#99 |
Drives: vrooom...
Let the man breath yo, he will post the info when he has the time.
#100 |
Drives: 2013 Scion FR-S Raven
My apologies to all for the tardiness of this update.
Data logging completed this afternoon, 91 F air temperature, another hot one! This is not scientific by any means. A/C was on the entire test. Full throttle runs through 4 gears, then heavy traffic, then Full throttle runs through 4 gears, no top end runs due to traffic. At no time did the power levels ever seem lessened by oil temperature. Wish I had a track to test this. Water never exceeded 197.6 F Oil never exceeded 224, in fact it was steady at 219.2 then the heavy traffic and an abrupt stop saw it peak at 224 then dropped to 219. Any movement at all and the water temperature dropped to 194 within 1/8 of a mile. Oil temperature stabilized at 208.4 at a steady 70-75 mph on the Turnpike at mid day, I think at night with IAT lower that it will run within 8 degrees of water temperature. It may not do what other coolers can do, but a normally aspirated automatic 4 cylinder with this oil cooler should live longer and not have oil temperatures that cause the ECU to strangle the timing during spirited driving. The engine, from an oil temperature perspective, never ran hot. One older data log showed 241 at midday on a spirited run, with the factory header and the air on, once. I believe the equal length headers have reduced engine temperatures as well, I can't prove that but it just seems to run cooler. Sorry if I'm off topic.
May'12 AT Raven, OFT V2, Perrin IntakeTube, Pulley & Overpipe,HKS Snorkel,FA20 EL Header,Nameless Frontpipe w/ Helmholtz, Crawford AOS, Cusco O2W Cooler, Grimmspeed Strut/MC Brace, Winjets w/D2S 3.0 HID by Illuminating Lighworkx, Fogs w/EU Stalk, LED's, JDM UnderPanels, Diffuser, Rigid Collars, Whiteline, HVT Camber Plates, Koni's, Swift Springs, GTSpec LCA, SPC Toearms, DBA 4K T-Slot Rotors, Ferodo DS2500, Vorshlag BrakeLines, MichelinPSS, 5Axis Wing, Raammat, Ensolite, JPM Coachworks, OEM+Ref400, 20mmspacers, TOMS
| The Following 4 Users Say Thank You to tonystewart For This Useful Post: |
#102 |
Drives: 86 GT MT
From Australia
see this post http://www.ft86club.com/forums/showp...2&postcount=82 |
#103 |
Drives: 2012 Toyota 86
Well, i cant speculate on temps without the cooler, but on fuji speedway the highest i saw was 252 on the VERY long strait. this was at WOT 200+kph. It would drop very quickly to 230s on the less full throttle portions. water temp never went too much above 200. ambient temp was in the 60-70's.
EDIT: also i compared it to my friends stock STI cooler and it seems to have a decent amount more surface area. Last edited by troek; 04-03-2014 at 08:44 AM. |
| The Following User Says Thank You to troek For This Useful Post: | CxG (04-25-2016) |
#104 |
Drives: 2013 Scion FR-S Whiteout White
Anyone using one of these kits with an aftermarket radiator?
#105 |
NASA SpecE30 Racer
It should install the same whether you put it on an OEM or an aftermarket radiator. Why do you ask?
- King Tut
Street/Track Car: 2006 Honda S2000 TT3 || Race Car: 1987 BMW 325is SpecE30 || Tow Vehicle: 2014 RAM 1500 EcoDiesel Sold Cars: 2012 BMW M3 || 2013 Subaru BRZ || 2012 Porsche Cayman R || 2009 Chevrolet Z06 || 2009 BMW M3 || 2004 BMW M3 || 2004 Nissan 350Z |
#106 |
I'm considering getting this oil cooler.
For 99.9% street, and the occasional AX or track day, I'd rather have my oil temps run a little high every once in a while, than have the temps run too low most of the time, and only reach proper operating temps when tracking. This cooler looks like it'll keep my oil temps around 200 on the street, and on track the temps might see 230-240. The posts I see of other oil coolers, street temps are 170-180 (too low I think) and get to 220-230 only when on track under super high load. |
#107 |
#108 |
Drives: Moped
Bumping an older thread to see if other members have any additional feedback on this oil cooler....
#109 |
Drives: Subaru BRZ
Highway cruising I get 226 F, Got AVO Turbo and koyo rad
#110 |
Drives: Moped
#111 |
Drives: Subaru BRZ
No I haven't made any recordings of temp pre install, but I can say that it is great at bringing temps down fast when you come to a stop or are in slow traffic.
When I am doing hard pulls/ spirited driving I have no problems getting the temp up to 266 F quicker then I would like, but as the turbo is oil cooled this is likely the reason. I have actually ordered an AVO oil cooler and it is going to be installed on top of the cusco to get the best from both As the Cusco is great at bringing cold start oil temp up and the thermostatic controlled AVO cooler will manage temperatures when driving with boost to bring temps down. Overall my opinion of the Cusco for FI application is that it is insufficient. |
| The Following User Says Thank You to ahaghshenas For This Useful Post: | Lonewolf (01-15-2015) |
#112 |
Drives: GT86
I data logged some temps with this cooler on track. As I mentioned in the post it cooled oil down faster than without it when you go off throttle.
This was also on 0W20 oil, so may be better with 5W30? Thought this would be of interest to anyone browsing this thread: http://www.ft86club.com/forums/showp...0&postcount=11 I also drive my car harder now so will try get some new data and share it in the next few weeks. |
| The Following User Says Thank You to lazyluka For This Useful Post: | mister.bond (09-18-2015) |
| FT86 Suspension- D2/BC/Cusco/Megan/Tanabe/Tein/KW/Cusco/Ksport/Eibach/Perrin | JM Auto Racing | Brakes, Suspension, Chassis | 271 | 03-22-2014 01:17 PM |
| New Cusco oil cooler | ahaghshenas | Engine, Exhaust, Transmission | 11 | 04-02-2013 11:48 PM |
| Cusco Engine Mounts and Cusco Rear Diff Brace - Stiffen up your BRZ/FR-S!!! | RallySport Direct | Transmission and Driveline | 10 | 03-12-2013 03:11 PM |
| Cusco Rear Diff Covers!!! Cusco LSD Units! | vividracing | Transmission and Driveline | 0 | 06-18-2012 04:24 PM |
