Old 05-15-2013, 09:32 PM   #43
Originally Posted by AE86guy View Post
Just get the car to spin out completely and jam the brake pedal. It will even happen at low speed; first gear.
Well, if that's the case, it's doing the right thing... but my goal is to drop time on hot laps, not spin >.<
Old 05-15-2013, 09:41 PM   #44
robispec
Drives: Black frs project
I pulled the fuse at the Dynamic Driving Academy clinic and that seemed to work pretty good, .
which fuse? i'll test it at laguna!
robispec is offline   Reply With Quote
Old 05-16-2013, 02:02 PM   #45
AE86guy
AE86guy's Avatar
Drives: Scion FR-S + Toyota AE86
Green ABS fuse under the hood. But this will render the car analog with no driving aids. You don't want ABS for drifting, but you might need ABS for big tracks where speeds are higher for safety.
AE86guy is offline   Reply With Quote
The Following User Says Thank You to AE86guy For This Useful Post:
philstar (05-17-2013)
Old 05-16-2013, 02:18 PM   #46
T2 at Laguna has a rather MASSIVE runoff.... but Robi's an experienced enough driver that not having ABS shouldn't be an issue.
Old 05-16-2013, 02:25 PM   #47
rice_classic
rice_classic's Avatar
Drives: Nevermorange FRS
I think one should be able to pilot a car without ABS. But that's just me.
SCCA T4 - FRS
Old 05-16-2013, 02:55 PM   #48
I may be guilty of taking advantage of ABS at times...
Old 05-16-2013, 08:26 PM   #49
robispec
My first 85 cars didnt even have abs....
Old 05-17-2013, 12:22 AM   #50
D1cker
Drives: B9 S4/ND2
I learned to track in a car without ABS, but it doesn't hurt to have it on a modern car.
D1cker is offline   Reply With Quote
Old 05-17-2013, 01:01 AM   #51
Simmons
Simmons's Avatar
Drives: 2022 BRZ
I pulled the abs fuse during an event, and got crazy lockup of all 4 wheels way to easy.
Simmons
2022 BRZ 71 STR
Sponsors Xero-Limit//Karcepts
Simmons is offline   Reply With Quote
Old 05-17-2013, 02:22 AM   #52
rice_classic
Couldn't help myself.
SCCA T4 - FRS
The Following User Says Thank You to rice_classic For This Useful Post:
acro (05-17-2013)
Old 05-17-2013, 03:08 AM   #53
OmarGC
My FR-S has 5 gears
OmarGC's Avatar
Drives: FRS/280z/Tundra
I pulled my abs fuse after a week of ownership... Completely forgot about pulling it too, that explains on why I never dealt with the ice mode.
Omar GC
2JZ - 6870 - stock block - 1000whp?
Instagram: 2jzus
OmarGC is offline   Reply With Quote
Old 05-17-2013, 03:09 AM   #54
robispec
Yeah baby I'm one bad*ss m*fo ;-)
Old 05-19-2013, 05:28 AM   #55
Godzilla35
Drives: Nissan GT-R
Of note:
I was able to replicate the "slip light turning solid when going over big bumps or left foot braking" this weekend while canyoning when not using the pedal dance.
It's also typically accompanied with a CEL. The CEL is soft and goes away after a while.
@D1cker
This actually happened to me at the Dynamic Driving Academy when I was doing a donut.
Godzilla35 is offline   Reply With Quote
The Following User Says Thank You to Godzilla35 For This Useful Post:
CSG Mike (05-19-2013)
Old 08-27-2013, 04:02 AM   #56
Godzilla35
Drives: Nissan GT-R
I experienced a lot of the "ice mode" at a drifting event at the balcony track a few weekends ago using the pedal dance. Mainly when I was spinning out(which was often). A car traveling backwards out of a third gear drift initiation with a rock hard brake pedal is not fun.
Using the traction off button was not an option as it would interfere too much, especially in transitions.
I pulled the fuse at the Dynamic Driving Academy clinic and that seemed to work pretty good, however, that was a low speed event so conditions were quite different. I also changed to a stiffer front spring rate but that shouldn't have made too much a difference.
I'll be at the balcony again in June for another drift event where I'll be running with the ABS fuse pulled. I'll let you guys know how that works out.
This EXACT situation just happened to me at Balcony this weekend... and as a noob it was kind of scary. Then it got to be really annoying as I was getting better and getting closer n closer to the wall / other cones. Sucks. Is the fuse you're talking about shown in the owner's manual or could you take a pic? And does it create a hard CEL / ABS light? I wouldn't mind doing this for track days at least.
The "Pedal Dance" testing CSG Mike Tracking / Autocross / HPDE / Drifting 419 08-01-2023 11:46 PM
Where to buy "heel/toe" shaped gas pedal? dookie11 Scion FR-S / Toyota 86 GT86 General Forum 56 01-22-2019 12:24 PM
Pedal Dance Imperative for Autocross/Track Black Tire Tracking / Autocross / HPDE / Drifting 5 04-22-2013 12:37 PM
Which Markets have "GT86" and "Toyota" badges on trunk? Tanuki Scion FR-S / Toyota 86 GT86 General Forum 20 02-10-2013 06:23 PM
Dyno testing and "drivetrain loss" serialk11r Other Vehicles & General Automotive Discussions 5 11-03-2011 09:55 AM
