#43 |
You know we talk all about oil temps, has anyone really determined what the most efficient oil temp is for this motor?
Ever motor is different obviously but 230F is not out of the realm for most cars. Oil temps too low can also not be efficient. Did a search for oil temp data logs, and it seems either it is blown out of proportion or no one is logging.
#44 |
Drives: Sterling BRZ Ltd
I like this style, and its just that a different style. But yes a upgraded radiator probably makes sense but the Koyo for our car is actually really reasonably priced.
#45 | |
I Love custom Turbo kits
Drives: Limited BRZ
http://www.ft86club.com/forums/showthread.php?t=29965 I've seen 240 F Oil temp doing 6-8 pulls in the "street" on 80 degree ambient temperature. According to Perrin, power is lost (with Dyno to prove it) if I remember correctly above 230 F, so if that number is correct, you ideally want your oil temp between 200-230 F.
| The Following User Says Thank You to Sportsguy83 For This Useful Post: | Dezoris (05-22-2013) |
#46 | |
| The Following User Says Thank You to Dezoris For This Useful Post: | Sportsguy83 (05-22-2013) |
#47 | |
Drives: FR-S ultramarine
#48 |
Drives: FRS
Any idea on how to get a 230F thermostat? Could we reach out to mocal? Is there a universal solution we could use?
#49 | |
Drives: FRS
#50 |
Drives: GT86
You want the oil over 100C so the water can evaporate leaving just lubricant on your components. 105-120c is a good operating range for most oils.
| The Following User Says Thank You to ft_sjo For This Useful Post: | Sportsguy83 (05-26-2013) |
#51 | |
Drives: Black frs project
Price goes up in 24 hours. 15 installed no clearance issues now. Robi |
| The Following User Says Thank You to robispec For This Useful Post: | Sportsguy83 (08-16-2013) |
#52 |
Drives: Attitude
#53 |
Drives: Subaru BRZ
#54 | |
Drives: GT86
Comes with a graph as well: ![]() Looks like it actually decreases water temps!
#55 |
Drives: AVO BRZ
That is a side effect of running cooler oil. I have similar results with a fbm mocal cooler. Oil peak from 135 down to 115 and coolant more like 105 to 90 due to koyo radiator.
Impressive results from this little cooler it looks like a viable option and will create less heat soak than air-oil. The 230f power loss thing from Perrin must be tune dependant.
#56 |
Drives: 2013 Subaru SWP BRZ Limited 6AT
I've been paying attention to this type of solution. Hope they release one for the AT's.
Couldn't you source this from other Subaru parts and create your own? Or would that be too difficult to accomplish?
Man Law#17:A man in the company of a hot, seductively dressed, woman MUST remain sober enough to fight!
MODS: AVO tubes + filter, Cusco (F) strut brace w/ MC brace, Perrin CBE, Subaru OEM trunk tray, Grimmspeed front license re-locator & hood struts and Beatsonic rear cam. |
| FT86 Suspension- D2/BC/Cusco/Megan/Tanabe/Tein/KW/Cusco/Ksport/Eibach/Perrin | JM Auto Racing | Brakes, Suspension, Chassis | 271 | 03-22-2014 01:17 PM |
| New Cusco oil cooler | ahaghshenas | Engine, Exhaust, Transmission | 11 | 04-02-2013 11:48 PM |
| Cusco Engine Mounts and Cusco Rear Diff Brace - Stiffen up your BRZ/FR-S!!! | RallySport Direct | Transmission and Driveline | 10 | 03-12-2013 03:11 PM |
| Cusco Rear Diff Covers!!! Cusco LSD Units! | vividracing | Transmission and Driveline | 0 | 06-18-2012 04:24 PM |
