#43 | |
Drives: 2013 Asphalt FR-S
Asphalt FR-S: EcuTek Visconti STG2 tune, MAPerformance turbo kit, MAPerformance 3" exhaust, Hotchkis springs, Mach-V 17x9 Awesomes.
Build thread: http://www.ft86club.com/forums/showthread.php?t=30703 |
#44 |
Drives: Raven FRS MT
#45 |
Drives: 2013 FR-S whiteout
#46 |
Its normal, and good. We have electronically controlled camshafts that are adjusted depending on RPM and throttle input to help with power, torque, and efficiency. Most modern engines use some type of variable camshaft design today.
#47 |
Addicted
Drives: 2013 Asphalt FR-S 6MT
So... I was interested in this but after reading everyone's problems with this conversion do you guys think it is worth it? From what I am reading you have to deform the frame a little bit to fit the tubing and seems like a lot of people are having issues or CELs.
#48 |
Drives: 13 White MT FR-S
yeah you have to bend some metal, but its not structural at all, and you can't notice it. One person has reported a cel, and can't confirm that its from this mod. 2 people have confirmed that it solved all/most issues with the intake...I won't go back to stock.
#49 |
Scrape Master
Drives: Goal: Oldest FRS State Side
@ML so you got two 90 degree pipes and two straight pipes, do you know the length of the two straight pipes?
#50 | |
#51 | |
Red wine
Drives: Subaru BRZ(R.I.P)
buy this and use a hack saw and cut it to fit.. http://www.ebay.com/itm/3-5-89mm-Alu...a5b862&vxp=mtr Then use your creativity and shop for another 3.5" 90 degree tube and two 3.5" silicone holders and everything else that you will need.
#52 |
Scrape Master
Im having the hardest time trying to find a store that stocks 3" 90 degree pipe.
#53 |
I had Advanced Auto order it for me. I got it cheap though, so maybe you could try online.
#54 |
Drives: Brz
I had this done today,I have to say it's work, we just to cut the pipe, and bring down that frame to make it fit, plus all that bumper fun, I don't want to discourage anyone but you need to have some skills for this. On that note, soooooooooo worth it!
#55 |
Drives: Neptune GR86
It might be beneficial to put the plastic piece that you removed back on.
Perrin talks about it a bit in their blog on their CAI development. http://blog.perrinperformance.com/br...design-part-2/
| WTB: Injen intake | Obja | Engine, Exhaust, Bolt-Ons | 3 | 01-10-2014 10:20 PM |
| Injen Intake | seven | Engine, Exhaust, Bolt-Ons | 4 | 03-09-2013 02:40 AM |
| Does anyone in NE have an Injen intake | 2forme | New England | 2 | 10-28-2012 06:22 PM |
| HKS intake setup VS Injen intake,,,what are your thoughts? | JDMrolla | Engine, Exhaust, Transmission | 4 | 10-11-2012 02:31 PM |
