Old 05-01-2013, 02:33 PM   #15
kvnchu
Drives: 2005 S2000
Lowered ~2 Inches
Alignment:
Front:
Camber: -3.2
Toe: 0
Rear Left
Camber: -2.8
Toe: 0.2
Scion FR-S '13 - Track Toy
BMW M Roadster '06 - Track Toy
Suzuki GSX-R750 '07 - Track Toy
Lexus IS350 '07 - Sold
kvnchu is offline   Reply With Quote
The Following User Says Thank You to kvnchu For This Useful Post:
CSG Mike (05-01-2013)
Old 05-01-2013, 03:45 PM   #16
currently:
lowered 2.375 inches in the front, 1.625 inches in the rear
-3.2 front camber, -2.5 rear camber
0 toe all around
dsc_pat (12-11-2021), stock (08-31-2016)
Old 05-01-2013, 03:47 PM   #17
ayau
Drives: Some rust bucket
currently:
0 toe all around
How much shock travel do you get on those SRCs with that much lowering? Or is the ride height adjustment independent of shock travel?
Old 05-01-2013, 04:00 PM   #18
No indication of bottoming out the front yet. Did rub off some fender liner, but not touching the chassis like Robi is.
We never actually did explicit measurements until Robi measured it...
Old 05-01-2013, 04:02 PM   #19
ayau
No indication of bottom out the front yet. Did rub off some fender liner, but not touching the chassis like Robi is.
Does the front allow for more lowering without "messing up" the suspension geometry compared to the back?
Old 05-01-2013, 04:06 PM   #20
Quite the opposite... but I was messing with rake to see how it affects aero, subjectively.
Last I saw Robi's car, he actually ran the opposite from us, where his rear is lower than the front... our car was 3/8 lower in the front and 3/8 higher in the rear than the Robispec FRS, by his measurement, when he last measured.
And yes, the SRCs run a shorter shock, so compression stroke isn't an issue with the lower drop. Haven't had any droop problems in the front, but the rears will lift over driveways. We really should try disconnecting the rear sway per Robi's suggestion... it doesn't hurt to experiment.
Old 08-05-2013, 02:43 PM   #21
Slick
Slick's Avatar
Drives: FR-S Firestorm 6MT
Front
Caster: max
Camber -2.2 L&R
Toe: 1/8" toe-out
Rear
Camber: -1.8/2.2 L&R
Toe: 0
Eibach ProKit on stock shocks, lowered 1"
Factory crash (camber) bolts
Continental Extreme Contact DW 245/35/18 square on 18x9" wheels
I do a few trackdays a year and instruct also, and I find this setup great all around for DD without compromising grip at the track. I found the middle/inside of the tire to be hotter initially until I dropped the pressures a tad which equalizes the wear (I tend to run typically higher pressures to suit my driving style). Regular rotations between track events so pretty even tire wear now.
Slick is offline   Reply With Quote
The Following 2 Users Say Thank You to Slick For This Useful Post:
86gt? (08-04-2014), Owentdc (04-26-2016)
Old 08-06-2013, 02:49 AM   #22
iLuveKetchup
My VTEC fluid is full
iLuveKetchup's Avatar
Drives: EFF JAY
Wait, what? You can change alignment specs on a BRZ?
iLuveKetchup is offline   Reply With Quote
Old 08-06-2013, 10:09 AM   #23
SubiePig
Drives: -'02 PSM WRX, '94 Miata, '13 BRZ
Camber and toe in front/ Toe only in rear but if you have coils you can use ride height to get the rear camber were you like.
Front:
Camber 2.3
Toe 0
Rear:
Camber 1.75
Toe 1/32 in
Sponsered by:Chasebays/Corr Performance Tuning/KartBoy/Bad Panda Motorsports/Racer-X Fabrication
STX Build thread 14th/67 SCCA Nationals (2014)
SubiePig is offline   Reply With Quote
Old 09-08-2013, 06:18 PM   #24
Dephective
Drives: '13 Whiteout FRS
I'm lowered 2 1/4" all round on Fortune Auto's.
Front:
toe:0
camber:-1.4
Rear:
toe:-.08
camber:-2.5
it's a little snappy till the tires warm up. what's with disconnecting the rear sway? I know that there's very little droop with my setup, but info on that?
Previous:
'01 Accord-daily
'93 Rx7-fire breathing track monster 545hp 397tq 2300lb.
'06 Mazdaspeed6 one helluva love-hate relationship
Dephective is offline   Reply With Quote
Old 09-08-2013, 06:54 PM   #25
ultra
Curious cat.
ultra's Avatar
Drives: 86 GT base M/T - Red
Lowred 30mm on RS*Rs.
225/40/18 Continental Sport Contact 2s.
Usage: 90% spirited street driving, 10% track days/AutoX/drifting.
Front:
-2.0 Camber
0 toe
OEM crash bolts + Whiteline front camber bolts + AVO caster bushings
Rear:
-1.7 Camber
0 toe
Whiteline rear camber bushings
Stock sways.
Impressions: Very balanced and controllable overall. Very capable on street, handles track decently given the mild setup. Crisp turn in and rear end reacts nicely to throttle lifts. Tad much more corner entry underster on tight bends than I'd like when pushing up to the very limit (perhaps die to driver error). No excessive tire wear. Great all-around setup, haven't felt like fiddling with it in 7 months.
If were competing for trophies, or maybe 2% out of the 10% of the time I spend driving the car really hard, I'd really like to try out some stickier tires combined with more camber in the hopes of gaining a little more ultimate grip and front grip bias.
The other 98% of the time I'm completely OK with with it as-is.
2013 Toyota 86 GT M/T
2009 Renault Clio Sport R27 Team F1 Edition (sold)
1991 Mazda MX5 Miata (sold)
2007 Mitsubishi Evo 9 RS (sold)
2006 VW Golf R32 (sold)
ultra is offline   Reply With Quote
Old 09-08-2013, 07:34 PM   #26
Zach3794
Drives: 2013 Scion FR-S, Raven, Manual
Front:
-2.0 Camber
0 toe
Rear:
-1.7 Camber
0 toe
Stock sways.
I'd never thought of that. By what you said there, you're using the Whiteline bolts on the bottom, and the factory crash bolts on the top strut mount to get even more camber adjustment? Is there room to add even more past -2 with this configuration?
Zach3794 is offline   Reply With Quote
Old 09-09-2013, 01:52 AM   #27
ultra
Curious cat.
ultra's Avatar
Correct.
Can't really comment on whether or not it's better in terms of range (my alignment guy would know better) or even recommended but it works for me.
The Following User Says Thank You to ultra For This Useful Post:
el-92 (12-23-2015)
Old 09-09-2013, 02:09 PM   #28
Slick
Slick's Avatar
To get extra camber from my crash bolts, I just stretched out the top hole a tad (dremel) and then tightened it up. Got -2.2 up front with just crash bolts and Eibach ProKit (1" drop).
DIY Alignment FRSFirestorm Suspension | Chassis | Brakes -- Sponsored by 949 Racing 39 10-03-2013 06:29 PM
Big O For Alignment? djliquidsteele Suspension | Chassis | Brakes -- Sponsored by 949 Racing 7 02-19-2013 06:21 PM
Alignment help, track day comin up boonFRS Suspension | Chassis | Brakes -- Sponsored by 949 Racing 1 09-27-2012 05:39 AM
Proper Alignment - Post Eibach Pro Lowering Thatruth2001 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 09-10-2012 02:48 AM
where to get alignment? FML Hawaii 2 08-08-2012 02:36 AM
