#113 |
Drives: waiting for BRZ
Please post some more data from track days. With this or OEM cooler. Thx.
#114 |
Drives: 2013 Black FR-S
This is not a track oil cooler if you want to track in anything but winter weather.
#115 |
Really? :-) There are even cooler-free cars on tracks so there is a good reason to know numbers for people which are on track once per year.
#116 |
Airborne at your service
Drives: '17 BRZ Series.Yellow
I'm considering this kit with my supercharged car. I have the Perrin oil cooler, but I only daily my car and occasionally take it for a hard drive on the twisties, and feel it's overkill. Curious how this works with FI applications (track or daily).
#117 | |
Drives: Late 2014 Subaru BRZ
The cusco setup you cut lines to install. The forester xt you replace pipes and lines to match the direct Subaru setup for this block. There's a walk through on this forums but I'd be recommending different barbs then the guy uses. You want all 1 piece barbs and they can be purchased at jegs.com. I can give you links if you go that route. With a turbo you want the oil to get to operational temp as soon as possible. Both help that big time. Forester xt set me back about $180 complete at the time.
2014 Subaru BRZ
FBM Turbokit: GTX3076R - ECUTEK HRI FlexFuel tune - FBM 3" Turboback Exhaust - 550cc Injectors - Walbro 485 Fuel Pump - 4bar Map Sensor - FBM Oil Pan - ACT SB7-XTSS - AMSOIL all fluids - Forester XT Oil Cooler - Cusco engine, trans mounts - Whiteline rear differential bushings - Perrin shifter bushing - Firehawk 235/45/17 - AEM Failsafe |
| The Following User Says Thank You to GsxrMe For This Useful Post: | weederr33 (08-07-2016) |
#118 | |
#119 | |
Drives: 2014 BRZ
I bypassed the coolant lines that run to the throttle body for my XT Oil Cooler. Install was super easy. If you are running a GTX series turbo or another that is water cooled than you may want to think twice about the XT cooler as they use the TB lines for coolant. |
#120 | |
My car will never see a track and its driven 5-6 days a week. All Turbo Subaru's have this cooler and lines. So if its good enough for Subaru, its good enough for me. We dont need to reinvent the wheel.
2014 Subaru BRZ
#121 | |
Drives: 2014 BRZ
#122 |
Drives: 2013 Turbo FR-S Java Pearl
Also currently running this oil cooler and for DD its been working just fine. If you track then air/oil cooler would be better. Although for the DD this cooler works perfect especially when encountering stop and go traffic in congested areas.
#123 | |
The forest xt cooler doen't touch the throttle body lines like the turbo uses. The heat block under the oil filter is also great. All one piece and no leaks, oil or coolant.
2014 Subaru BRZ
#124 | |
Drives: 2014 BRZ
Ahh I see. Myself I bypassed and used the coolant lines that run to the throttle body. I always forget this is a "workaround" and the not the OEM setup. |
#125 |
So if I installed the oem style oil cooler, or the cusco, and don't drain my coolant... and I go to install it, will coolant go all over the place? Stupid question, I know, wanna fight about it?
#126 | |
Drives: 2014 BRZ Limited 6MT
| FT86 Suspension- D2/BC/Cusco/Megan/Tanabe/Tein/KW/Cusco/Ksport/Eibach/Perrin | JM Auto Racing | Brakes, Suspension, Chassis | 271 | 03-22-2014 01:17 PM |
| New Cusco oil cooler | ahaghshenas | Engine, Exhaust, Transmission | 11 | 04-02-2013 11:48 PM |
| Cusco Engine Mounts and Cusco Rear Diff Brace - Stiffen up your BRZ/FR-S!!! | RallySport Direct | Transmission and Driveline | 10 | 03-12-2013 03:11 PM |
| Cusco Rear Diff Covers!!! Cusco LSD Units! | vividracing | Transmission and Driveline | 0 | 06-18-2012 04:24 PM |
