Old 08-01-2013, 09:54 AM   #43
TrogDor the Burninator
TrogDor the Burninator's Avatar
Drives: 2013 Hot Lava FR-S 6 MT
For those on adjustable ride height coilovers, I'm curious of everyone's opinions if daily driving in a lowered position is ok with normal driving, but then adjusting ride height to a level position with the differential / axle would be sufficient for Autocross/track days ...
Or are the CVs so brittle that even DDing in a lowered position is simply a ticking timebomb ...
2013 Scion FR-S Hot Lava 6MT Current Mods: KW V3 Coilovers - Raceseng CasCam Plates - Volk TE37SL Black Edition 18x9 +45 - Dunlop Direzza ZIIs 255/35 - Tomei Expreme Ti 60S - FT86 SpeedFactory UEL Catted Header
TrogDor the Burninator is offline   Reply With Quote
The Following User Says Thank You to TrogDor the Burninator For This Useful Post:
Juvenile (08-01-2013)
Old 06-12-2014, 05:25 AM   #44
gonzo
Drives: frs
Originally Posted by whataboutbob View Post
I've got a "click" that seems to be around the driver's rear side. Audible on start of movement (sometimes), gear shifts (sometimes), and hard acceleration (sometimes). Not sure where it is at yet.
I have the same noise and it has been getting more consistent. Was it your cv?
gonzo is offline   Reply With Quote
Old 06-12-2014, 04:27 PM   #45
SomeoneWhoIsntMe
Drives: 2013 Subaru BRZ
I wonder if there's a way to replace the rear hubs with lexus parts so we can use normal lexus/toyota axles. considering they don't shatter so easily, and the diff is the same as the IS300. you'd think you could swap the companion flanges out for IS300 ones if they're not already the same, and then it's just a matter of finding the right wheel bearing to fit a lexus hub.
I wonder if you can press the hubs out of the bolt-on wheel bearings
1jz salvaged brz build thread brought to you by visconti tuning --> Pipe dreams and poor life choices
SomeoneWhoIsntMe is offline   Reply With Quote
Old 06-12-2014, 05:24 PM   #46
Dipstik-sportech
Dipstik-sportech's Avatar
The FRS/BRZ doesn't run a companion flange on the diff side
The Frozen North
Old 06-13-2014, 10:13 PM   #47
whataboutbob
AutoX-10/10ths every run
whataboutbob's Avatar
Mine has been increasing in consistency too, but it hasn't failed *yet*.
[ Delicioustuning | Counterspacegarage | RS-R USA | Cusco USA | SPL Parts | ACE Header | Stark Performance | Infinite Motion | Ciro Racing | Build thread:Here ]
[ GR Corolla Core in White w/LSDs on wish list ]
Old 06-17-2014, 12:29 AM   #48
gonzo
Drives: frs
Have you tried lubricating the cv? I read that it may get rid of it. I'm considering whether it's worth taking the car to the dealer and asking them to do that.
The Following User Says Thank You to gonzo For This Useful Post:
whataboutbob (06-17-2014)
Old 06-17-2014, 03:28 AM   #49
whataboutbob
No, not yet. Currently troubleshooting what appears to be a DI seal failure first.
Old 08-28-2018, 10:32 AM   #50
HawaiianMike
Drives: 2015 Brz Limited
My car started clicking pretty consistently on initial acceleration. Were you able to find the culprit?
I'm pretty much all stock but a tune & e85, but beat the crap out of my car. It does sound like cv joint clicking but not as loud? If it gets louder and I can't visually see anything I may just go ahead and replace them to see.
Thanks!
HawaiianMike is offline   Reply With Quote
Old 08-29-2018, 10:31 PM   #51
whataboutbob
I ended up buying DSS 600HP axles before I experienced any failure. I didn't disassemble the stock ones to see what might have been wrong.
Old 09-01-2018, 05:12 AM   #52
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
Thanks!
Try replacing the axle nuts with new ones installed to proper torque specs. Supposedly the Subaru axle nuts are made with softer metal and may need to be replaced. (much like the wheel studs...)
I replaced mine after scratching my head about this clicking for 20K miles. The clicking went away after I replaced the driver side rear axle nut. After doing some google-fu I found that this was a rather common issue whit other subarus that share the same nut. Repacking the grease with fresh heavy duty grease along with replacing axle nuts may be a good fix if done early on.
Intent > Content
axle, broke, cv joint, drag, turbo
Toyobaru joint project, but who's manufacturing / designing what? VisciousGXR Scion FR-S / Toyota 86 GT86 General Forum 78 08-31-2014 05:28 PM
What if...Honda and Mazda joint together to come up something to compete with 86? 86BRZ FR-S / BRZ vs.... 77 02-11-2013 06:51 PM
Toyota and GM Joint Venture Dragonitti Other Vehicles & General Automotive Discussions 19 03-31-2011 04:34 PM
