Old 12-30-2015, 02:31 PM   #239
avishenoy1
avishenoy1's Avatar
Drives: 2015 FR-S Release Series 1.0
Hi, I will be installing this kit on my FR-S soon and will be running it with an Openflash UEL header, quad tip TRD cat-back, and Maxflow BOV on 93 octane pump gas.
My goals for the tune are 250hp/200lb-ft torque and I will running the 3.48" pulley. Will I be able to reach these numbers on the stock fuel system? I will not be running e85.
Also does anyone know if the stock fuel system will be able to handle the 3.125" pulley on 93?
avishenoy1 is offline   Reply With Quote
Old 12-30-2015, 08:24 PM   #240
DJCarbine
Thupercharged
DJCarbine's Avatar
My previous tuner advised me that the stock fuel system could support this power with the addition of a drop in fuel pump. I opted for fuel pump + injectors for E85 potential later on down the line.
I would skip the maxflow bypass valve, mine is sitting on a bench quietly
3.125" pulley on 93 is fun, I am currently running it
2013 FRS
Vortech V3 11psi
Old 01-04-2016, 03:43 PM   #241
FyeaFRS
Drives: 1992 Nissan Skyline GTS-t Type-M
295whp on stock fuel system with no problems
Doing pump, rails, injectors w/e85 in the spring
FyeaFRS is offline   Reply With Quote
Old 03-30-2016, 03:04 PM   #242
continuecrushing
continuecrushing's Avatar
Drives: 2013 Firestorm FRS
We've got an FRS in the shop with the Vortech being installed! I'll have some photos up in a bit
Old 06-13-2016, 11:50 AM   #243
Gopherboy6956
Gopherboy6956's Avatar
Drives: 13 BRZ Limited WRB
I am on Vortech - been about 10k now.
On my 2nd motor, after a bad tune last year detonated and bent a rod.
These are my details -
-Engine & Drivetrain-
Vortech Supercharger Kit
Gates Serpentine Belt
Open Flash Tablet Vortech S/C Tune
Perrin Oil Cooler
Perrin Radiator Hoses
Mishimoto Radiator
Radium Dual Catch Can Kit
Open Flash Tablet UEL Header
P&L Overpipe
P&L Catted front pipe
Perrin 3.0" Cat-back Exhaust (Resonated)
Perrin Crank Shaft Pulley
Perrin Lightweight Accessory Pulley Kit
Driveshaft Shop Aluminum Driveshaft
MTEC Shifter Springs
Nameless Performance Engine and Pulley Covers - Custom Subaru Logo Engraved
Painted all fluid caps WRB
(former) P&L Catless Header
(former) EcuTek with Perrin NA Tune
(former) EcuTek with Perrin Vortech Tune
(former) Perrin Inlet Tube
(former) Perrin Cold Air Intake
(former) K&N Air Filter
-Chassis & Suspension-
25% 3M Tint all around
Grimmspeed Hood Struts
Racecomp Engineering Tarmac Zero Coilovers
Whiteline Crossmember Mount Insert Bushings
Whilteline Rear Camber Adjust Kit
Cusco Power Brace
Cusco Strut Tower Brace
Cusco Battery Tie Down
Perrin Rear Sway Bar - 16mm
Perrin Poly Endlinks
Perrin Master Cylinder Brace
Perrin Transmission Support
Perrin Steering Rack Lockdown
Perrin Rear Shifter Bushing
(former) Grimmspeed Strut Tower Brace
-Wheels & Tires-
ARP Extended Studs
--Street Setup--
Enkei RPO3 17x8 48mm Offset Silver
Dunlop ZII 245/40/17 Tires
Muteki Blue Lugs
--Track Setup--
Enkei RPF1 17x9 45mm Offset Gold
Dunlop ZII Star Specs 255/40/17
Muteki Black Lugs
-Brakes-
Carbotech XP10 Front, XP8 Rear race pads
Stoptech Steel Brake Lines
Motul RBF 600 Race Brake Fluid
-Audio-
Pioneer AVH-X8500BHS
JL Audio XD500/3 Amp
JL Audio C5-653 3 way components
JL Audio 10W3v3 Subwoofer
Integrity Concepts Subwoofer Enclosure
-Misc-
Raceseng Shift Knob
Raceseng Front Tow Hook w/ GoPro Mount
Raceseng Rear Tow Hook
Toms' Clear JDM Tail Lights
GTR Lighting 3rd Brake light F1 Style Flasher
LED Turn signals
I plan to live forever. So far, so good.
My Build - http://www.ft86club.com/forums/showthread.php?t=31925
Gopherboy6956 is offline   Reply With Quote
Old 06-13-2016, 11:57 AM   #244
bee_are_zee
bee_are_zee's Avatar
Drives: GBS BRZ
Vortech smaller pulley (3.25")
Who did your tune?
bee_are_zee is offline   Reply With Quote
Old 06-13-2016, 01:36 PM   #245
Gopherboy6956
Originally Posted by bee_are_zee View Post
Who did your tune?
The current one? Shiv @ OFT
Previous one was the stock Perrin tune that came with my kit (good, but way rich)
One that killed my 1st motor was Full blown Motorsports (ironic) in Minneapolis.
Old 06-13-2016, 04:03 PM   #246
bee_are_zee
Drives: GBS BRZ
Thanks. I'm about to get the same pulley and have shiv etune it. Have you had it on a dyno by chance?
Old 06-13-2016, 05:03 PM   #247
Gopherboy6956
I haven't yet. My last dyno was after my Full Blown Tune -
On the stock Perrin Ecutek, i was at like 242whp, with the FBM tune i was at 276whp/199tq
We did just recently get a Dyno here in Fargo, so after i get this tune sorted out (still in progress, and going to add E85 soon) then i'll hit the dyno again.
Old 06-14-2016, 01:19 PM   #248
sirsol66
Drives: 2013 FRS- Hot Lava
I'm on this kit (OFT300), open flash header, open flash tablet, tuned by Shiv. We're at 4 revisions and should be done soon. Total of about 2000 miles on the kit but I also split my time between 3 FR-S's so none of them get many miles. Overall very happy.
I have not had this car dynoed but relative to my evo, I would estimate 240~250whp range on a dynojet. Not a "fast" car in any sense of the word but it makes for an entertaining drive to work.
sirsol66 is offline   Reply With Quote
Old 06-14-2016, 01:30 PM   #249
Gopherboy6956
I figure if balls out, stock pulley, i get 275whp, then backing it off to a safe level should net 250-260whp.
Looking forward to seeing how it works on E as well.
Old 06-24-2016, 05:48 PM   #250
Gopherboy6956
Anyone having issues with their Serp. Belt walking 1 notch off the pulleys?
When i went to replace my squeaky belt (seems to be annually) it was 1 spline off (towards rear of car) so i put the new one on, got it all situated and checked it over the next few weeks - was good to go.
This last weekend i was racing, and was just checking around the SC (it get's spitty out the vent when on the road course) and i noticed the belt had walked back 1 notch again.
I figure there must be some slight alignment issue, but i dont know what on earth a guy can adjust to make this stop happening. Any ideas?
This only happens on the crank pulley and the water pump pulley.
(Photo shows new belt installed correctly for reference)
Old 06-24-2016, 09:41 PM   #251
DJCarbine
Thupercharged
DJCarbine's Avatar
Which Gates racing belt are you running?
2013 FRS
Vortech V3 11psi
Old 06-25-2016, 12:24 AM   #252
Gopherboy6956
Gates K060975RB
STX Rules and Setup Questions Scooby South Tracking / Autocross / HPDE / Drifting 3914 07-18-2023 05:16 AM
Questions and Discussion on Vortech Supercharging Systems Brian@Vortech Forced Induction 1462 01-27-2017 03:05 PM
Vortech Offical Owner Thread cjsporl1996 Forced Induction 2 03-27-2014 01:50 AM
Who to tune Vortech setup? pheoxs Forced Induction 18 02-20-2014 03:58 AM
Sprintex or Vortech, which setup has more potential? Turbowned Forced Induction 328 09-14-2013 12:09 PM
