#127 |
SLO NO MO
I use my AC all the time, stage 1 vortech v3 kit, using the belt that came with it. Had the kit in place since spring 2013 and haven't had any issues. No issues downshifting either.
Sent from my Nexus 5 using Tapatalk |
| The Following User Says Thank You to Foobar For This Useful Post: | Jman1759 (01-08-2015) |
#128 | |
Drives: 22RE, FA20, 4G63
It is completely dependent on your driving habits... Off course you can down shift and use your AC and if you drive like a normal person the belt could last as long as the original one (without the stress of the blower)... BUT you have to understand that the belt was design for certain amount of power, and the belt (black or blue) could move the blower with ANY pulley. In my case everything was and is aligned (SC, belt, pulleys) but if I try to use my car as I fly my motocross bikes I have change belts 3 to 4 times per oil change (3k miles), and I believe that's not so bad, if I went the turbo way and drive like I run out of medications maybe the engine and/or the trany were the things braking. So it is a good idea to have an additional belt and some basic tools on the trunk, it doesn't hurt and could be change in 15 min without removing the sc. Enjoy
#129 |
[Citation Needed]
Drives: 2014 WR Blue Subaru BRZ Premium
#130 |
Yup, that's why I change the way I drive, specially down shifting. If you try to get hot to a tight turn (late braking and down shift "aggressive" so the rpms get close to the rev limiter with the rear tires braking traction just before full throttle again "that could be 2 or 3 gears at the same time" (on the AT cars you can even down shift 4 gears at the same time)... But all that spinning in so little time is NO good for the belt... Also change the differential bushings (they start early wear noise) and yes this is abusing from the car, but that's why I didn't buy something expensive
So yes you can down shift, you can up shift, you can use you AC and you can even go to track events and the unit would hold. As side note: it is more "rewarding" (and would let you know you car better) to take the turns in 3 or 4 gear at 35-45 mph... But then a little bit of more midrange would be welcome. Already with the 4.88 final drive. Anyway take care and have fun Last edited by AJPG; 01-09-2015 at 10:27 AM. |
#131 |
Drives: 2013 FRS, 2002 WRX Wagon
What size belt are you guys running? I was having to change my belt almost every 1000 miles (Gates Blue K060975rb). Emailed Vortech and they said that is the wrong size (even though manual states 97.5" belt) and stated that the k060970 (97.0") belt is the correct size on the 9psi pulley. Too bad gates doesnt make the blue belt in that size, or i just can't find it on their site.
#132 | |
SLO NO MO
About 8.5k miles, 2 years. All seasons. Sent from my Nexus 5 using Tapatalk |
#133 |
Builder/Driver/Enthusiast
Drives: 2013 FR-S 6MT Turbo Firestorm
Is anyone running the Vortech V2 with an OFT tune? I'm putting together a custom kit and I'm hoping to not have to replace my OFT.
Andy
1977 Triumph Spitfire 1500 - New Project 2013 Firestorm FR-S 6MT Turbo - Sold 2013 Honda CBR 250 Repsol- Toy 2017 Toyota Tacoma - The Rig |
#134 |
Go-Kart Enthusiast
Drives: Toyota Scion FRS
The OFT supports the Vortech version 3 with stock pulley. You will need a different tuning solution with the 3
FRS
Current mods: K&N air filter, OFT, OFH, berk high flow cat front pipe, Q300 exhaust, lighter wheels |
| The Following User Says Thank You to Boofneenee For This Useful Post: | RedFR-s (03-09-2015) |
#135 | |
Worst case I'll have to put together a custom tune.
Andy
#136 |
Drives: GBS BRZ
If the boost curve is the same I'm not sure what would need to change in the tune? I would log a lot and make sure everything is ok but at the least it would be a very good start for a custom tune.
| The Following User Says Thank You to bee_are_zee For This Useful Post: | RedFR-s (03-09-2015) |
#137 | |
Thupercharged
Pretty sure the compressor is the same minus the bits required for oil feed.
2013 FRS
Vortech V3 11psi Revworks UEL - PLM Overpipe - MOTIV catted frontpipe - Invidia Q300 2019 Series.Grey STI - Stage1+ SF |
| The Following User Says Thank You to DJCarbine For This Useful Post: | RedFR-s (03-09-2015) |
#138 |
#139 |
Brian@vortech I'm trying to send you a PM but about the V2 charger I've got but no inbox room.
Andy
#140 |
Can someone tell me whether the supercharger spins CW or CCW?
Andy
| STX Rules and Setup Questions | Scooby South | Tracking / Autocross / HPDE / Drifting | 3914 | 07-18-2023 05:16 AM |
| Questions and Discussion on Vortech Supercharging Systems | Brian@Vortech | Forced Induction | 1462 | 01-27-2017 03:05 PM |
| Vortech Offical Owner Thread | cjsporl1996 | Forced Induction | 2 | 03-27-2014 01:50 AM |
| Who to tune Vortech setup? | pheoxs | Forced Induction | 18 | 02-20-2014 03:58 AM |
| Sprintex or Vortech, which setup has more potential? | Turbowned | Forced Induction | 328 | 09-14-2013 12:09 PM |
