#169 |
Drives: Whiteout FR-S
#170 |
Drives: A Potential Traffic Ticket
Did you change your springs already? Im kinda hesitant on doing the replacing myself.
#171 |
At least on my set they are gone.
I haven't but a few others have. Dave and Ayau could probably help you out with that. |
| The Following User Says Thank You to Hanakuso For This Useful Post: | JackSmiley (06-10-2013) |
#172 |
I'll wait til tomorrow when Eibach says something before i change out the rates.
#173 |
Drives: E46 M3 (daily) / EG Civic (track)
Here's the official response from our Eibach R&D department on the changes made. If anyone has an existing kit they wanted "updated" they can call Eibach at 951.256.8300 and talk to Mark Krumme in Technical Sales.
Multi-Pro R2 · FrontNoise o 1in droop spacer installed to allow the removal of helper springs o Updatedspring lengths from 6” to 7” (no spring rate change) · Front Ride o Compression and rebound valving was improved forbetter street ride characteristics without sacrificing track performance o Full open setting on compression and reboundrecommended for street use · Rear Noise o Removed helper springs o Updated spring lengths from 7” to 8” ( no springrate change) o Updatedto new rear upper mount bushings · Rear Ride o Compression and rebound valving was improved forbetter street ride characteristics without sacrificing track performance o Full open setting on compression and reboundrecommended for street use Multi-Pro R1 · FrontNoise o 1in droop spacer installed to allow the removal of helper springs o Updatedspring lengths from 6” to 7” (no spring rate change) · Front Ride o Compression and rebound valving was improved forbetter street ride characteristics without sacrificing track performance o Full open setting on compression and reboundrecommended for street use · Rear Noise o Removed helper springs o Updated spring lengths from 7” to 8” ( no springrate change) o Updatedto new rear upper mount bushings · Rear Ride o Compression and rebound valving was improved forbetter street ride characteristics without sacrificing track performance o Full open setting on compression and reboundrecommended for street use Pro-Street-S · FrontNoise o 1in droop spacer installed to allow the removal of helper springs o Updatedspring to 0700.250.0200 (spring rate change) · Front Ride o Compression and rebound valving was improved forbetter street ride characteristics while still maintaining a sporty ride o Implemented Schrader valve to better control ofgas pressure for more consistent ride. · Rear Noise o Removed helper springs o Updated spring to 0800.250.0275.0 (spring ratechange) · Rear Ride o Compression and rebound valving was improved forbetter street ride characteristics while still maintaining a sporty ride o Implemented Schrader valve to better control ofgas pressure for more consistant ride. |
| The Following 7 Users Say Thank You to Jackson For This Useful Post: | CSG Mike (06-10-2013), Hanakuso (06-10-2013), JoeBoxer (06-13-2013), lamawithonel (01-02-2016), RAWR BRZ (06-10-2013), RYU (06-10-2013), tokiokun717 (06-11-2013) |
#174 |
I'm going to assume my R2 set has all the updates? If anyone local wants to feel mine out you're welcome to. I'll be at the Vegas 86Expo as well.
BTW i'll probably not track my car till Scion comes out with a TSB for the direct injector issues so I wont be able to speak on track performance. |
#175 | |
#176 |
Drives: Attitude
#177 |
Drives: Some rust bucket
@Jackson, since there's a revalve, does the "update" change the way the shocks handle on the track (specifically the R2)? You mentioned that there's no sacrafice in track performance, but what exactly does that mean?
#178 |
I did mid-ohio today, the car felt great out on the track but the ride back home made me realize how difficult these are to run on the street. Hopefully the update will help correct the harshness/bounce issue but on the track...perfect! If only I could live on a track
2010 Cadillac CTS-V Sedan M6 w/550whp (Build Thread) ![]() |
| The Following User Says Thank You to swift996 For This Useful Post: | donutfilling (06-10-2013) |
#179 |
Drives: 2013 WRB BRZ
I agree at the limit they exhibit confidence but on the street was the only weakness I could find. Hopefully this update makes them a choice among many at the top.
Now to figure out how I am going to get the updated version after having sold off my oem struts and shocks ![]() Update: tried calling Mark but he was busy on the phone so left a message earlier in the morning - he must be getting alot of calls. Last edited by Squishy; 06-11-2013 at 03:24 PM. |
#180 |
Drives: Whiteout AT/FRS
hah...Well i just had my Pro street Coilovers installed over the weekend and I can see some of the complaints people are talking about. Even with the pro street setup I feel like I am feeling the bounce that everyone else is slightly complaining about. Springs feel a little more stiff obviously but it really does feel like it is constantly bouncing :/. I guess i should contact Eibach
WHITEOUT FRS/AT![]() |
#181 |
Site Moderator
Drives: Stuff
-Dave
Track cars: 2013 Scion FRS, 1998 Acura Integra Type-R, 1993 Honda Civic Hatchback DD: 2005 Acura TSX Tow: 2022 F-450 Toys: 2001 Chevrolet Corvette Z06, 1993 Toyota MR2 Turbo, 1994 Toyota MR2 Turbo, 1991 Mitsubishi Galant VR-4 Parts: 2015 Subaru BRZ Limited, 2005 Acura TSX Projects: 2013 Subaru BRZ Limited track car build FS: 2004 GMC Sierra 2500 LT CCSB 8.1/Allison with 99k miles |
#182 |
Do you think I could buy a new set with the changes and then I can send my old ones back for a refund. Gosh it would be such a hassle after i just put these on lol to switch out to stock suspension. Ship them back. Receive them again and then swap the suspension.
| Fortune Auto 500 Coilover Review | stoneman155 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 13 | 01-16-2020 06:22 AM |
| Coilover Review: FEAL SUSPENSION 441 coilover kit | mr. slim | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 39 | 11-28-2019 07:30 AM |
| ***Time to freak out, Eibach coilover pricing available**** | JoeBoxer | Brakes, Suspension, Chassis | 154 | 05-16-2013 06:30 PM |
| Eibach Multi-Pro-R1 VS KW v3 | thebear21 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 27 | 04-10-2013 02:32 PM |
| Eibach Coilover Options - SEMA 2012 Coverage | FT-86 SpeedFactory | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 45 | 01-25-2013 08:19 AM |
