86WORX
Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > Marketplace > Commercial Classifieds > Exterior Parts - Lighting
Old 11-07-2013, 11:07 PM   #183
pansontw
Drives: Subaru Legacy
SB for your ref.
pansontw is offline   Reply With Quote
Old 11-08-2013, 12:04 PM   #184
pansontw
Bump...
Old 11-11-2013, 12:22 AM   #185
pansontw
To the top..............
Thanks for the GB, price now is $299 shipped for 1 set of Valenti Tail Lamp.
Pls pm if interested!
Sincerely,
Panson
Old 11-11-2013, 12:29 AM   #186
kALMIGHTY
Drives: TRD Ultramarine '13
I still can't decide between these or the Spyders. I know I want the Valenti reverse lights, but not sure about the tail lights. A lot of people have issues with some LED's in these not working, and I'm not sure what the brightness in daylight is like compared to the Spyder's. Really wish there was a direct comparison for daylight brightness and quality issues.
Old 11-11-2013, 12:47 AM   #187
pansontw
We do stand behind all the products we sold.
So no worry on defects on what's so ever.
For brightness, both Valenti and Spyder are at similar level.
If you are getting the reverse lamp, then there is no meaning comparing the brightness level.
Because the blinking of the reverse will definitely get others' attention.
Let me know
Sincerely,
Panson
Old 11-11-2013, 01:48 AM   #188
kALMIGHTY
Let me know
Sincerely,
Panson
For the reverse light, how is it coming wired up now? Is it going to light up the "V line" only and the triangle comes on with brake, and white led's for reverse? Or is the V line and the triangle lit up at all times? Is there a way to stop the reverse light blinking?
Old 11-11-2013, 02:46 AM   #189
pansontw
Blink 5 times is optional w/ a separate wire. If you don't like this blink-5-times thing, just leave the wire unattached.
Below is the functionality of the reverse lamp
Since USDM 86/BRZ doesn't come w/ rear fog, we will usually attach the fog function to position lamp.
Old 11-11-2013, 04:09 PM   #190
kALMIGHTY
So what will be exact functionality of the reverse light if I leave the blink wire unattached?
Is there a way to have only the bar on, and Zone 1 will only light up with the brakes, but no blink? And Zone 2 with only reverse?
Old 11-11-2013, 07:09 PM   #191
pansontw
It is doable. But you need to open up the reverse and do some cut & soldering.
Sincerely
Panson
Old 11-11-2013, 07:18 PM   #192
pansontw
Here is the DIY quoted from an Australian 86forum.
[ame="http://www.youtube.com/watch?v=pSsHzfdmD3U"]Toyota 86 Valenti Modified REVERSE & REAR FOG LIGHT (daytime) - YouTube[/ame]
DIY here: http://*****************************...f1-race-style/
Sincerely
Panson
Sincerely
Panson
Old 11-11-2013, 08:48 PM   #193
kALMIGHTY
Sincerely
Panson
You said Zone 1 and the bar are lit up at all times by default right, and Zone 1 blinks 5 times when you press the brake?
What happens if I leave the blink wire unattached? Zone 1 will still be lit up at all times so nothing will change when I press the brakes?
Old 11-12-2013, 03:44 AM   #194
pansontw
Yes, by default, Zone 1 and V bar will lit up all the time. (A wire)
Blink 5 times (optional B wire)
If you leave the blink wire (B wire) unattached, zone 1 and V bar will still lit up at the same time.
Custom wiring is required if you want to make make zone 1 function independently while braking. (need to open up the lamp, find and splice the A wire, then attach the zone 1 part of the wire to braking wire)
I think below is what you want!
[ame="https://www.youtube.com/watch?v=A9u35UTZEio"]Subaru BRZ - Scion FRS LED Tail Lights by Valenti at ModBargains.com - YouTube[/ame]
Sincerely,
Panson
Old 11-12-2013, 12:53 PM   #195
kALMIGHTY
Sincerely,
Panson
Yes that video is exactly what I want. I'm not an electrician and I have no idea how to splice and cut wires though.
Old 11-12-2013, 03:28 PM   #196
pansontw
It is doable if you follow the DIY quoted from Australia forum.
If you are not comfortable doing the splicing and soldering, you might need to find a good tech to help you w/ that.
Sincerely,
Panson
Valenti Japan Full LED Tail Lights pornflakes AUSTRALIA 4 11-07-2015 09:56 PM
**Valenti Japan LED Tail Light & Rear Bumper Reverse LED Light** nigel-jdmparts Exterior Parts - Lighting 13 04-30-2013 01:14 PM
Valenti Tails & Reverse Lamp JPxM0Dz Cosmetic Modification (Interior/Exterior/Lighting) 16 04-27-2013 11:06 AM
Gauging Interest Valenti Japan Full LED Tail Lights pansontw Cosmetic Modification (Interior/Exterior/Lighting) 95 03-10-2013 05:29 AM
