#85 | |
Drives: really slow...
#86 |
Drives: Whiteout FR-S
Really sorry you guys are having issues, I am 100% sure Eibach will resolve whatever problems you may be having though.
@Jackson any ideas on how many sets of R1's and R2's have been shipped out? |
#87 |
When Mark replies back, I should be heading down to Eibach next week. Btw I did notice on a steep driveway my traction control going off and I heard a bunch of noise (Tings, clunks). I wasn't bottoming out but I played it safe and went a different way. I thought maybe one wheel was off the ground.
#88 | |
Drives: 2010 BMW M3, 2013 Subaru BRZ
#89 | |
Even with all the aids off, if tire spins, the diff/TCS will engage to stop the spin, so you can put power down. THe way our factory diff works, without the TCS kicking in, you're stuck; gotta have some sort of resistance on the lifted wheel for the other wheel to get power. If you tripod like this with the Pedal Dance.... you're stuck. |
#90 |
That TCS issue is due to suspension articulation. In my experience good dampers will cause TCS to come on less of the time as opposed to more of the time when the car is driven at speed; all other things being equal.
#91 | |
#92 |
Drives: A Potential Traffic Ticket
I got mine yesterday and now im having 2nd thoughts about installing the R2's. I might change the spring rate before installing these.
#93 |
Site Moderator
Drives: Stuff
Pull the e brake a little
![]() I still haven't driven my car enough to review. I'm running 2 comp and 6 rebound currently. My car is currently in an airport parking lot where it will stay for another week
-Dave
Track cars: 2013 Scion FRS, 1998 Acura Integra Type-R, 1993 Honda Civic Hatchback DD: 2005 Acura TSX Tow: 2022 F-450 Toys: 2001 Chevrolet Corvette Z06, 1993 Toyota MR2 Turbo, 1994 Toyota MR2 Turbo, 1991 Mitsubishi Galant VR-4 Parts: 2015 Subaru BRZ Limited, 2005 Acura TSX Projects: 2013 Subaru BRZ Limited track car build FS: 2004 GMC Sierra 2500 LT CCSB 8.1/Allison with 99k miles |
#94 | |
Drives: Some rust bucket
How can you tell if the damper isn't providing enough rebound for the springs? |
#95 |
Best way I can describe is that when the car rolls, it'll roll "too quickly" or "too hard", and the weight transfer will cause a loss of traction. With enough rebound damping, it'll roll, but without the loss of traction from swing/transfer being too big.
#96 |
I found 4/10 compression and 6/7 rebound to perform very well but again I've been plagued with the issues I spoke about. 0/10 compression and 2-3/7 rebound seem to be the easiest riding set up and dial out as much of the bounce that I get.
2010 Cadillac CTS-V Sedan M6 w/550whp (Build Thread) ![]() |
#97 |
Quick question - is it better to have the rear stiffer than the front or should it be equal with the front?
#98 | |
Ideally your buttdyno is sensitive enough that you can mentally separate front and rear when you're dialing it in, but it isn't easy. - Andrew
Website
https://www.racecompengineering.com/ Instagram: https://www.instagram.com/racecompengineering https://www.instagram.com/theapexfiles <- tech articles |
| The Following User Says Thank You to Racecomp Engineering For This Useful Post: | JackSmiley (05-21-2013) |
| Fortune Auto 500 Coilover Review | stoneman155 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 13 | 01-16-2020 06:22 AM |
| Coilover Review: FEAL SUSPENSION 441 coilover kit | mr. slim | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 39 | 11-28-2019 07:30 AM |
| ***Time to freak out, Eibach coilover pricing available**** | JoeBoxer | Brakes, Suspension, Chassis | 154 | 05-16-2013 06:30 PM |
| Eibach Multi-Pro-R1 VS KW v3 | thebear21 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 27 | 04-10-2013 02:32 PM |
| Eibach Coilover Options - SEMA 2012 Coverage | FT-86 SpeedFactory | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 45 | 01-25-2013 08:19 AM |
