86WORX
Old 04-19-2013, 07:25 PM   #15
A5D5TRYR
A5D5TRYR's Avatar
Drives: FR-S 6MT Ultramarine (BeeDrill)
Originally Posted by FT-86 SpeedFactory View Post
Our Firestorm car has been running without a tune for several hundred miles and an open track day with no issues. I sure wasn't easy on the car for the track day either Mods include AEM intake, HKS EL header, Perrin over-pipe, Invidia catted front-pipe, and T1R cat-back.
I will be interested to see the logs on the stock tune. We have tunes waiting for it, but just have not had the time for it. Also, kind of want to see what kind of numbers we are putting down with the stock flash.
Just my .02, I suppose.
Cheers!
-Yo
How do you find it volume-wise with that exhaust set-up? I'm really interested in the T1R exhaust but plan to go to a header at some point and don't want it to end up TOO loud.
2013 Scion FR-S - Ultramarine 6MT
A5D5TRYR is offline   Reply With Quote
Old 04-20-2013, 02:30 AM   #16
Tainen
Drives: First SWP BRZ-L
Cheers!
-Yo
I've also been running headers for several thousand miles, track days, etc. without a tune.
Lets not flood the forum with bad info- you don't need a tune with headers. At least, not all.
First white BRZ in the country
Limited SWP BRZ, 35% tint, clear bra, Nameless Performance downpipe, axelback, headers
Tainen is offline   Reply With Quote
Old 04-20-2013, 02:38 AM   #17
Hawaiian
That guy
Hawaiian's Avatar
Drives: Ultramarine mt FR-S
while a tune may not be required, you will not be getting the most out of your header without one.
Ultramarine mt FR-S
P&L stage 1 turbo
Prime Motoring Flex fuel
Jr Tuned 506whp @17psi (e73)
Old 04-20-2013, 02:44 AM   #18
ft_sjo
Drives: GT86
If you don't need a tune, then your headers aren't doing much!
The Following User Says Thank You to ft_sjo For This Useful Post:
Hawaiian (04-20-2013)
Old 04-20-2013, 04:32 AM   #19
Tainen
I've got the dyno numbers that say different. I'd love to see them with a tune as well though, some day. Track time is more important right now for me.
I just want to make sure people know that you don't "need" a tune with headers. My AFR looks good, and the headers were designed to be fine on stock tune, and it pulls nice and hard (and these were the first dyno proven headers on the forums, I might add).
Old 04-20-2013, 04:43 AM   #20
ft_sjo
Drives: GT86
No doubt you have before and after dyno runs taken on the same dyno, same day?
Old 04-20-2013, 05:18 AM   #21
Tainen
different days. Same exact temp and humidity though, with 6+ runs both before and after. And re-verified at yet another dyno facility operated by a 3rd party (which was all within 2hp, same kind of dyno). Check out the nameless header thread for the deets. It's all been beaten to death over there with dyno plots, pics, drive impression vids, it goes on. No need to hijack this thread to challenge someone
Old 04-20-2013, 12:58 PM   #22
mad_sb
Drives: 2013 Asphalt FR-S
I see you have one of the early prototype nameless headers... no offense but those do not flow as well as the newer 4-1 long tube designs or the yet to be released nameless 4-2-1 long tube (which i am on the waiting list for). For those I believe you are correct that you don't NEED a tune because they did not change the flow / back pressure characteristics as much as the newer long tube 4-1 or 4-2-1 designs.
I still think you would notice a nice difference with a custom tune though because the stock cam timing is the way it is to work around the limitations of the stock header in the dip region.
So, to revise my opinion headers that don't flow much better than stock probably won't benefit from, or change afrs enough to warrant a custom tune.
Old 04-22-2013, 01:49 PM   #23
Tainen
These are equal length with 30-40% more volume (just looking at primary sizes by themselves). They flow significantly better, as evidence by the +29whp at the top end. No offense taken, just trying to clear up info- you *can* run headers without a tune. Are you leaving power on the table? yes. but it's not unsafe for the vehicle. Do the newer long tube designs flow better? Yeah. not saying that
Question for Subaru veteran repair and ecu guys:radiator fans Huehuecoyotl Engine, Exhaust, Transmission 11 04-14-2014 07:19 AM
Question for you guys!? mbh1101 Electronics | Audio | NAV | Infotainment 5 03-22-2013 04:48 PM
Question for the guys with the cusco spin knob "drift" knob Juurian Cosmetic Modification (Interior/Exterior/Lighting) 5 03-13-2013 09:51 PM
Question for the Phoenix area guys Pscylo Southwest 11 09-11-2012 01:28 PM
What you guys do with stock headers and exhaust after swap? WatchmaN Engine Swaps 6 08-09-2012 07:26 PM
