEl7/4T+cuuqq6a98ZfrLXz75gQ+YlhQi/6Y3Tf71X09/5StT11xzIpczLDkhxJ5mn1mKoiiKoupSyYaVh4U4IcRYVJ1zzs z3vleemyuXy+VyeW54+OSnPz0qxLHAkqNCjL3lLad//OPygrP79o1/8IPBJWXlhXix2nMRRX1kWMt+K21t3tBQ/NWrLd/matnzqk5jckfkTHGiKIqirCvxsHJciKNhNSLEiSuuKC9WGh8fv/LKI4Elj77pTafvu8+38Jmf/WwkovHXhHih2nMRL6zE20rUj3WvOsas2rdIcaIoiqJiVeJh5Zg Qw2E1JMT4F79YDph77bXjn/70YW3JI2972+n77w8uOTs4eDii8VEhdsU+KcGriNTa6k1MeJ7n DQ15ra0hC7e2emNj83P0ZXztBGOQoeXWVq9Q8CYm5mdu2jS/5MSEt3796y23tnpDQ/OrjI3NNxLcnOVBhbZmc4Cq2U2bvELBKxS8zs5Fn0btv+Ejaf36 +U/1/Qk9HJvTJW3ZMr9wa6u3c+f8YnrjaqP66uvXe57n7dv3+mL79s3 vYcVj7OycPy2bNoX/oVAURVFhlWxY+akQI0IMhdVBIY5/4QvBCFIul+fGx1+74oqDQhwUYui882YeeCB0seLevYciGh8R4v nYJyV4FZEKhdcv/Oreir6wvEQpY2PhLevpoWLLkrw0ysukrq1tfmGVISR5tQ5uzvK gQluzOcDgRj3P27Rp/iPD/hs+Cqq43YqnK9hg8GCDq6vkIc+DvulCofKBqICia8j/5BRFUVmvxMPKYSEGw+pVIQ6/5z3Fl14KzysnThy74oqD5503HdanIuW//vVXIxo/LMRzsU9K8Coi7d7tCe1qFFxYWr26isYrtiw/km3Ka6q8+LW1ed7if9/Lam2N3L3QPQndtLk1mwPcudMTYr67QmULw/4bPpJkkIraz2pPl9TZ6a1e/fq072Dl6rLB3bsXHYg8Ltlp1Nn5+vHaHKN+ZqL+aCiKoqjFlWx YeUiIg0Lsj6h9Qhy+9NLZgwdDs8jskSOnn346KqmcuPXWV6JbP ijEM7FPSvAqEpowgtPqCjQ25m3ZYtV4xZb1ZBCk/kEvhNfW5u3c+XonQdSxWO5JaGv2Byh3W0WBivtf8SN1HqKOqKr TFXWKDKdO/1Eel8wu8hT5dq/igfjODEVRFGWsZMPKg0IcEOLl6NojxMHly4sHDkSFkvA+le9+d +855+yNbna/EDtjn5TgVcRw3fJ9tGWLNzT0+iiQio3btyzCLoRqAXmLYefOqn tWQn+Maq3aA6wYVuw/MvzpxDhd1U4Hs4Uc0yNPlH5bynKjhBWKoqhqKvGwsk+IPcbqF+ LVSy6xzyvHb731JSFeMrb5shBPxz4pUZe90B/tr50Vm6rYsn6LwVdy6Elrq+kulf2eRLVmf4Cy38VwG8hXho/MZ8ww37LNqGnDbSCxeACKGpRjc4x6g1F/NBRFUdTiSjasPCDEgBD9lWq3EPs//OHC4GDFpPLaLbe8IES/EC8aG9wjxPbYJyV4FbGMFL5xqaEdD2pAqxzKYNmyrODgTbUJfe ir3ETo5iwPKqo1mwMM8j1HE9qC4SPDfpr/1CzbjJo2DJXVz61+J67aYwzdLkVRFBWoZMPK/UL0C7HLop4XYu/733/6xRejYkppdnb0W9/qe8Mb+ixa6xdiW+yTErxyGK6X+vTq1fNPsXrRT/auXz9/kZPXMMuWVXV2zieJQmH+3+iyfE8ge9rIWX1zlgcV1ZrNAUr6M7 o2+2/4yLCf5j81yzYN5zz00WVVsnfEdxTmY9Sf6CasUBRFWVfiYWWXE L0W9awQz7/xjae2bIkMK4XCq//1v+60a22XEL9s9pmlKIqiKKoulWxYuU+IXiGeMdazQuwUovf88 08++qj5HtDs8eP7/8t/6anU4DNCPC9Ed7PPLEVRFEVRdalkw8pPhHhGiB5j7RDimfPPH3/kkYoDVsrl8tkTJ/b95V9ur9TmM0L8vNlnlqIoiqKoulTiYaVHiO3RtVWInre+dbyr yyapzOeVqam9n/vcVmOzTwuxudlnlqIoiqKoulSyYaVDiKeE2BpW24T4pRA73v72/GOPhQ9SmZ2dzefD7wedPLnnv/23LREtbxXiKSEeb/aZpSiKoiiqLpVsWNkkxFYhfhlWW4TYdv75r0V870+5XB688cZn L7tsemAgKq/s/uQnuyMa3yrEo80+sxRFURRF1aUSDyvdQvw8rB4X4oW//MuopPLqP//zE294w2NC9Lz//dN794YuM/HMM5sjGu8W4pEYp0PSn7aN8UypfDzVi/i+PXO1tS16xjgNT7QmuktpOMDa9ydtR0FRFOVcJRtWNgrxhBA/C6tOIV78278Nu/1T2v/Nbz4uxM+E2CxElxA7PvjB6ZdfDi54+tChxyIaf0KIn8Y4HZL63 l0R6zpUy6XL8p0ijaw07EPKD3ZJnSKKoqhmVLJh5V4hfibEY2H 1sBC7VqwIRpBXbrqpS4hHtSU7hXjqD/5gKtC/MvH8810Rjf9MiIdinA5FfUtfVW8J01tQKxryh9Ta6hUKi14a61 vX94o21dSmTeE742vWt4etrfPfa+N53tiYv0HZJ6ReZVbxcKJO iKQ+9W0o9Gy0tr7+hlzzG+eimo06IeaP9PfX+Y4u3loURVFUvS vxsPKoEJ1h9bAQm9/+9vxTT+n54+WbbnpYiEcCCz8kxJP/6T+d0t5vWzp7tvev/urhiMa7hLg/xumQJia8QmH+23H161DwdenBvFLx6q7/qFNvhg2uq16Z7xnf3a5eBu9r1reHvlfmqzTja1DGNfPhGE5IUO hNMb01X1wzLB+6mOGEGD7Sv+JHP8zYa1EURVEJVOJh5REhHo6o B4XY/Fu/deD73x/7+c+Pbd7c9z/+x0NC/DRsyZ8K8YAQv3jPew7dddfYz38+2tX1q89+9qHolh8R4icxToc kr1LB7+4xf7OdrxGbHyX1JvuohdWL84M7Iy+fbW2v73Bos6Hl+ 0Zl1aCcr0KMYf8NJ0SS0cry2xAlww6bmzWckIof7dzpiYWvXbR vMHQtiqIoKoFKPKw8JMSD0fWAED8RokOIDiHuMy4pF+5YqPuNS z4kxKYYp0NddeSNEnmJ8l1NgwtHNVLxx+Dludp1deob9Spe9dv avJ07X+9iiX049odm07i66o+NvX4bLnT50GYrnpCK52r16jhn2 LcWRVEUlUAlG1buEeJ+Ie5reN0vxL0xToe66sgrkOFybrhE+eY bfgy2UO26PlHN6iVvYezc6e9ZiXE4hhNiPpCo+Vu2eENDrw/QibEzhhNS8VxVDCs2a1EURVEJVOJh5T4hftLwuk+Ie2KcDv2qo/6hr+bUchtIDuaQa4Ve8wzrhv6o36Qw74Cv5AiY1tbw2yjr18+H GF8vgmEfDLeBKu5SjfMtT0jFj/RDsG8wdC2KoigqgUo2rPxYiE1CbGx4bRLixzFOh++qo0a2yh8N Iy4NjfgGtOqfBi9yaovBETO+H4M7o7oizNdOfRyr3Fxog+qBIM MuVRzkG3VOQuf7TlS1PSuGE1LVR/Ea9KL/TCmKoqiaK9mw8iMh7hHixw2ve4S4O8bp8F1pOjv9cyo+uhxsRD 2ROzHhf8w1eGFbv34+HMjrouHaLHdP7kyh8Hq2CG1WL9+D0J6W S4KPLlfcJfOjyxV3SZ+/evXrj0SZH12u9oSYP5JHXSiE/HHHWIuwQlEUlUAlHlZ+LMSPmlF3NfvMUhRFURRVl0o8rNwtxF3 NqDubfWYpiqIoiqpLJRtW/l2IO5tUdzT7zFIURVEUVZdKPKzc0aTa0OwzS1EURVFUXSrZsHK 3EBuaVOubfWYpiqIoiqpLJd6zsr551fSTS1EURVFU7ZVsWKEoi qIoiqqxCCsURVEURaW6CCsURVEURaW6CCsURVEURaW6CCsURVE URaW6CCsURVEURaW6CCsURVEURaW6CCsURVEURaW6CCsURVEUR aW6CCsURVEURaW6CCsURVEURaW6CCsURVEURaW6CCsURVEURaW 6CCsURVEURaW6CCsURVEURaW6CCsURVEURaW6qg8rQFqVF5RKp bNnzxaLxZmZmYmJieHh4ZGRkWbvHQAgJsIK3OELK4VCQYaVI0e OHD16tNl7BwCIibACdxBWAMBJhBW4g9tAAOAkwgrcEdWzQlgBg EwjrMAd9KwAgJMIK3BHaFg5efIkY1YAINMIK3BH6G2gkydP0rM CAJlGWIE7onpWCCsAkGmEFbgjaswKt4EAINMIK3AHYQUAnERYg Tu4DQQATiKswB2EFQBwEmEF7uA2EAA4ibACd2Q9rKxDwzX7zxy AFcIK3JH1N9hy7WwwTjiQFYQVuCPrY1a4djYYJxzICsIK3EFYQ VU44UBWEFbgDsduA8n/3fhv8L/1QlgBsoKwAneEfjeQDCtZGWCrpvl/LUodzwxhBciKhoaV66tUr4PEEpHQFxl2dXW1tLTkcrlcLtfR0Z HP5z3Pkz/Wb989j2tnw3HCgaxoXFhZs2aN/cJbt25ds2YN/7hEVZJ4dHnDhg25XE4GlMHBwVwu19ra6iUfVtRdj9D/AYMT9hqzSnLoWQGWoEaHFSFuqlgeYQWxJBFWZCjp6+sLnT8yMr Jhw4aWlpaBgQE5v7u7W3bDdHd3qyXldE9PTy6Xk0t2d3cHs07w 2lnxf4Fq/x8R1iM/lsL/fYQVICuaEFa+1OvJWu55vd78f4U3P7PxYcX8T+SoT+v1D+uBgY HW1tZcLrdhw4aqVpSXydp3oF7t+ISenyR6I3RJ3AaSPSu5XK69 vV1vRM7s6urK5/Oqu0XGkb6+vr6+vlwu19PTI1tob29XTXV0dHie197eHjztoT0r 5t1bgmGFnhVgCWpaWNGTynKVVNb1pq1nJenra+z267VjCR1gGs KK/uhy7J6VfD4v06SkEoZ+LGpaLqlmygQjM4parKWlRU6bw4oU9b+ ACLsNZPM/aVRY8a0b/NGwFdWmr9naf2kkjbACZEVzwkpkUqkmrMhf/QMDA+3t7S0tLT09PX19fS0tLXLadzGQF4yRkRHVS79hwwbDSMk NGza0trYODAyoT9W1Sv4rOXj18m1FfqrfC9BX12fqOxB6EyHGi vKqOTk56Xne5OSkunD6FvO1k8/nVUdCa2vr4OBg8LQHT2DoWvLHnp6elpaW0At88BTVLrlHl1UHm PoTDw0roTPl38auri55QuQh5xb6XXQVx6z4Pg2d8Cwijs10VTP j7U88Nr8WfKIWJqwAWdGEsGJKKtWHlZ6eHnkxltcA1ScferWWF 4m+vj65WPCqI8nrSl9fn5zQr0Pq+q2uzcGtqHsBMuvIa5Jvdd9 RyOnQmwjxVlRH6nmenNnd3W1oX7bT3t4uNyTPj+wD0IWewNC1Z LNdXV1yW11dXV7g+u07RbUzPLpcl/esyGMx5JLQnhW1lr5iLmwcTC09K/UKK+YF4s1sMMuk4hFWgOxoQlgxJZXqw0rUtLwKymukzBwDAwOy S8DQjqQvFnpxst9KrtLDI/r80EtdvBVHRkZUmFDPs9i0L7uF2tvbQ7cbegJD1/L9iegJJniG5Z7ULiqs1DLAVp40mcb0sxr61y80Dsq11IodHR3y x2B+sh+zEhpWzP+fGv53TiKs6FsMPYTYbBq0SSoeYQXIjgTDyp rFFn753mRIKsu/VMUAW3NY8TxP3hKanJyUE17EhT84M7S10LBi2IouatM2RxF7RR kI9HtAFduX2Uu+SsTyXEWtZd5W6CmqXRKv28/n8ypetLS0yGDqRZ9/eZuspaVF3d5Sp0VmF9XRIm+i6erVs2JexdBI1PLxwop5ZtJs/lIRVoCsSCqs+N6qIoTw9ayEJpX6hhU1ckVdJ+res1LLVoLz69i z4i38C17umD6QxdC+IWHkAj0ioXsSerpyxp6VOooKK7X0rDRSj T0rwU8Nc6K2EiOXxEswsdWxNcIKkBWJhJU1a9as1MgVX3/PSnRSqW9Y8bQLrRxW4htyoQ+V1VtWY1ZkEDGHlYpbiRoZE2yn4 piSqlZUo4NzC/+Ir9i+zBD5fF4fnKELPYGha8mJrq4u/U6Z+jT0FAUPLerkR3Hviwztw4pnvO1i045vXf1H81YM01X9C6f xCCtAVtQ/rASTyj13370orNTppXA2YUXGDtV172kPoVR8GqilpSVqQKXNVt QjM8Hlo47CC7uJELWiDAHqEaHgimpdfURIcDG9HTngRn4atd3g CQxdS07Ij9RO6m0GT1HwnNQlrGT0iwzTfI1vrjqeGcIKkBV1CC trwuhJRQ8rltLznpVMk/d9MnGdrgv3elaQKE44kBX16VkJBhE9qaiwsrUahJVaqD4V9Rr4 pYCelaWAnhVgCapPWPE8b+VielKRYSWGzs7ORp4LZJ1LYQUNwA kHsqJuYSX4oLIvrITeLTLo7Oys6s4RYPgiw8yFFaE9p8N/g/+t+wkHkGb1DCu+dn1hRc6/XXP99ddff/31hp0jrKAqKqnU8YsMG4lrZ4NxwoGsaFxYkdHkS73rPG9db++X ZHV2di5fvnz58uW+bhU1bCX5MwB3cBsIVeGEA1nRoLCycuXK5e t6v7RuXTCsdHZ23nP33cuXL9e3snXr1oq3gXIRPOsnXWMbGRkJ PnCLpkvidfuNxLWzwTjhQFYkG1bWrFkzn1R6e5ev65V5xfNezy syqdxz991bt25dvny574Egw+a8poaVpNuvnbj8QZsfxeUPqgpt xFcJ7V69OBBW0GDN/jMHYCXBsCKTinznyvLeXplX9M4V1a2ydetWz/N8nSvmpKILRgc5R311n3p9mf5RS0uLelvawMCAXLK1tVX/fuN8Pi9fVy9fm6a/RE7PRsFNDw4OygbVWlGtqVV6enrkLuXzefl2NTmtWo7aydDd0N OAnDbPCf5oOSeexoSVzN0GAgCESrxnZeXKlcPDw+u83kV5Zd06 1a0ik8revXv37t27fPnyGMcQFVbkC1Il35tkpY6ODs/zBgcHfflDXdjU1whL+pfpmMOKTr2/NbS14Cr6YmoZw05WG1aCE6E/VpwT7G5RGwrODC6QRF6J6lkhrABAptU5rPT29sr/qp4VGVZkXlGRRTYlw4rneXv37pW9LPUNK/L99+oyH/xIfpWPDAfyYjYyMqJCjM73LcSh+UD/SGYj36bNrfX19clvSM5pX5qjlrHZSR9fKKkYVgwtRLUZnGneiv 2m46FnBQCcVM+wopKKt7hnxXeTWDUihJAdKuohoPqGldAf5bSM KfocnfyKYGlkZKS7u1v1dkRt0deaat+3ZMXWzNNROxnK5u5P7D ErFSNIesJKhr51GQAQqhE9K70LZPeJHlb0V8DVvWcl9MeohX3k R/JL/rq7u6vtWQn90aY1+7AStQOK5VAV36dRc4L3jIIhJm1hJXPvWQE AhGpEz4qKKZJ8zEcIMbxAfdSUsKLfYfGRo17y+XzovSSbndF/tGktatqwk1EqhpVqx6wYsothgTT0rBBWACDTGtGz4ksqvb3ren vXiXXr1nm9w4s1JawEx66q0bjy6RtJRg05Xw3dDQ4cMWw6qjWb sGLYSUNyqrazxLy6zW2gdI5Z4TYQAGRa4j0rQojrr79eJRUZVj xvnVjXK/OKiizxkopXc1jxPK+vr08miZaWFjn2VvI9/JzTBu3KtBF8NZxh01Gt2YQVw07GDitexJgVQ6SI8TRQ6FbUdIx hvwaEFQBwUrI9K3J52bmiXvUmw8ry3l49r6zzemOHFaREQv0l9 ngaCACclGDPir7wypUrVVKRYaXX69XzCkmlvoIP8mS0qjpqwgo AOKluYaXikitXrly5cmUwrMgvMkz4MLEkcBsIAJxUt7ACNB1PA wGAkwgrcIfhPSv0rABAdhFW4A7DbSB6VgAguwgrcAcDbAHASYQ VuINvXQYAJxFW4A6eBgIAJxFW4A7D00CEFQDILsIK3MGjywDgJ MIK3MFtIABwEmEF7jC8Z4WeFQDILsIK3MFtIABwEmEF7uA2EAA 4ibACd/CeFQBwEmEF7mDMCgA4ibACd/C6fQBwEmEF7mDMCgA4ibACd0SNWSGsAECmEVbgDgbYAoCTCCtw B98NBABOIqzAHVFhhdtAAJBphBW4o4m3gXKLqZm+idq3UtX8Zk l0f2ppPKE/GstGQhfz7UndT12G/m405q93ja3F2P9atmXeXNTfqLrsycDAQGtray6X27BhQ+2t1Y6 wAnc08XX75t8OhJWUNF73+FhVazZ/SQgrVa1S3x2ocfUGn+p6hZJmtV8twgrc0cT3rNj8o1lN+34L2P zzyNBUxfYNrQVb9vUMhaaUIRwAACAASURBVLYTXD24VtSPoYdp btBwsDZHHdwTfb7h8A3bNey2b07wU8PxVtwl33Totqra7aj98U 2b96TiOQn+EZhXsT+E2Ce84gmJOkvm1fUtDgwMtLe3t7S09PT0 9PX1tbS0yOnc4r6KDRs25HK5kZGR7u7ulpYW+Wk+nw89yXL51t bWgYEBfZfkWu3t7fpeRW1Fftrd3a0fhVrdd2hqB9TumVdMDmEF 7khbz0rwV2rUL82KK5rbNLdvuRu+duKtVdXxxmvQvh3DTMvTWO 1Jjjpe/aISe5cstxVjt0Mn7PfEci3LVao6hLqc8Kr2yvKvQS6X6+npmZy clNPd3d35fD6Xy7W2tsp7K5OTk57nyQVaW1tlhujr65OLyZwR/Nve1dUlF5MT+uYGBwf1nQzdioxKfX19Muv09PQEV9cPSm1drdj X11dxxYQQVuCOJr4ULqfRZ0ZN+KaDrVX8KMav2tD2K+5bjb/cow4kapeq2jfDVuyvhdVu17w5/SLqu6DWZZeitmV/7OZjae7fjdgN1nLCa98Z36f674HgtAwKXV1d3kL4GBgYkJ0Wwd Z8M/XF1KfBXzs2W8nlcq2traFbCW5dRh/LFRNCWIE7mjvA1jDT9/tFqaq1qDarmlntuhV33qYpw8HGa9DQTmjLoX8QNpswnJPg5vSJ 4H8rbsJyl6K25TsblseStr8bMf44aj/hUXsV+6+Bb93gtLwlNDk5KSd8i/naj5qjpoP7YN6K7wBDN21zFFErJoSwAndk6zZQta0ZmrKfWe26 FXc+3pK1HIL5HFrug+Wlq+J2o9oJ/rfiJix3KWpboXtV1QFWu665nXhLxv7rXcsJjzfTsP8VL/Nq5Epu4ZZK3XtWatlKcD49K0A9ZSusGP4/t/nNHuNXbbzfyLX8cjcfb9QvdPt9q33H7Jev8UTZ75KarqodXab/blT717va6Xr9iRs25FvXMJ1bGFbiG7OiD5X1NGrMigwi6lwFd8 BmK1EjY4LtGMasBFdMCGEF7kj/bSAv8LvMsK7Nr93Q1oK/RKLmVPyNXNXOm38pB49RX9JmNwxNGY462EiM7VY8D5ZNGRYO/llU1Y5Pdv9uBD+1P/M20/YnJHRJy9UNxyunZeyQY0ok9ZxOxaeBWlpaZGhQ+xncK8NW1DNH weVDz4O+YktLi+9poOCKCSGswB2hYYU32KIuGvl72V469wqoO8 IK3NHEp4HgpNB/T6dHOvcKSAJhBe5o4pgVAEByCCtwR9SYFXpWACDTCCtwB2EFAJ xEWIE7om4DEVYAINMIK3BHs8LKyMhIXb5FvV7t+ISOD7UcNJrP 59vb2+XCHR0dwQXUd5Toj0f6dHR01GsoaGrHugJIFGEF7mjWty 7X6wqa0JW4lrAi31yZz+f1t0gp6jtH9C8i0eXzefkCTRIGgFoQ VuCOpjwNFHy61fdd6qFffxpczNeOfplvbW0N/WrT4HfKh64lf+zp6WlpaQl9E1TwW+MNR6rPCX0Jt28V1TET2tr AwEB7e3tLS0tPT09fX59869TAwIC3uFPH/JosAM4jrMAdzXp0Wb+CBt9LrV5x7XmenNnd3V3x9dXt7e0yasg uDfk9ZLrQN2eHrqVu08htyf4Pta3Qb40Pkuv64oi+w6ExwvA+b xWhZICTp0XuttyKSkLmF5ADWAoIK3BHGsJKsLNhZGREhQnZ7ZH P522+GGxkZKS7uzuqZyL0O8lC1/JFCt+3vIZ+a7zP4OCgXN7XwVMxrBg+ilrXt2Pt7e2yo6XiVgA4 jLACdxjeYNuwsGK47ur3gEIX02fKfo6Ojg7Zr2C+2Cuha5m3lQ vwtZnP5+X+y84hmwO32dWKJ21gYEBuN5fLqXtDhBVgaSKswB3N ehpIv4KGdpnIx2Fkt4o+kMW3WMXrt54nKn7be1RYMfSshJLjSE IHzcj+G99RmM+PeVeDCw8ODsphvL7dBrCkEFbgjjTcBgodjCI7 PCQ5ULTimBWZIfL5vP71qrrQ75QPXUtOdHV16c/sqE9Dx74oXV1dLS0tcp+DxyvX9T0NFNxbmwgVnJZJKJ/PR/VIAVg6CCtwR7PCirxUy7jghX2XurdwldX7HoKL6e3ImyDy06gr dPA75UPXkhPyI7WTepvBb41X1I0Yxbdu8D0r9Qork5OTskdKnh OeBgKWMsIK3BH6uv2UvMFW3vfh+xQBIAbCCtyRzu8GUn0q+lMt AAB7hBW4wxBW6NIAgOwirMAdzXrdPgAgUYQVuKNZA2wBAIkirM AdUbeBCCsAkGmEFbgjnT0rvkd/1VO4zcUzwAAyhLACdzTrDbZmeiyQ3xMU9abXRiKsAMgQwgrcYf huoJSEFS/wNjb5o3ovnHqBW3t7e0tLS09PT19fn3zPm3ryWb3Drbu7W/+WREm+1F9+naGvcfmpfIiasAIgQwgrcEezvsjQLNizIl8jq964 L6OD/sb9np4e+Y55GTXki/Blf0zwPf3ydXOTk5Oe56k304c2Lt8229fXp14726xzAgBVSTas lMvlmZmZEaOJiYmEjg1LTSbGrKhX4+vfIJiz/i7D4Dcg6t/LI1OI+r5iX+O+mYQVAFmRYFiZm5v7/ve/v8rCQw89VC6XY+y97zLQ0dFhOXRxZGQk+DUoUe0Hp5FO6XzPiv qbMzg4mNO+QigX4FmEldCZ8j7R5OSknKi2cQBIuQTDykMPPWST VKQHHnggRl4J/kaWv7ItV4yxrWr3EI2U8rDieZ68dyMHkej9HKELh04He1a8hXt DcrSKvOMT2jg9KwAyKsGwct1119mHlVWrVj3//PPV7r3+C3dyclL+slbf/up53sDAgPzl3traOjg4qK+l/4szn8/LdXOLnyyNunLk83n5/fU5rVcfTZfO96z4YoEaYiIHwPb19ckhKbKrr2JYCY5Z0RfILQx eCW1cjVmRjRBWAGRFgmGlqqQivfbaa1Xtve8XrhpdKH+Uve46e cUKhhWVPCTVQtSVQ15vFNWxj+YyjFlJz9NAMmTI9KCe61E3JSu GFbVWS0uL/piPDCJ6Ug827nnehg0bWlpa5D4QVgBkRbrCyt///d8XCgX7TQR/4epzZASRAUU+hdHR0RG1oiT/GVrxaqH/Exbpkc7bQACAGqUrrKxatWrNmjX2g1fMYSUXIMcehq4o30uhul iiWpPT6g0W7e3tqh8eTZfOp4EAADVKXVhZtWrVU089ZbkJX+bw 3QYKhpXQ5OF5nnz4U73QomJY8Tyvp6dHvl/L182OJooas9Lc96wAAGqUxrCyatWqU6dO2WzCFyB8t+3120DmF eWt/Xw+r4a5BBeLunMUNR+Nx20gAHBSg8JKOdru3buDYeXmm2+2uRk UeqNHDSUJDrBVXSAyneQWRrHoA2ajHu/Up30DculZSQluAwGAk1IaVlatWrV169aKm/BlkeBL4fr6+mQQaWlp0R+UGBwc1B+UyOfz6oaOvBMkF44KK5OT kx0dHSqp8OhyStCzAgBOSultIKmqJ4OAqLDS3C8yBADUKNVh5d FHH03uyOGe0AG2Vd0GGgYANJbNL+dUh5XVq1fbbw5gzAoAOKlB YcUwZiVIXzG5I4d7DLeBCCsAkF2EFbiDnhUAcFKqbwMRVlCV2s esAABSKNthJfg2NvP72Zr49jb1fHWzdiCU/mC25ZKGOU1HzwoAOImw0gj6dlN4jfcIKwCAFGtQWElozIrhCio nfJ0ZwenQxbxAR0i8RiruZHBDoa3FW8D+hOgv1ova7WqPwjzTZ vUYGGALAE5yOawEo0bohOFTT7uch240NDdU3ElDU8HWKu6zzf5 XXNJ8mObjMmQjw+bMS8YTNWaFl8IBQKY5exvI3LsQ2oL9ur52z JfbGGEliQUqpofgYZqPwpDPbJZsQFjhdfsA4IYlF1Z8txsIK4b DNB+Fr0HfidVnWv6hBFuoFmNWAMBJSy6sVLVYcGZdwkq8noY0h 5W67EPtQm8DMWYFALKuQWEloTErnsWV27O4NtvMjDFd407WdwH LExJ1CLGPIrRnpWJ3SzxRY1boWQGATMt8WPGi70EEp4MzDRddy zYN0xV3MnR+7WFFb9Y+rNh0ddgfhd5mcMei9jb0WOxxGwgAnJT t20BIQo3dG3XZSh3DCgNsASDrCCtYJNGkEuzvqe9uRIUVxqwAQ KYlGFZuvPHGGpPKjTfemNyRwz3cBgIAJyUYVl588cUaw8oLL7y Q3JHDPYQVAHBSgmGlXC7v2rXrpptuihFTbrrppl27dpXL5eSOH O4hrACAk5INK6dOnTpw4MBLL720Z8+ePXv2vPTSS77pgYEBNUf NfPHFFw8cOHDq1CnCCqrCAFsAcFKCYWV6evqVV1555ZVX9i924 MABwxy5ipwzPT1t3kToM7RVLd8wSWw6F2C5OfPDyfYLRy3ZrPP Me1YAwEkJhpWRkZFDhw4dOnRoaGhoaGhoeMHhw4fVf3WHDx8+f PjwkKbil89lJawE3yxSx2bNcyxX1D8KfS1Kjc02BreBAMBJCYa VowtGR0ePLRgbGxsbG9OnFX3OsWPHRkdHR0dHzZswXK1VPjC/Qi10MU/rtIha0aaR0MV8mwg2aJ8PKh5+VJuGPhhzWAndveCBmM9b8HRVF YkMuA0EAE5KMKwcP358fMGJCCdPnpT/leSSckIyb8J8tTZcOy0X88JyRuin5jsghkZsIlEUm7BiiAuGFo L/tWnKfusVDz8eelYAwEkJhpVTp05NLqjqdftqrampKfMm7LsW9I mKfQwV17W5isfeRFQ7QbkAc5u+Tyt+VFVYCZ1Z1WESVgAAoRIM K6dPn56ZmTl9+vTp06erCitnzpw5ffq0/K95EzHCStRF3Wbd0P9GLa/PCeYJ8+75djKKYbu+j4JHHbUJ82HaH4jNp+ZDiIHbQADgpATDS mHB7OxssVgsFotyYnaBmg7OLBaLhUKhWCyaNxEjrFS1WHBmvLB S7e5ZMgcUw/KGLVoepnmjqQor9KwAQNYlGFZmZ2fPhpmbm1P/rajiVmyufHUJKzGmgz96YQnAMvQE2YQV+zBRcZka229iz8qRI0 cqPlkGAEitBMPK3Nzc3NxcaYE+bUMub7Oh0JsalpdJw4XTsk3D dPBH386E7oNvu4ZLuH3HkqHNqB22bEqfaV6liT0rhBUAyLQEw4 qePKoasyIvNnIiuSNPD/NFuvZL+NJBWAEAJyUYVvS0oabVf31ZRJ+jp5Z6HmuaBPsbDEs2 ZpccQFgBACclGFa8xXnFW0gqnkWOqc/BYYkJDSs8DQQAWZdsWAEayRdWCoXC9PQ0TwMBQNYRVuAObgMBg JMIK3AHYQUAnERYgTuixqwcOXKE20AAkF2EFbgjOGaFsAIADiC swB1Rt4EYYAsAmUZYgTsIKwDgJMIK3MGYFQBwEmEF7mDMCgA4i bACd3AbCACcRFiBOwgrAOAkwgrcwXcDAYCTCCtwB2EFAJxEWIE 7uA0EAE4irMAdhkeX+W4gAMguwgrcYfgiQ3pWACC7CCtwR9R7V rgNBACZRliBO0LDihyzwm0gAMguwgrcwdNAAOAkwgrcwXcDAYC TCCtwR9RtIJ4GAoBMI6zAHbxnBQCcRFiBOxizAgBOIqzAHbwUD gCcRFiBO7gNBABOIqzAHYQVAHASYQXuIKwAgJNcCCv79+/fvHnzunXrNm/evH//fvPC69atW7duXcU2LRdDqjBmBQCclPmw8uyzz65b7Nlnn232Tq E56FkBACc1J6yUy+WJiYljx46dPXu2lnaOHDki08np06c9zzt9 +rTMLkeOHJELyPhy+vTpzZs3P/XUU16gy+TYsWPyo9OnT+sfBadPnjz51FNP6ZtD2vDdQADgpCaE lVKpdPz48aGhoaGhoaNHjxaLxXK57HleuVyeXSDnVCTTw9TUlJ ozNTW1bt06mUu8hZwhDQwMeItTyMmTJ9Wn8kaSIazQeZN+3AYC ACc1NKzIODI6OjqkGR4enpmZKZfLhUJBzSwUCjYNho4sCeYMOZ ClWCz6PpXdMIcOHfI8b//+/eaw8sILL3havqnlPCAhUbeBCCsAkGmNCyvlcnlmZmZ4eHhoaGh sbKxUKpVKpWPHjsl0curUqenp6YTCiowp5k+LxaI5rKhGCCupF XobiJ4VAMi6BoWVUqk0Pj4ug8iJEyfUXZ5yuXzixAl1S0h1uli GFXkb6OTJk2qO7Pnw3QbSV4kdVkJbQKowwBYAnJR4WCmXy2fPn lU9KNPT095CL8vk5KRMLapPZXR0VOYVy7CiBtjKYStTU1OhA2z 1VWLfBgptAanCdwMBgJOSDSvlcvnMmTMjIyNybIqMIOVyOZ/Py3Ry7NixUqnkeV6xWJR3iEZHR48ePWoZVrxKjy6bw4rMOpLsp CGsZBoDbAHASQmGFfl88uHDh4eGhkZGRuRTynNzc0ePHtUH2B4 5ckR+VCqVZLfK0aNHT506ZflAkGd8KZw5rHjVPLpsaBMpQVgBA CclElbK5fLc3Jx6PnlsbEwmj2KxKLOLz+HDh32dLiMjI+Pj43N zc4kevIwd8qUpcrDL5s2bE90iEmV4zwq3gQAgu+ofVsrlcrFYV N0ncjhtuVzWH/YJpV6XMjU1JfPKsWPHCoWCfRdLtV544QXfLaSKb+tHmjFmBQCc VOewUi6Xp6am5OgTfTiteuTHbHx8XO+DGRkZOXr06MTERHJ5ZW BgQMYUm+8VQspxGwgAnFTPsDI3N6eeTx4eHp6dnfU8T3+Zig01 5HZubm5kQe0v5sdSwHtWAMBJ9QwrY2NjMnAcPXpUBo6zZ8+qXh Z7ajSuHMKiIkuDTgkyi/esAICT6hlW5Ija48ePy7s2hUIhdDitDf0558nJyZGRkePHjzfo lCCzeN0+ADipnmHFJ15M0VXchG94bA3nIbL9xqweuiTPSFeLAb YA4KTMhxXDj7VrYlghpsTAmBUAcFKjw8rhw4fHxsZeW+zIkSN1 CSu+Ob4eF99Hvmn1X8NiUa+Yi3rvnOXqwQPRF/YtEGwnuOdLtkuG96wAgJMaHVZCrxknT56se1iJiiOGT4PrmoOO eWbFnGTOFlW1U3HhJYKwAgBOanRYCe2Nn5iYaEBY8RanlmCPha GRqKBT1XararPiYvYLLB0MsAUAJxFWagor6zTmdiyXtDyQqhZY OgwvhaNnBQCyKxW3gTIaVuLNDN15wkpd8J4VAHCSU2HF5rJd1b R9lOE2UBrw6DIAOCnzYSV4eyX4qW+m/XToHZ/gJqKWtFw9aueD+xDaDmFFMfSsMGYFALIr22EF0PGeFQBwEmEF7 jA8ukxYAYDsIqzAHQywBQAnJRhWQt9Le+TIkeCSsV8KB+gIKwD gpATDyvT09FTA9PR0cMlisTgdpn6HiSWBp4EAwEkJhpWZMGfOn AkuOTs7ezpM/Q4TSwI9KwDgpATDypkwhUIhuKQcCxlkvy3Do7+Wy8MBUU8DEVY AINMSDCvFMLOzs8El5+bm5Eezs7NqsdAloxBW4NGzAgCOSjCsz C44u1hwSXlpCbLfVsWXqlV8kVroYl7gJWzxGkFj0LMCAE5KMKz MRQguWSqVLJeMYg4rwagROmH41FscRwyfRr15Fg2gkgo9KwDgk gTDSilCcEl1gam4ZBTL19UHu1tCW7Bf19fOEn/bfdNxGwgAnJR4WNGDiLyQBJcsR7DfVoywYvMNO4SVbIkKK7xuH wAyLcGwYh9BmhJWqlosOJOwkkK8ZwUAnORIWPHifp1yjLASYxq N4QsrfDcQALgh1WElRl4JfZwnOF3VyFnLNg3TaIyonhVuAwFAp jUurKg5oUvqE/rydThELBmEFQBwUuJhxVucRcypxbcYUBXCCgA4qc5hhZCBJjKM WWGALQBkV4I9K0CDhfasMMAWALKOsAJ3RIUVbgMBQKYRVuCO0N tAvGcFALKOsAJ3MGYFAJxEWIE7DGNWCCsAkF2EFbiDR5cBwEmE FbiDsAIATiKswB1RA2wJKwCQaYQVuINHlwHASYQVuCPqNhADbA Eg0wgrcIfhNhBhBQCyi7ACd/BSOABwEmEF7uA9KwDgpKrDStlayc5cJWeNZiMUjQoRzkQ4HWEm wnSYqTCTYU5FmAhzMsyJaONh8mGOh3ktwliEYxFGIxw1GolwJM zw8PDw8PDhw4eHhoaGhoaa/f8aACAmwgphxfGwMjw8TFgBgEwjrBBWCCsAgFQjrBBWHA8r3AY CgKwjrBBWHA8r9KwAQNYRVggrhBUAQKoRVggrhBUAQKoRVggrh BUAQKoRVggrhBUAQKoRVggrhBUAQKoRVggrjocVHl0GgKwjrBB WCCsAgFQjrBBWCCsAgFQjrBBWHA8rjFkBgKwjrBBWCCsAgFRzI ax4bcu8tmXlB1fYhJW5/GD5V/+i0olct2JYkYvJgDI7tr/UcxthJSthhdtAAJB1yYaVEydOnHvuuZdccslnPvOZ/v7+/v7+6enp+oaV0themSS8tmWlsb0Vw4ovncToWdGDC2GFsAIASFo jwor0+OOPv/e97z333HN/7dd+7fLLL//Upz513XXX3XTTTZ2dnePj47HDSvml+722ZeVf/R+vbVn5pfv1sDI3sqv84AqvbVnpxfv0pKJK71mZGx3w2paVeu9 UAaXUe6fXtuzs6B69Z8XXQvln/9NrW1Y8eWxmZqZ48picQ1ghrAAA6qhxYaW7u1uGlVCf/vSnH3744Thh5cEVXtuyualx352guWN79VRROvBLc1gpFArlzV/12pbpt37KD3zedxvI10Jpd4fXtuzsUO/MzMzZoV45h7CSqrDCmBUAyLrGhZUdO3a8+93vjgor0sUXX9zb2 2sfVkqvvey1LSv33T07O1vuu9trWzY3flCGlfK2b3tty+byg2d Pjnhty8qbvxZ6G0j/sbT3Ua9t2dzBp8+cOTN38GmvbVlpb1dwzIo+PR9QnrtjZmam9N wdKrgQVtITVuhZAYCsa2hYueCCC8xh5dxzz73gggv27dtnGVbK +x732paVRnbPzs6WRnZ7bctK+x6TYUVGiopjVvQfZ08d99qWlb fefObMmfLWm722ZbOnXjOHlflbP/d/fmZmpnz/5722ZYxZIawAAOordWHl3HPPveaaa2zDyhP/4B9E8sTXYoeVQqFQ3nmb17Zsbvh5lVrMYWVmZqb85D/LDhWvbVn5yX8mrKQtrHAbCACyLo1h5bOf/axNWJk7NepLKrLmJo6+fhvo2N7520APrrAJKzKmzLcz/LxNWJnb06lG2s7t6SSsEFYAAPWVbFg5evRojLBy2WWX3XHHHdu 2bTOHlfl7QEM71aDa0tBOdSfIP8B24YEgOSDXa1tWev7O0Pesl B/4vD60NhhW5AJe27JS7w9nZmbOjryotnJ25EXCStrCCreBACDrk g0rhw4dihFWlJtuuskUVp74B9WPMv8E0MRRdSco9NHlYrE4d2y vnFne+S+hYaXU/xOvbVmp/ydRYeXs0ZdkXin13CajiQorvGeFsAIAqLsMhxUpDa/bl8NW5DNBhJW0hRVuAwFA1jUurOzatavasHLPPfdkKKzIh5YJK 4QVAEB9NS6s9Pf3VxtWenp60h9W5KPL8l1whJUUhhVuAwFA1qU 6rLz22mvpDyt8NxBhBQCQqPSGlQsvvNDmdfuEFcIKt4EAwG3pD Suf/OQnCSuEFcIKACDZsLJnzx5fWLngggv+5m/+5t/+7d9++MMf3n///b2af/3Xf9XDyte+9jXLsJLL5cxhJZfL+SaaHlZyuVwul2tAWMnlcuaw ksvl3A4r3AYCgKxLNqz09/frYeV73/vemTNnSoupN9Xu27dPDyt33HGHTViRSSWYV0LDSkp6VmRMaUzP ijmsyMxEWAEApFnjwsqePXtKYfSwsmPHjt7e3vvuu+/GG29UX78cI6zIa7BKKupHvWdFzVdJJZfLnTlzRs7Uk4paMhhWc rnczMyM/FQPK2oVlVRkQMlp9C6WXC6nkkoulzt16pTvv3JiYmJCTuthRbW ghxU5Rw8rasLXp+J8WOE2EABkXePCyqFDh8xhJUq1YUVOh9790 Sf0jKImVEzxTahoEgwrKqboE3pGURN6QFETekZREzKa6DFFTau Aoib0gKImVEDJLfnbQIQVAMi6bIeVYEbRw4phzEpUWNF7U4JhJ apnxTKsBG8DRYUVdd/HN633ptiEFcascBsIAByQ+bCiSyKs2NwGCoYVXdJhRUdYIawAg HsyH1aS7lnRB9gG80rFnhXfmJVEe1b0LhbCCmEFAJyRbFjZtWt XcmEll8udXfyelZw2fiXemBXzbaDQsJKzHrPCbSDGrAAAYkg2r OzYsaPxYcX3NJB6IMjyaaAYt4H0yGJ+Gij46LJa0vc0kGVYMT8 NJEU9DbREwgo9KwCQdRkOK1Jz32Dryyj2L4XjDbaEFQCApcaFl bGxMcIKYYWwAgCoVuPCyokTJ9wLK6FJhbCSqrDCmBUAyDrCCmH F8bBCzwoAZF2yYeWVV165bsH09DRhhbBCzwoAoFrJhpXR0dEf/ehH//7v//7jH//4TOArDAkrhBV6VgAAFSUbVg4cOPCP//iP3/jGN77xjW/MzMwQVggr9KwAAKqVbFgZGhr67ne/29bW1t7efvr0acIKYYWeFQBAtZINK0ePHr3zzjvvuuuuH/7wh/SsEFboWQEAxJBsWHnttdcefvjhRx555JFHHpmamiKsEFYIKwCA aiUbVsbHx7ct4DYQYYWwAgCIIdmwMj09vXv37hdeeGH37t2FQo GwQlhhzAoAoFrJhpUzZ868uqBYLBJWCCuEFQBAtZINK8VicXR0 VF6xZmdnCSuEFcIKAKBayYaVs2fPyqvpxMTE2bNnCSuEFcasAA CqVXVYafYOA5F8QblQKMzMzJw8eXJ4eHhkZKTZewcAiImwAnf4 wkqxWJRh5ciRI0ePHm323gEAYiKswB2EFQBwEmEF7gi9DTQxMU FYAYBMI6zAHVE9K8PDw4QVAMguwgrcSiGHmAAADhFJREFUYQgr DLAFgOwirMAdoWFlYmKCsAIAmUZYgTuixqwQVgAg0wgrcAe3gQ DASYQVuIOwAgBOIqzAHYxZAQAnEVbgDsIKADiJsAJ3cBsIAJxE WIE7CCsA4CTCCtzBbSAAcBJhBe6ICit8NxAAZBphBe7gNhAAOI mwAncQVgDASYQVuIMxKwDgJMIK3MGYFQBwEmEF7uCLDAHASYQV uIMxKwDgJMIK3MFtIABwEmEF7iCsAICTCCtwR+iYFW4DAUDWEV bgDsasAICTCCtwB+9ZAQAnEVbgDsasAICTCCtwB2NWAMBJhBW4 gzErAOAkwgrcYbgNRFgBgOwirMAdUa/bZ8wKAGQaYQXuYMwKADiJsAJ3MGYFAJxEWIE7eM8KADiJsAJ3E FYAwEmEFbgjaoAtYQUAMo2wAncwwBYAnERYgTu4DQQATiKswB3 cBgIAJxFW4A56VgDASYQVAACQaoQVAACQaoQVAACQaoQVAACQa oQVAACQaoQVAACQaoQVAACQaoQVAACQaoQVAACQaoQVAACQaoQ VAABqUh78CBW7bM4wYQUAgJqUXr2Mil02Z5iwAgBATZp+vc902 ZxhwgoAADVp+vU+02VzhgkrAADUpOnX+0yXzRkmrAAAUJOmX+8 zXTZnOMNhpb+//8RPP9DsvQAALHVNv95numzOc***yo7t239w++1Xr/jCwBM3NXtfAABLXdOv95kumzOcvbAyNDR0zd/+vys+ffHGe++de+6aZu8OAGCpa/r1PtNlc4bTFVbKM8OlwTtL+26be+6aueeuKe27rTR4Z/nUHrXArbd85we3377iL/7kwR/8/cZ77010ZwAAsNH0632my+YMpyWslPO/mnvumrknPhheO1eUR3/ued7Ge+/9+Mcuv+7aL191xZX9/f0J7QwAAPaafr3PdNmc4VSEldK+2yJjilYrPn1x7sKLrl7xBV9 S6e/v37F9+47t2+WPExMT+o8AACSq6df7TJfNGW5yWCnPnprbucImq Xz+T9/9+T99d+7Ci2Re0Ru5esUX5Hx5Y2jH9u3yR8t9mJiYuHrFF3xtA 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 a6+/SAix92cXqzknnvvw2usvOvjL5fLH+bCy8Onen118zV//phDimr/+TX2t0ac/dMO175ALr73+otGnP6Q+6nv4A6GrJF02Z7hpYaU0/MDrfSpPXVmePfXYo48GR8XqKeGH/3Tp6+FG61yRy9x6y3dkXvmnb/wvlUtUBNmxfbvsFPn4xy5Xbd56y3c8z7v1lu+ocLPx3ntl7tl4 7707tm+XweWqK66Uq1x1xZVDQ0P68gCku+66681vfvO2bdu2bd sm88rIyEizdwpokNKejyZd81nEboG9j/2R79q997E/kh9d81e/pc+/4Zp3RK1ysPuSBhxXac9Hbc5w88KKNlqlNPyA53myq0PeoJHLqD 4SGUFOvvqEnm9UUyqs/OD2233dJHJFudjExIS63aMGuHiep9ZS0zLEeJ43NDSkryLnM8Y F0K1YsUJ1qLzlLW/5jd/4jTdrrrzySm4JwXmlXR9NuuaziN0CN6x6hxBi4y2/V9r10Y23/J4Q4oZV79AXO7H9Ut/qcpWDj19S2vXRg49fIoRYd+O7G3BcpV3pDiv6oFo5R4WAq664U uYV1QWiHtXRHx0qz56SM+ViP7j9dm8h8aiOEz2s+JKHalPvKTG vIjdBWAF0b64k6m6puPxBWfXdn6oaDN0H9aO5qbrvee3NqsOp5 dwmdFw227XcZ8s/oEYqPfuxpGs+i9gt4FtY//GR9vfN96n899/5xe1/4FtGd+Xl5zfguErPfszmDKcgrGivzFedHFev+ILeraK6OvQ3sp Tzv5Iz9W4PeR9HjTVRq6t7OvIpZT2sqI0ODQ2p1fVV5Dvo6FkB QslEUg5jCCv6Zaa+lxz71qL2wbKFdIaV2ltrSgKo6vynJ6MopR 2XJ11rr3uXEGLvxuVqzoknLlt73bsOPvgh+eN8IglMB3/8xW1/uPa6d13z2d8SQqy97l36Mj4NOK7SjsttznC6woqn9abIASj6/RrPGFZkt4enda54nqfGr6g2+/v7fWFFPT0k44hhFXpWgCAVVq644grVm/Lrv/7rMzMzUWHFfE0N/gtbTuszDTnDt1jUP9YN+xA1UXGvDBs1HJS+QOiO2av2xAZnVjy BobtdY3qo+GcRtUvV/rWp4z77lLZ+POnqu+MSIcSVH3n7wZ/836WtHz/x2MduuPoiIcQNV18kF5iPF1s/Xtr6cfnRxv/9vtLWj2/83+/TF9MruIpsvMFlc4ZTF1bUnRdV+ncA6U87q7AiH05Wi8nnfVQW2 XjvvfLHf/rG/xoaGlLLq94ab+HJ5KtXfEHGkdBV5IPNnufJ7MJL5AApRs+K4To RmkKCMcXwD/GKgcZ+Hww7YJhpuScV24zBJoHZz7Tf7dBN12u3K4bIqna1Xvvs U37yTxpQG298b/CifKjjUvmp/FFOv/yjD0UtdsPVF+rz267NRa2iPkq6bM5wCsKKNlRW0vs29G4Vzzdm JeylLAAarC49K6Ef2VxTq708V7UPtVzpozZRcckar/q+Mm8ixh4mtNvx9qHGP6A6asxFvfzkn3S3v3/1Vf9RXo7X/8PvqQjiCysyfMglV1/1H1/+0YfU/JOPfnT9P/yeiiPHHrpMfdTzrxfLVT7zkbdvvPG9DTsomzPcvLCifW2h6iOR 9M4VvVulPDMcGnGmpqaKxWLUhsbHT4yOHjMsAKAWjelZiZqZlb ASDBBJX/WDHU5RISYq1tjMDG2zlt2uah9q/LOIvcNBDbuuO1k2Z7hpYWXR62sX3wnytJEr+q+5RU87ay+R27W 7f3z8ROhW9gzs3fxE967d/XsG9sbbz127eUctYOLrWWlpaYkRVmLHgjqGlbr/w73pXRRVNVtjAqhFg8OKeWY8Tb/eZ7psznDTwor5Dbbym5P1l9kveonc4ntAMpFseXLb+PiJLU9uk 3NGR4/JCZU2nnmud2pqav+BV4cOD295ctv2p3c+81zv9qd3bn96Z7FYf Oa53i1PbpO5Z9fu/i1Pbnvmud6hw8MbO+6XM+UqxWJxz8BeuWS9TgWQafV9GijqqhP jClTVtariRdF+ZrXt2OyqJcuwUm0UqDizxt02N2uTUWrPiDVq+ vU+02VzhpsWVrzFj/bIvKJenVJxSf3TXbv79x94dc/AXpk8hg4Pb36ie2pqyvO8YrG4/emdDzz08P4Dr8rFtj+9c3T02MaO+8fHT3R2PT46emzLk9tGR4/Ju0UbO+4fHT3W2fV4sVjc2HG/53nyv1ue3DZ0eHjX7v5du/sfeOjhYrEY1ZcDLDWhYeXMmTN33nlnvPesRN2YCC4cFUF84cBw TQpdIOpaaL9XUTNDG/etVcew4oVd+CvurfkE2hxs7J2P+rOI2kPz0ZkDUB2TikdYcTus eIsHzMqRKKXBO1WvSXlmuDT8wNxTV/qW8WUa2Y8iY4eMI5uf6NYXGB8/IdPJ9qd3dnY97mkRxFsIIp1dj+/a3S/DipzvCyvbn94p+2nkpwAkX1g5e/bs5s2bL7300vPOO88cVuxFXVfqe72JsQNIWlbOfNOv95kumzPc 5LBSnj3lzyvm2vLH5VN7fI3s2t0v+1Seea5X9ojot36eea531+ 5+mVE6ux5/5rleLxBW9gzsjQorDzz08J6BvfKG0TPP9Y6Pn3jgoYd37e6X7Q Co9g22ehcCFVUx/iCavs8Z3e0Y+xzU9Ot9psvq70lzw4on84r2ZJCpdq4IfVx5amp qdPTY/gOvyh83P9Gt7tEUi8X9B17df+BV+TSQ7ETxPE+OaJGLjY+fKBa Lo6PHhg4Py+eG5Hy5jJwv25HrTk1N7RnYy20gQPqLv/gLQ1L5xCc+wXcDwXlNv95numzOcPPDihRyu2dxh4r+NcsGsv8j 9CO6QwAASWj69T7TZXOG0xJW5v+8R39e2nfb3HPXqCrtudn3Fh YAAFKl6df7TJfNGU5XWAEAIHOafr3PdNmcYcIKAAA1afr1PtNl c4YJKwAA1KTp1/tMl80ZJqwAAFCTpl/vM102Z5iwAgAAUo2wAgAAUo2wAgAAUo2wAgAAUo2wAgAAUo2wA gAAUo2wAgAAUo2wAgAAUo2wAgAAUo2wAgAAUo2wAgAAUo2wAgA AUq3qsAIAANB0hBUAAJBqhBUAAJBqhBUAAJBqhBUAAJBqhBUAA JBqhBUAAJBq82EFAAAgtf5/uqS01J3hohgAAAAASUVORK5CYII=[/IMG]
Whitster is offline   Reply With Quote
Old 03-14-2015, 02:48 PM   #147
Ice_Man
Ice_Man's Avatar
Drives: Toyota GT 86
Send a message via ICQ to Ice_Man
Hi guys,
i have a problem with the connection to my gt86....
i downloaded the latest techstream ( thanks by the way ) installed it like in the desription an ordered an minivci-cable. now i could not get connection. the programm wants to connetct to a vmi??....
i hope you can help me with this problem! ;-)
my system is a i3 2,4gHz cpu 64bit with windows 7....
Ice_Man is offline   Reply With Quote
Old 04-18-2015, 05:08 PM   #148
eddieflyinv
eddieflyinv's Avatar
just a heads up.. AVG detected a trojan inside that MVCI driver download linked for the newest techstream update (10.blahblahblah), not initially, or when attempting to execute the file (because 64bit windows 7 cant install it without doing it manually) but when i extracted the msi into a folder for the work around install on 64bit.. soooo me personally - not using that file. id imagine when it works for a 32 bit system youre just throwing that trojan right into your computer to roam around and do shit.. like trojan virus type shit lol
eddieflyinv is offline   Reply With Quote
Old 04-20-2015, 10:51 PM   #149
redlined600
redlined600's Avatar
Drives: Fr-s
Maybe someone can help.
It claims to connect to the car but I need to manually input the make, model, year and engine.
For some reason it's not connecting properly.
When I go to Chassis>VSC/ABS/trac gives and error (paraphrase); system not available or not functioning.
Any thoughts?
*edit:
I played with it a bit more and if I run the firmware update tool it shows the cable connected but when I launch techstream it's not connecting to the car.
Also it's not just abs/vsc/trac, nothing is available.
redlined600 is online now   Reply With Quote
Old 04-22-2015, 10:47 AM   #150
fika84
fika84's Avatar
Originally Posted by Ice_Man View Post
Hi guys,
Do some searching and you will find some threads in the toyota 4runner forums about how people installed this on 64 bit machines. I've installed it on 2 windows 7 ultimate 64bit laptops without much issues. You just have to manually install the driver and use an appended 64bit registry item. Look here. It's pretty much step by step.
First link after searching "Techstream install windows 7 64bit" - LINK
Second link after searching is on this forum - LINK
They're the same thing and they work.
fika84 is offline   Reply With Quote
The Following User Says Thank You to fika84 For This Useful Post:
Old 04-22-2015, 10:54 AM   #151
fika84
fika84's Avatar
AVG thinks a lot of things are trojans.. don't always trust it. AVG will detect things as a Trojan if they patch other programs (assembly or registry entries). Any application that isn't signed by a reputable author will also cause it to think that.. meaning any program made/modified by someone. Use your judgement. If you trust the source it is coming from than tell AVG to ignore it. If you don't trust them, let it "protect you"
Old 04-22-2015, 01:13 PM   #152
1st86 Driver!
For all you folks that have played with TechStream, does it allow you to recalibrate the speedometer to adjust for different size tires?
Old 04-25-2015, 09:44 PM   #153
davesrave
davesrave's Avatar
Drives: 2014 Boxster S; 2015 Macan S
I didn't see anything like that.
davesrave is offline   Reply With Quote
Old 05-01-2015, 12:23 PM   #154
Whitster
Drives: Highlander
Anybody know if Techstream works on '16 Kia Sorento?
Does anybody know if Techstream works on '16 Kia Sorento?
I'm trying to enable DRL's on the USA version. The Canadian and Euro versions already have the DRL's. I was hoping it might be optioned away in the CPU somewhere and the Techstream might be able to access it. The LED DRL's are already in the headlight assy, but only come on when parking lights/tailights, etc., are on. The "Auto" position on the stalk only controls the headlights on/off during daylight.
Kia is not cooperating at all!
Thanks for looking!
Search this Thread:
Advanced Search
TPMS Tools developer Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 27 10-04-2021 02:28 PM
anyone with a shop or tools Tylub Southern California 0 05-14-2013 12:03 PM
Tools? Gost Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 35 04-03-2013 04:46 PM
Tools for DIY maintenance? F1point4 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 19 08-08-2012 08:47 PM
