#323 | |
Drives: '15 Vortech Supercharged
The plan is to baby it around this winter while I finish all of the shit that should have been done along with the SC kit: radiator, dual catch cans, cam plate, header, stuff like that. Then in the spring it's getting a small pulley and will be professionally tuned on a dyno. I'll check and see if it has the OEM MAP sensor or not tonight. Pretty confident that it probably does have the original one since this is a pretty low boost set up and I don't know they would've needed a different one but I don't know all of the ins and outs of tuning so maybe I'm wrong there. Last edited by jstn; 01-22-2020 at 05:51 PM. |
#324 | |
Drives: 2013 FR-S Argento
#325 | |
Drives: 13' Brz
Reply your thoughts. Thanks! |
#326 |
Drives: Scion FR-S
Vortech supercharger V2 (3.14 pully)
Borla UEL Headers Perrin Catback Exhaust Zeitronix Flex Fuel kit FIC 770CC injectors AEM 340LPH Fuel pump EcuTeck Tuned by HRI Tuning. Run#1 On 93 Run#2 On E85 14 PSI Mustang dyno |
#327 | |
2013 Series 10 FRS #553
#328 |
Drives: 2017 Subaru BRZ (silver)
Hello 86 club.
So, currently my BRZ is running E85 with OFT and I have almost everything I need to finally install my Vortech I’ve had laying around for months now. I’ve just been debating what pulley I want to go with and I read someone mentioned the 3”, but it’s an 8rib. How much of an issue would this be? And if it is a safe possibility what size belt should I run? Also I’m going to be re-scaling the front O2, will I need to do this with the Omni 3 I’m going to be installing? And any other recommendations you might have? Thank you for your time! An idea of my setup: *Engine* - Vortech V3(not installed) - OFT v2 (E85 pop tune) - Omni 3Bar Map(not installed) - Radium dual catch cans - FIC 650 injectors(not installed) - AEM 340 fuel pump(Not installed) *Exhaust* - Speed Factory UEL headers - HKS front pipe - Tomei over pipe - Greddy Evo cat-back *Wheel/Suspension* - Tein Flex-A - Rayz Gram Lights (57extreme) Last edited by BRZ_Mobin17; 06-07-2020 at 10:48 PM. |
#329 |
If anyone has a 2.87” pulley they want to get rid of please DM me.
#330 |
Something something
Drives: 2017 BRZ (Vortech), 1993 R32 GT-R
Well, I just bought this since it went on sale for an insane price.
It's going to take about 2-4 weeks to get here. So question is...does this come with a BOV or nah? (Yeah I gave in to my inner rice unfortunately. I wanted the cool BOV sounds.) I've seen people get a TurboSmart BOV but I'm not sure if that sticks to the stock one (if there even is one). On the other hand, Vortech sells this one - https://vortechsuperchargers.com/pro...ru-brz-systems Just curious if I could save like 350 dollars buying a TurboSmart BOV. |
#331 | |
| The Following User Says Thank You to BRZ_Mobin17 For This Useful Post: | Suzuyans (10-06-2020) |
#332 |
Drives: 203 Toyota 86 gts supercharged
Vortech supercharger issues
Hey guys. Long time watcher first time poster so sorry if this is in the wrong place. I recently installed a vortech supercharger on my 2013 manual Toyota 86. It had a bad tune and was running very rich for a while. Eventually the car started to idle really rough, and break up at 5k rpm. So I replaced the coil packs, spark plugs and recently got a decent tune. The car ran great, made really good power. This lasted for about a week. Car now feels like stock power and sometimes doesn’t wanna idle like before. Feels like there is a dead stop sometimes between 3k-4K rpm. Can anyone help me out? Feel like maybe the cat is blocked up maybe from when it was running really rich. On my obd2 boost/temp gauge it’s hitting like 7psi which I think is what it was hitting when it was good. But on the exutek computer when it was getting tuned it was hitting 9psi. But of a noob haha. Cheers
Car has stock header. Mxp comp rs cat back 3 port oil catch can |
#333 | |
Drives: Scion FR-S
#334 |
Drives: brz 2017 hksv2
post logs or no help : \
#335 |
Drives: 2017 Toyota 86
@Hartley107 Yep, logs are important.
Grab these channels to start: Air Fuel Ratio (AFR), Commanded AFR, Short Term Fuel Trim (STFT), Long Term Fuel Trim (LTFT), Ignition Advance, and Advance Multiplier (IAM), and your boost pressure. Upload to Datazap.me, it's a pretty widely used site to chart and share logs. |
#336 |
Something something
Hey guys, just got my package.
I'm waiting till Black Friday to buy the supporting mods and was wondering if I should change anything else. I have a 2017 BRZ so I believe I don't have any need for an oil temperature gauge as there is a built in one. I'm also not running a boost gauge because it's...supercharged. However, I'm told it can be nice to have one in case of boost leaks? Omni 3 BAR - Very very important and very much required. MAPerformance Oil Cooler (Bought because some review said he ran it with a Vortech kit so presumably it should be fine.) AEM AFR Gauge AEM Oil Pressure Gauge Racer X Catch Can (Debating if I should just splurge for the dual catch can but it's not like I'm tracking this car...) Turbosmart 25mm BOV w/ Blue Spring I believe this is all the important ones. It's the ones during installation that I require more knowledge about. One quart of Subaru 0w20 for the Oil Cooler One oil filter. Gauge mounts. Am I going to need additional stuff such as additional wiring, oil adaptors...ect? All installation will be done by a professional shop and tuned by someone who is very familiar with the platform (DD Performance in Sealy, TX). |
| STX Rules and Setup Questions | Scooby South | Tracking / Autocross / HPDE / Drifting | 3914 | 07-18-2023 05:16 AM |
| Questions and Discussion on Vortech Supercharging Systems | Brian@Vortech | Forced Induction | 1462 | 01-27-2017 03:05 PM |
| Vortech Offical Owner Thread | cjsporl1996 | Forced Induction | 2 | 03-27-2014 01:50 AM |
| Who to tune Vortech setup? | pheoxs | Forced Induction | 18 | 02-20-2014 03:58 AM |
| Sprintex or Vortech, which setup has more potential? | Turbowned | Forced Induction | 328 | 09-14-2013 12:09 PM |
