Old 07-23-2013, 10:42 PM   #29
Racecomp Engineering
I can for certain trace mine back to a very STUPID thing I did last summer. On the side of the road I turned the wheel fully to the left, revved to 5500, dropped the clutch and did some rather tasty donuts ...... and man was it fun and nice and smoke and "kool". And yes I had axle hop like a mofo.....
Thats when I started noticing a VERY slight knock when taking off NORMAL from a stand still and making a slight left. It was VERY subtle and got worse and worse. Doesn't do it going right.....only left. Its gotten progressively worse and Friday we are swapping out the shaft on the drivers side.
Like all noices I'm prepared for it to be the opposite side and for it to be the DIFF. If its the differential....GAURD here we come !
Myles
Old 07-24-2013, 10:38 AM   #30
nix
nix's Avatar
Drives: AVO BRZ
The amount of people seeing this has got me worried, I my car a bit for the time being!
nix is offline   Reply With Quote
Old 07-25-2013, 02:13 AM   #31
Xauterus
Drives: GTS 86 Galaxy Blue
What is your rear suspension height?
Xauterus is offline   Reply With Quote
Old 07-25-2013, 12:10 PM   #32
frsvr4
Drives: '13 FRS
Has anyone broken the driveshaft shop "600hp" axles? I know they make good DSM parts, but the 3000GT axles they made were weaker than stock.
'13 Asphalt FR-S // 6 spd, 3M bra, BeSpoke, Sportsguy83 arm rest, YoSpeed sills & plaque, P3Cars Vent Gauge +oil P sensor; on shelf: SRP pedals
'93 Pearl White 3000GT VR-4 // 5 spd, stock block & 30+ psi: 10.5@135
frsvr4 is offline   Reply With Quote
The Following User Says Thank You to frsvr4 For This Useful Post:
JordanWho (07-25-2013)
Old 07-25-2013, 01:03 PM   #33
JordanWho
JordanWho's Avatar
Drives: Ford Focus RS & Toyota 86 GTS
I just ordered these. Interested to see how they will go.
Mine will probably go because I'm running a lot of low and the car gets driven pretty hard.
JordanWho is offline   Reply With Quote
Old 07-26-2013, 03:48 PM   #34
jmmay
Drives: Hyundai Elantra
Google crawfords build that was the first thing that broke in there car was the cv joint Im sure someone will make a better designed one that can withstand the power
jmmay is offline   Reply With Quote
Old 07-26-2013, 03:50 PM   #35
jmmay
From what I have read it seems to be close to the same they used in the s2k if that's the case it will be able to hold up to more then it is rated for .
The Following User Says Thank You to jmmay For This Useful Post:
JordanWho (07-31-2013)
Old 07-31-2013, 10:22 PM   #36
JordanWho
JordanWho's Avatar
I hope so.... will let you know
Old 07-31-2013, 10:30 PM   #37
Dipstik-sportech
Dipstik-sportech's Avatar
Two more days till race day!!!!
Old 07-31-2013, 10:43 PM   #38
Turdinator
Seņor Member
Turdinator's Avatar
Is it only boosted or really low cars that are breaking CVs?
1974 TA22 Celica
2013 86 GT
Old 07-31-2013, 10:50 PM   #39
OrbitalEllipses
Drives: Attitude
"Abusive" launches on sticky tires too, couple autocrossers have popped 'em.
Old 08-01-2013, 12:57 AM   #40
WolfsFang
Scrape Master
WolfsFang's Avatar
Drives: Goal: Oldest FRS State Side
its all of the above and what the guy above me said.
You do realize comparing the BRZ to the FR-S is like comparing which hand you love masterbating too right?
WolfsFang is offline   Reply With Quote
Old 08-01-2013, 01:01 AM   #41
whataboutbob
AutoX-10/10ths every run
whataboutbob's Avatar
I've got a "click" that seems to be around the driver's rear side. Audible on start of movement (sometimes), gear shifts (sometimes), and hard acceleration (sometimes). Not sure where it is at yet.
[ Delicioustuning | Counterspacegarage | RS-R USA | Cusco USA | SPL Parts | ACE Header | Stark Performance | Infinite Motion | Ciro Racing | Build thread:Here ]
[ GR Corolla Core in White w/LSDs on wish list ]
Old 08-01-2013, 09:41 AM   #42
JordanWho
JordanWho's Avatar
New axles arrived this morning. Looks strong as fuck. Will be on tomorrow.
The Following User Says Thank You to JordanWho For This Useful Post:
charged86 (08-18-2013)
axle, broke, cv joint, drag, turbo
Toyobaru joint project, but who's manufacturing / designing what? VisciousGXR Scion FR-S / Toyota 86 GT86 General Forum 78 08-31-2014 05:28 PM
What if...Honda and Mazda joint together to come up something to compete with 86? 86BRZ FR-S / BRZ vs.... 77 02-11-2013 06:51 PM
Toyota and GM Joint Venture Dragonitti Other Vehicles & General Automotive Discussions 19 03-31-2011 04:34 PM
