#15 |
Drives: Black frs project
yeah for 3 days prior to failure I thought the brake rotor/pad combo was clicking who'd a thought? I me we drive it HARD but I'm pretty smooth...don't speed shift etc... started taking off "normal" and bang!
#16 | |
Drives: 2013 Scion FRS
#17 |
Motor Sports slut
Drives: 13 FRS, 2011 f150eco boost,
I looks to my that you may have had some grease failure. Robi did you change out the grease to something a little more high performance? How did the grease look? runny like eggs?
#18 |
#19 | |
Motor Sports slut
we use this it's the best. http://www.kartek.com/Product/250/NE...se-Grease.aspx |
#20 |
Drives: red frs
I have yet to truely beat on my car yet, no track days or burn outs, and I have a noise occasionally when I back up then go forward. It sounded like a junk cv but I figured I was imagining it. Guess I better check it out.
#21 |
Drives: GTS 86 Galaxy Blue
Looks like the driveshaft angle is a bit severe. How much is the car lowered?
You might have to raise the diff centre. |
#22 | |
Drives: FBM stage 1 rebadged FRS
My brother said the car squats really hard on launch amd when I shift so I am going to stiffen the coils up and see if it does it again but DSS axles will be happening |
| The Following User Says Thank You to ben15r For This Useful Post: | usptwins (05-09-2013) |
#23 | |
Drives: Ford Focus RS & Toyota 86 GTS
My 86 is set up for drifting which is also slammed with a lot of camber and I also just broke a bearing casing like in the OP. I'm looking at the 600HP rated DSS axles but want to try and lower the diff to reduce any additional strain.
#24 |
Usually it requires cutting the subframe and floor enough to raise the centre , then reinforcing and replating it all. You also have to ensure you have clearance for your tailshaft.
Why does your car need to be slammed for drifting? It is about driving isnt it? Not hard parking? |
| The Following User Says Thank You to Xauterus For This Useful Post: | ATL BRZ (07-24-2013) |
#25 |
This has me nervous about my track trip next weekend. I wish we had $150 used stock axles up here
Sent from my iPhone using Tapatalk 2
| The Following User Says Thank You to Dipstik-sportech For This Useful Post: | JordanWho (07-23-2013) |
#26 |
#27 |
I got my used axles off eBay, and have not had a problem since I put it back in all I did was stiffened the coilovers when I drag race to keep it from squatting. This axle has at least 20 passes on it
#28 |
Drives: Attitude
| Tags |
| axle, broke, cv joint, drag, turbo |
| Toyobaru joint project, but who's manufacturing / designing what? | VisciousGXR | Scion FR-S / Toyota 86 GT86 General Forum | 78 | 08-31-2014 05:28 PM |
| What if...Honda and Mazda joint together to come up something to compete with 86? | 86BRZ | FR-S / BRZ vs.... | 77 | 02-11-2013 06:51 PM |
| Toyota and GM Joint Venture | Dragonitti | Other Vehicles & General Automotive Discussions | 19 | 03-31-2011 04:34 PM |
