Old 04-12-2013, 06:12 PM   #85
BRZfan
BRZfan's Avatar
Drives: 2013BRZ Premium St Silver Metallic
There are several possible reasons for this installation:
1. Experimentation/product development.
2. Practicing speeding in reverse.
3. The owner of the car has minimal driving experience and is trying to 'prove' something to his bimbette girlfriend.
4. Did not follow installation instructions and will soon get a Big Surprise.
5. THe driver also puts his pants on backwards (see post #17) and can hardly walk let alone drive.
6. The drive doesn't know the difference between reverse lift, forward lift, up force/down force, as well as oversteer/understeer, toe-in/toe-out..
BRZfan is offline   Reply With Quote
Old 04-12-2013, 07:03 PM   #86
SubieNate
SubieNate's Avatar
Drives: 2013 FR-S Ultramarine
Originally Posted by naikaidriver View Post
Growing up in an aerospace household and after building countless flying model planes from scratch, I know a considerable amount about airfoils but I don't consider myself an "authority" on the subject. I work with aerospace engineers on a regular basis and I wouldn't dream of insulting their experience and education by labeling myself such.
The problem with what the guy has done here is that the design of that wing utilizes a basic airfoil (thicker at the leading edge and tapered to the trailing edge, similar to an airplane wing. To generate lift, the top of the airfoil is usually curved at a higher rate toward the leading edge and straightening out as it moves aft while the bottom is usually flat or concave. As air moves over the airfoil, it creates an area of low-pressure on top of the and an area of high-pressure below. This results in "lift".
Now on car-wings, this airfoil is inverted with the flat or concave surface on the top and the curved area on the bottom. This is how reverse-lift or "down force" is generated. The amount of "down-force" can be adjusted by altering the angle of the wing in relation to the air-flow. This is known as the "angle of attack". While down force can be increased in this manner (by tilting the front of the wing down), it also increases drag.
What this IDIOT has done by reversing the wing is render the airfoil backwards. This completely negates the aerodynamic properties of the design and increases drag. If you notice the little "lip" on the trailing edge of the wing, it is disturbing the airflow over the top of it to create an extremely turbulent, low-pressure area above the wing. So unless he were to compensate by tilting it dramatically, his wing is generating considerable drag while generating a little lift.
Scott
I AM an aerospace engineer.
And this post pretty much has all the right points. At that AoA it'll likely be producing some lift just from Newton's 3rd law. The air going under the wing is hitting that bottom surface and being deflected downwards (probably) so the wing is going to be pulling up on the trunk
Now, with that lip at the front of the wing and that AoA, it's 99% guaranteed flow is separating as soon as it hits the leading [trailing ] edge. So that's going to create a TON of drag.
Nathan
SubieNate is offline   Reply With Quote
Old 04-13-2013, 09:17 AM   #87
lemoncola
Guest
Posts: n/a
If i was the pedestrian, ill will smash that spoiler lol
Old 04-13-2013, 09:35 AM   #88
Slick
Slick's Avatar
Drives: FR-S Firestorm 6MT
Scott
Makes good sense, but biggest issue I see is that it is angled downwards.
Slick is offline   Reply With Quote
Old 04-13-2013, 09:43 AM   #89
Bristecom
Bristecom's Avatar
Drives: 2017 Subaru BRZ PP
Originally Posted by Saber_TRD View Post
He's driving a Scion, close enough.
Sadly, I wouldn't be too surprised if this was part of Scion's new 10 Series FR-S.
"In addition to the illuminated Scion logos in the front, rear, door sills, dashboard, and shift knob, we have now added a reverse spoiler for the ultimate in brand identification - now standard on all 10 Series Scion models."
*13 year old Mexican kid claps*
Ugh...
Bristecom is offline   Reply With Quote
The Following User Says Thank You to Bristecom For This Useful Post:
Anthony (08-18-2013)
Old 04-13-2013, 02:29 PM   #90
Hownet
Drives: 09 Honda Fit MT
I am getting BRZ instead of FR-S because of this car!
Hownet is offline   Reply With Quote
Old 04-13-2013, 02:56 PM   #91
autogyro
Drives: Toyota 86 GTS
The biggest problem I have with this is not the fact that it may generate some lift (I doubt it's more than 50 kg at highway speeds) but the potential for decreased rear end stability under braking and cornering. Now that would be dangerous if it makes an already tail happy but balanced car even more likely to fishtail.
autogyro is offline   Reply With Quote
Old 04-13-2013, 03:21 PM   #92
shiumai
shiumai's Avatar
Drives: 2013 DGM BRZ, 2020 C8 Corvette
since we're talking aerospace, thought i'd chime in for fun (my background is in aerospace). without seeing the actual cross section of the wing, i find it hard to draw a conclusion (besides the wing looking like it'll add drag) as to whether it's lifting or pushing down on the back of the car. the wing basically looks like a deep camber airfoil. but put on backwards, i'm not sure what that would actually do.
as for angle of attack, we can't assume that the direction of airflow is the same as the direction of travel of the car, because the air follows the contour of the top of the car and it may actually be hitting the front of the wing without a negative angle of attack.
so, performance-wise, i think it's hard to draw a definitive conclusion without more info. but, i think we all agree that the owner probably made a mistake and it looks stupid
shiumai is offline   Reply With Quote
Old 04-13-2013, 03:26 PM   #93
Kelbyat07
Poor College Kid
Kelbyat07's Avatar
Drives: ~.~
That car must have some crazy aerodynamics now
Kelbyat07 is offline   Reply With Quote
Old 04-13-2013, 04:21 PM   #94
FullTuneZN6
Novice Drifter
FullTuneZN6's Avatar
Drives: 2013 Asphalt FR-S
Originally Posted by raul View Post
Does anyone know the owner of this car? It HURTS to look at it. For those who can't spot what I'm pointing out. It's not the fact that it has a wing, it's the fact that it's backwards.
does that make UPforce?
FullTuneZN6 is offline   Reply With Quote
Old 04-13-2013, 07:55 PM   #95
xbreed
Drives: 2013 CBS BRZ Limited
Maybe the instructions were in Japanese?
xbreed is offline   Reply With Quote
Old 04-13-2013, 08:07 PM   #96
ftc~brz
Done
Drives: WRB BRZ
yep, just as funny today as it was yesterday!
ftc~brz is offline   Reply With Quote
Old 04-13-2013, 10:03 PM   #97
Carwhisperer
Drives: A lot of supercars.
Originally Posted by dsmx17 View Post
Good thing everyone knows the Frs is to underpowered to be at high speeds, damn 200hp...
had a pic of it on my phone until I dropped it in a bucket of water at work ( go figure )
6th gear at 151 mph running on NA on e85. Reguardless of it literaly taking about 2 minutes to hit that speed from a dig.
Carwhisperer is offline   Reply With Quote
The Following User Says Thank You to Carwhisperer For This Useful Post:
ftc~brz (04-14-2013)
Old 04-13-2013, 10:10 PM   #98
tuckdaddy
Because Racecar
tuckdaddy's Avatar
Drives: 2013 Asphalt FRS
Originally Posted by TheEradicator View Post
I laughed my ass off when I saw this picture because I saw a guy yesterday with an identical frs complete with an even bigger spoiler and in my neck of the woods you still don't see many frs's so it really stuck out.
His is facing the proper way. Still ungodly big for what his car has under the hood...
It did not take long at all for this to happen
tuckdaddy is offline   Reply With Quote
The Following User Says Thank You to tuckdaddy For This Useful Post:
Search this Thread:
Advanced Search
Giving her what she deserves 86 Legend ASIA 25 05-23-2013 02:28 PM
noob question. giving thanks? its_the_biz Site Announcements / Questions / Issues 2 02-16-2013 06:57 PM
Is your FR-S giving you any mechanical problems now? doctortt Issues | Warranty | Recalls / TSB 40 01-19-2013 02:06 AM
We're giving away 4 Firenza performance tires SCIONMONTREAL CANADA 13 01-18-2013 07:41 PM
The color choice is giving me migraines. pastuch CANADA 8 05-11-2012 10:36 AM
