86WORX
Old 05-06-2013, 06:15 PM   #29
CounterSpace Garage
CounterSpace Garage's Avatar
Drives: Subaru BRZ / Toyota 86 Experts
Originally Posted by N_I_N View Post
3 questions:
1. Are there any DOWNSIDES to running any of these high performance fluids other than costs?
I am a newbie on mechanical things, but I'm pretty mechanically inclined. I know that sounds like I'm cancelling out the first statement with the second, but what I mean is; as long as I have directions, I'm pretty good at following something and putting 2+2 together if I run into an unknown. So question 2...
2. Has anyone seen a really good tutorial for bleeding brakes online?
3. How much fluid would one need to completely flush the FR-S system?
1. Higher rated performance brake fluids are more hydroscopic (attracts/absorbs moisture). Although the qualities are good, it means the peak boiling temperature drops until it's completely compromised to the wet boiling temperature. Even with standard DOT 3 fluid, it is recommended to change brake fluid every year for optimal performance.
2. What kind of tutorial are you looking for? How to do it or what order to do it?
3. 1L of brake fluid is generally sufficient in flushing your brake fluid pretty well. Most of the time, you use less than a liter. Sometimes you'll need more if you're trying to pump out that stubborn bubble that got introduced into the system.
CounterSpace Garage is offline   Reply With Quote
Old 05-06-2013, 06:25 PM   #30
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Originally Posted by rice_classic View Post
I've been racing on ATE since 2004 in a car with tiny rotors and poor ducting. Trust me, it can handle it just fine. I have never boiled fluid.
I used to push ATE SuperBlue too.. I have never boiled it in any of my Hondas, and still run it in the race car, but I did boil it in the BRZ. :shrug:
I'm an abusive asshole to brakes though.
I do a bleed (not flush) every event with AP Super 600, pedal has remained solid throughout events. I actually didn't have time before one event, so it did a 2 day event then another 2 day event, cracking a rotor the last day of the second event, fluid still had zero bubbles/etc in it. Firm pedal.
Until I get to a situation like Mike's (bleeding during the track day, noticable deterioration of pedal feel, etc) I won't step up to the high dollar fluid simple because I don't need to yet.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 05-06-2013, 06:32 PM   #31
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
This. I usually use 2L of fluid for a full bleed, I'm paranoid with brakes a little
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 05-07-2013, 01:25 PM   #32
rice_classic
rice_classic's Avatar
Drives: Nevermorange FRS
Just because I'm pedantic and this is a common mistake that I also had to be corrected on by an instructor.
Hydroscopic: -n; any instrument for making observations of underwater objects
Hygroscopic: -adj; (of a substance) tending to absorb water from the air
Then the confusion is compounded because the opposite of HyGROscopic is HyDROphobic.
SCCA T4 - FRS
The Following 2 Users Say Thank You to rice_classic For This Useful Post:
BRZZZZZZZZZZ (06-13-2015), CounterSpace Garage (05-07-2013)
Old 05-07-2013, 02:18 PM   #33
OrbitalEllipses
Drives: Attitude
You may as well use the whole liter since there's no point in saving the bottle once it's open.
Old 05-07-2013, 02:38 PM   #34
CounterSpace Garage
HAHAHAHA I just thought about the Family Guy moment when this happened. Thanks for the correction! :happy0180:
Old 05-07-2013, 02:40 PM   #35
CounterSpace Garage
That's essentially up to the user of course.
Old 05-07-2013, 03:33 PM   #36
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
^ that's the other reason I stopped using ATE.. too much waste. Although we don't follow that with the race car and no bad results.. yet
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 06-13-2015, 03:10 PM   #37
2015FRShalo
Drives: 2015 Frs Halo 909 miles
I'm not too sure if this is the correct brake fluid for my 2015 frs so if anybody could tell me? I'd love to get project mu so is the correct one? And how many liters do I get? http://www.evasivemotorsports.com/mm...MU-BRAKE-FLUID
2015FRShalo is offline   Reply With Quote
Old 06-13-2015, 04:44 PM   #38
Black Tire
Black Tire's Avatar
Drives: Whiteout Scion FR-S
That is the correct fluid. You may also consider Torque RT700. This came out after most of this thread was written. There is a review and discussion about it here:
Torque RT700 Review
Old 06-13-2015, 08:22 PM   #39
ScionOfHorus
ScionOfHorus's Avatar
Drives: 2015 Series.Blue BRZ
Torque RT700 Review
I dunno if it's still going, but CSG had a 4-for-3 deal going a little while ago.
ScionOfHorus is offline   Reply With Quote
Old 06-13-2015, 10:41 PM   #40
http://counterspacegarage.com/pmu-gfour335.html
Old 06-14-2015, 10:05 AM   #41
Alan
Alan's Avatar
Drives: 2013 SWP BRZ Ltd. / E60 M5
Mike, I made the switch from Stoptech 660 last year (its what was on hand) to Motul 660 this year. Brakes have gotten better. Is the PMU Gfour that much better?
2013 BRZ Limited | SWP | Verus Ventus 1 and High-Efficiency Rear Wing | Invidia N1 Ti | JR Oil Cooler | RCE T2 | RaceSeng Cas/Cam | SPL LCA & TA | Wilwood/RR Racing Stage II/Sport Performance | XP10 | Apex ARC-8 | Toyo R888R | 245/40-17 | Sparco Ergo II/Evo II | AIM MXP | SmartyCam GP HD 2.2
Alan is offline   Reply With Quote
Old 06-14-2015, 02:20 PM   #42
It's a small incremental step up. If you want a larger step, go to RT700. The price isn't much more than RBF660.
Search this Thread:
Advanced Search
Amount of Brake Fluid.... THEmailman Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 3 04-14-2013 12:46 AM
Brake fluid leak.. tintumz22 Issues | Warranty | Recalls / TSB 9 02-01-2013 04:20 PM
Track Day Brake Fluid Skorov AUSTRALIA 2 11-11-2012 08:10 PM
$98 Brake Fluid Upgrade Texas BRZ Tracking / Autocross / HPDE / Drifting 15 10-22-2012 03:50 AM
Brake fluid volume celica73 Tracking / Autocross / HPDE / Drifting 1 08-20-2012 03:05 PM
