#29 |
Drives: 14' Monogram FRS, ulramarine, white
In the stock form the Automatic tranny can handle 450 HP and 425 lb/ft of torque... The manual can only handle 220 hp and 200 lb/ft torque before the clutch starts slipping... That's what I was referring to. So at 220 hp you have to upgrade the clutch.
whether it be low and slow, fast and loud, or riding on rails, make it unique and make it your own.
#30 |
Driveway labs.
Drives: '13 BRZ Limited, 6sp, SWP
The Perrin car is at 300whp on stock clutch, there are AVO cars running 250+whp and 220+wtq on stock clutch.
-'13 Subaru BRZ Limited, SWP. (Mods: Driveway Labs full aero, MCA, etc)
-'06 Mitsubishi Eclipse 3.8L, UV blue. (Mods: turbocharged, full suspension, too much to list) -'13 Town and Country Limited (Mods: too many kids) |
#31 |
I said it starts slipping at 220... Not that you have to upgrade it... But its highly recommended...
#33 |
Ok, so I got my baseline numbers and my numbers after the exhaust was installed... Baseline was 146.3 HP and 120.2 lb/ft torque... After doing my exhaust I'm sitting at 167.3 HP and 145.8 lb/ft of torque now I need to get a full tune for it and ill be good to go or my F/I kit... I like the numbers so far but still have some of the torque dip problems... They should go away when I get the full tune done.
#34 | |
Boosted Member
Drives: 2013 SWP BRZ Limited
Was the dyno done on the same day? Its hard to believe a 21hp and 25 lb torque gain from a cat back exhaust on a n/a 2L engine. Is this with a base map tune or just bolt on exhaust without the tune?
Just for reference, I have a catless front pipe, 2.5in Invidia N1, Perrin CAI, LWCP, and a open source custom tune with BRZedit, and gained about 13hp / 15 lb torque. If your numbers are 100% correct, then your bolt on parts will be the highest power upgrade I have ever witnessed on this forum, including headers w/o a tune. A bolt-on header gains about 5hp w/o a tune. Quote:
Suzuki Swift GTI '89, Subaru Impreza L '96, Lancer OZ '03, Subaru Impreza WRX '06, Honda CBR600RR Graffiti, Volvo c30 T5 R '11, Subaru BRZ '13, Audi RS4 2007
SUV's: Mercedes Benz R500 '06, Mercedes Benz ML350 '12 |
#35 | |
#36 | |
Boosted Member
| BRZedit Drive By Wire Info | mad_sb | Engine, Exhaust, Transmission | 20 | 03-20-2021 02:19 PM |
| BRZEdit (ECUEdit) | illmatic | Software Tuning | 246 | 06-02-2016 02:15 PM |
| BRZedit Cam Tuning Info | mad_sb | Engine, Exhaust, Transmission | 11 | 01-25-2015 05:58 AM |
| My Initial (all stock) BRZedit tune | mad_sb | Engine, Exhaust, Transmission | 6 | 02-16-2013 01:20 PM |
| BRZ crash bolt same as Impreza lower strut bolt? | xwd | Tracking / Autocross / HPDE / Drifting | 0 | 07-05-2012 01:19 PM |
