86WORX
Old 06-19-2013, 09:28 PM   #155
mid_life_crisis
Drives: FR-S 10 #103 AT
All the debating about what rpm spool is achieved and boost versus rpm graphs.
Who gives a rat's ass?! For a daily driver, that power curve is friggin gorgeous. What does all that crap matter if all you want is one hell of a lot of fun on tap?
Don't get me wrong, I understand curiosity, but you guys getting your backs up over this seems a bit too much.
mid_life_crisis is offline
The Following User Says Thank You to mid_life_crisis For This Useful Post:
zbt (06-19-2013)
Old 06-19-2013, 09:49 PM   #156
lbroskee
lbroskee's Avatar
Drives: 2023 WRB BRZ (MT)
I agree. But ppl lik me want a somewhat good spool time bc (yes i know its illegal so dont gimme crap) like to race our friends late at night withno traffic just for fun.
lbroskee is offline
Old 06-19-2013, 11:09 PM   #157
FAER
Drives: Silver BRZ
Quick spool is great, but there is very basic physics at work. You want quicker spool then you lose top end, u want top end then you lose spool.
Decide your highest power scenario and find a turbo that maxes out at or just beyond that, go dual ball bearing equal length runners, shortest pipe routes and enough room in your exhaust for it to breathe.
Really though this design of a kit with a gtx disco potato on e85 is going to be about the best street kit for someone who has no plans of creating a monster...
Me I'm actually going with a turbo even bigger than this one because a low comp block is in my future, along with 25-30psi
FAER is offline
Old 06-21-2013, 10:09 AM   #158
Element Tuning
Drives: Hydra EMS Powered FRS Raven Black
I picked a 60 trim because I knew down the road I needed big power (and this still may be too small) and I was willing to give up spool over the 50 trim. In my head before I knew of this kit I thought the 50 trim would be perfect if I was going to make a kit.
Now that I actually drive and race with the 60 trim it's just about near perfect because it delivers a smooth onset of boost which is so critical in maintaining traction. I don't know how it feels on a factory ecu but with the Hydra EMS it's stronger than oem right off idle, surges hard but smoothly and maintains grip exceptionally well except in 1st and 2nd which is just a burn out competition
While I do think the 50 trim might be the best choice for the 5 psi pump gas crowd, the e85 or meth guys running 10+ psi need to consider traction limitations.
Thanks,
Phil Grabow
Element Tuning is offline
Old 06-21-2013, 10:59 AM   #159
mid_life_crisis
My consternation was about the debating, which looked like it was going to get ugly.
I don't care if a turbo has technically spooled or not. All I care about is if it is making enough boost at a given rpm to provide the power I want. I may be misunderstanding what you guys mean by spooling, which I interpret to mean "making full boost" at a given rpm. If a turbo is capable of say 20 psi and all I need at low rpms is 5 psi, why do I care that it didn't make the full boost? If during its buildup to full boost, while it is "spooling up", it moves enough air to make the power I want at those lower rpms, what is the problem?
I know that some designers use what at first might seem like too large a turbo, planning on the fact that it will not spool up at low rpms, thereby naturally limiting the low rpm boost and protecting the engine from excessive low rpm torque. They know that even not fully spooled, it will move enough air to improve the bottom end over stock. It isn't a trade off, it is deliberate. The obvious bonus to this is the larger turbo can feed copious amounts of air to the engine at high rpm, making huge amounts of power where it is safe to do so.
Edit: Just reread your post and realized this is the same logic you applied to your setup except for traction management instead of preventing a blown motor.
Old 06-21-2013, 12:26 PM   #160
Element Tuning
Well many do not understand the concept that more boost doesn't always mean more power when comparing two different turbochargers. A large turbocharger could make the same power at 5 psi that a smaller turbo makes at 10 psi.
So you're right it's about the hp it makes for a given rpm. There really is no right or wrong turbocharger as long as it suits your needs or your goals. If you a lazy driver get something a little smaller but if you troll around at 3500 rpm + like I tend to size isn't so much an issue so something bigger and more efficient might make more sense.
Old 06-21-2013, 07:49 PM   #161
FAER
Drives: Silver BRZ
Spool happens extremely quick it's not linear... At 4000 u may be at 2psi with full spool by 4300... It's not 1psi per X amount of rpm with full boost at Y
FAER is offline
Old 06-21-2013, 07:54 PM   #162
lbroskee
lbroskee's Avatar
That's a SC they are describing, correct?
lbroskee is offline
Old 06-22-2013, 12:09 AM   #163
Element Tuning
If you mean full spool is 5 psi The 60 trim has a pretty smooth onset of boost as my logs from a mash at 2500 rpm, I'm seeing 1psi at 3100 rpm and it takes 2400 rpm to climb 13 psi. But if you're racing/starting from a higher RPM boost response is much quicker as in 500 rpm from no boost to 14 psi. Racers have no fear if you know what you're doing.
In higher gears you can hit 14 psi in the 4200-4500 rpm range.
The 60 trim I would say is not a quick spooler in the traditional sense but the smoother onset to higher boost levels meters horsepower almost perfectly (just starting to break traction throughout the rpm and I'm running a 285 slick). For me running an rpm range of 4k rpm to 8k rpm is nearly ideal for racing but I can street guys wanting 3500-7500.
Wish I had time today to hit the dyno as I'm curious what this baby is doing at 14 psi and e85!
Old 06-23-2013, 08:11 PM   #164
Black86
Black86's Avatar
Drives: 2013 Raven Black FR-S
Get a dyno soon so we can see what it makes man!
-Raven Black 13 FR-S : The daily driver
-88 supra turbo : 2jz 66mm single on E85 in the process
Black86 is offline
Old 06-25-2013, 08:06 PM   #165
Element Tuning
I know I'm really itching to see what 14 psi and beyond results in but so much customer work right now...just can't seem to make time. I'm unfortunately only running 750cc injectors which will not carry me far on e85.
Old 06-28-2013, 09:45 AM   #166
FeaR-S
Drives: Great White
Originally Posted by FA20Club.com View Post
Long day all around got to throw the car on the dyno to test our new base tune we finalized this week and decided to crank it up a notch and see how she liked it. Car runs even better on the new base tune than before and bumped up power on same 5psi level. When i ran her up to 10 psi we got 337hp 255tq. This was no timing changes mainly just the improved cam phasing and a few other things to make driveabilty better on the current kit. Next week we will complete the test with E85 on the same boost level and see what we get before we push it a little more. sorry just a crappy cell shot the dyno printer was dead. ill be back next week anyway so you guys get a sneak peek for now.
should be interesting as it cranks up more...
FeaR-S is offline
Old 06-28-2013, 05:22 PM   #167
lexusb3
Drives: FRS
hey dont worry if its a nice day out in florida on my next retuning appointment i may crank it up more !!! btw congrats on the win on the track with the fa20club kit
lexusb3 is offline
Old 07-08-2013, 07:01 PM   #168
[[|==86==|]]
[[|==86==|]]'s Avatar
Drives: Hakosuka
Any quarter mile data for reference?
[[|==86==|]] is offline
turbo kit, turbocharged fa20
Fa20Club.com Turbo Kit FASTEST IN FLORIDA lexusb3 Forced Induction 864 02-22-2014 11:00 AM
Visconti vs FA20Club vs Stock Tune Dyno Results mechaghost Engine, Exhaust, Transmission 153 07-08-2013 12:35 PM
FA20CLUB V2 Turbo Kit Progress FA20Club.com Forced Induction 40 05-17-2013 02:26 PM
JFlogerzi's FA20Club 91 and E85 Tune Results and Impressions jflogerzi Engine, Exhaust, Transmission 16 03-24-2013 02:09 AM
FA20CLUB.com Stage 1 ECUTEK Reflash Results FA20Club.com Engine, Exhaust, Transmission 20 08-25-2012 08:02 PM
