#43 |
That Guy
Drives: 2013 asphalt FRS MT
^that!
#44 |
Drives: MR2 Spyder
I like Fortune Auto even more now!
Jenson May is cool
#45 | |
Drives: Evo
![]() Quote:
#46 | |
Drives: Evo
We use Ohlins shims on all our 510 & Dreadnought assemblies. It just makes building the shocks easier and consistent. For example, you can purchase a lot of 500 Ohlins .38-36 shims (pictured). Before we use them a tech measures each of the shims with a digital caliper. Out of 500 shims, maybe 1 shim will not measure out perfectly to .38mm thickness and 36mm in Diameter. I consider that very impressive considering that a difference in shim thickness of .01mm can make a impact on valving profiles. The malleability of the Ohlins shims are also very consistent. Considering that the shims cover up the piston ports and eventually flex to let oil through the ports, shims are very crucial. They are even more crucial on shocks that are running lots of force and digressive as the shims flex more. If you look at some lesser quality shims, you will see different grains in the metal and that usually has an impact on consistency from one shock to the next since the shims do not flex the same. Taking things one step further, if you look at some of the Taiwanese and even Japanese manufactured shims....well most are terrible. It is literally impossible to have a matched set of shocks. This is one of the main reasons why we stopped using Asian shims in our shocks for a few years now. |
#47 |
That Guy
@Jenson May are you shocks end user rebuildable?
#48 | |
Drives: Evo
| The Following User Says Thank You to Jenson May For This Useful Post: | Calum (04-28-2013) |
#49 |
That Guy
Just curious as I don't know much (anything really) about your company and thought others may benefit from the information. In the same vein, are you able to offer custom valving and/or spring rates?
#50 | |
Drives: Attitude
http://www.fortune-auto.com/products.htm |
| The Following User Says Thank You to OrbitalEllipses For This Useful Post: | Calum (04-28-2013) |
#51 |
Drives: DGM BRZ Limited
Mr. May, please keep talking.
Thank you, and carry on. |
#52 |
Drives: SWP DZE
For comparison, are there any shock dynos of KW V3s?
#53 | |
Drives: 2013 SWP BRZ
#54 |
Drives: Attitude
#55 |
Señor Member
Subscribed. Keep up the good info
1974 TA22 Celica
2013 86 GT |
#56 |
Drives: Evo
Yes all Fortune shocks offer custom valving and spring rates, even the 500's
| The Following User Says Thank You to Jenson May For This Useful Post: | Calum (04-30-2013) |
| Inexpensive lip+skirts+spats? | mike_ekim1024 | Cosmetic Modification (Interior/Exterior/Lighting) | 5 | 03-07-2013 02:05 PM |
| Inexpensive suggestion for better sound?? | ngabdala | Electronics | Audio | NAV | Infotainment | 28 | 08-24-2012 01:05 PM |
| Inexpensive rear spoiler | whataboutbob | Cosmetic Modification (Interior/Exterior/Lighting) | 16 | 08-17-2012 09:09 AM |
| Inexpensive spare wheel | Captain Snooze | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 1 | 07-05-2012 07:36 AM |
| I'm afraid the FT86 might be too inexpensive. | BRZrkr | Scion FR-S / Toyota 86 GT86 General Forum | 30 | 02-24-2010 03:45 PM |
