86WORX
Old 01-22-2012, 07:38 PM   #85
Ryephile
Hot Dog
Ryephile's Avatar
Drives: quicker than arghx7
Originally Posted by 2fast4you View Post
..... Also, you have the issue of suspension travel: BMWs typically have less suspension travel ...
Are you making assumptions or do you have actual data?
"Wisdom is a not a function of age, but a function of experience."
Just Say No to unqualified aftermarket products.
Ryephile is offline   Reply With Quote
Old 01-22-2012, 07:43 PM   #86
2fast4you
2fast4you's Avatar
Drives: 2006 Scion tC RS 2.0
I don't possess the actual data, it's a generalization from engineers at H&R springs.
Brake. Turn. Accelerate. Repeat as necessary.
2fast4you is offline   Reply With Quote
Old 01-22-2012, 08:00 PM   #87
serialk11r
Drives: '06 AM V8V Coupe
Originally Posted by LSxJunkie View Post
One thing to remember about lowering a car is that you change the angle of the control arms and, additionally, the angle of the hubs. You can align around this, but you cannot align around the way you've changed the position of the wheel in it's travel arc. It is this change in suspension geometry that, although will not affect a street car in a debilitating manner, has led many a race team to use drop spindles to drop a car in conjunction with coilovers to corner balance and adjust damping. This also allows you to keep your full suspension travel.
Just food for thought. I doubt 97% of owners will be pushing their cars THAT hard, but it's something that anyone that does suspension mods should keep in mind. Especially for those of you who plan on slamming your cars.
Hey LSx, I'm curious about this and I seem to have a little trouble finding info on this...could you explain a bit more how to lower a car while preserving suspension geometry characteristics? From what I know it seems like most people either cut their springs (this messes up too many things to make me comfortable) or get coilovers that preserve the travel, but coilovers don't change the geometry.
I suppose suspensions have some flexibility to accomodate, for example, heavier loads, but the suspension can never behave as it was intended to if lowered like this.
Old 01-22-2012, 08:17 PM   #88
old greg
Rocket Surgeon
Drives: PSM GGA OMG
You'd need to either move the inboard suspension mounts, or move the outboard points in relation to the wheel (either with a custom/aftermarket upright, or something like Whiteline's extended ball joint kits).
A drop spindle, like LSxJunkie mentioned, is usually just like a stock upright, except the spindle or wheel bearings are moved vertically upwards on the upright. In this way, the entire car (suspension and all) is lowered and the suspension geometry is mostly unchanged (Scrub radius and trail will change, unless they are accounted for).
old greg is offline   Reply With Quote
Old 01-23-2012, 12:29 AM   #89
LSxJunkie
Douchebag
LSxJunkie's Avatar
Drives: 2014 Mustang GT
It's like rocket surgery.
Here - 2014 Mustang GT Track Package/Recaros - Koni Yellows, Boss 302 Springs, BMR SB041 Front Sway Bar, Boss 302 Rear Sway Bar, Boss 302 Wheels, GT500 Quad Tip Axleback, 2016 Legacy 2.5i Limited
Gone - 2010 RX350, 2006 GTO (2nd), 2007 RX350, 2008 IS250AWD, 2006 GTO, 2004 G35 6MT, 1992 SC400
LSxJunkie is offline   Reply With Quote
Old 01-23-2012, 04:12 AM   #90
serialk11r
Say you drop the car...0.5-1" with coilovers. Would that make a noticable difference in performance and wear? Or would drop spindles still be ideal?
With drop spindles, I don't see any issues with the front wheels, but doing that to the rear would move the drive shafts (is that what they're called?) a bit. Is this a problem at all?
Old 01-23-2012, 08:45 AM   #91
LSxJunkie
Douchebag
LSxJunkie's Avatar
For an inch drop, the change in geometry would be negligible for a street car. You won't need to run drop spindles. However, depending on the design, your set of coilovers may not allow you to set the ride height at only an inch drop. Manufacturers understand that people who run coilovers tend to want their cars to be low, so they run shorter bodies. To allow people to slam their cars while maintaining some semblance of shock stroke, sometimes the highest you can set them is 1.5" lower than stock. For such a mild drop, especially on a street car, I'd run shocks and springs instead of adjustable coilovers. They really are overkill on most cars.
Which brings up another point. If you're not going to go auto-x or HPDE, you really don't need coilovers. And if you're going to get them, remember that you may actually be HURTING your cars handling if you neglect to get your car corner balanced and aligned (so you get almost even contact at all four corners), set the preload (often overlooked), and then spend the time getting the dampers set right.
What you're concerned about is the half shafts. Don't be. The drop would barely move them, and they (this is true of all IRS cars) have CV joints to allow them to articulate with the movement of the suspension. And inch won't do anything to them.
Old 01-23-2012, 09:24 AM   #92
MrVito
Grumpy Old Man
MrVito's Avatar
Drives: 2016 Halo FR-S, 2010 Tundra, 80 626
I try to articulate everything you just said to most of the people I know that are just getting into cars. Something else that a lot of people don't consider is the spring perch placement on an adjustable coilover vs a stock style MacPherson strut. The spring perch on stock style MacPhersons locates the spring completely above the wheel and tire, leaving only the body of the damper behind the wheel/tire combo. Adjustable coilovers typically have the spring and perch situated much lower, which actually reduces the amount of wheel width/ tire width that can be fit within the wheel well.
Is it nice to be able to set the ride height exactly where you want it? Of course it is. Given the choice of adjustable coilovers or a quality spring with some nice Koni's though, I'll take the shock/spring combo every time. I know that I can get new shocks from the same manufacturer in a couple of years, but who knows if the company that made brand-x coilovers will still be around to rebuild them when the time comes. Now if it's a dedicated track car that you're trying to eke every last .01th of a second from, and have the knowledge/skills/patience to change the setup for every given track and track condition, then I'd say a fully adjustable coilover is a great idea.
On a slightly related note, I wonder how much quality camber plates will cost for this car?
2016 Halo FR-S, 2010 Tundra, 92 325i convertible, 80 Mazda 626, 62 Impala
MrVito is offline   Reply With Quote
Old 01-23-2012, 12:18 PM   #93
Racecomp Engineering
One thing that bothers me is when people suggest that ALL coilovers are automatically better than ALL spring/strut set-ups for every possible user. That's simply not true.
Some springs do suck really bad. Some coilovers suck really bad too. Sometimes a coilover may not be the right choice for how you use the car.
We make springs, struts/shocks, and coilovers and there are times when we'll recommend one set-up over the other (even if it would be nice if everyone bought JRZ 4 way motorsport coilovers every time they called, that might not work well for 99.99% of people ). We'll have all of the above for this car, and swaybars, and camber plates, and some other nice things but we know that different set-ups will work for different people.
The point is do some research, go for some rides, and educate yourself on what makes one suspension better for your particular needs. Learn to understand the advertising gobbly gook and understand when one "feature" is really just cost saving measure or total BS. There are MANY poorly designed parts out there that are marketed well enough that people don't question if the part works or not. Maybe they should.
- Andrew
Old 01-23-2012, 12:42 PM   #94
Ryephile
Hot Dog
Ryephile's Avatar
- Andrew
[This is not directed at you Andrew, in fact it's an opportunity for you to be "the better Tuner"]
...and this is where the automotive aftermarket makes a shining arse of itself. It's significantly easier, cheaper, and more profitable to make well-marketed crap products than to make well-marketed quality products.
The main problem isn't that consumers are naive [a virtual given], it's that there are no standards to which aftermarket parts are held. There's no way for the consumer to differentiate between crap and quality other than spending obscene amounts of money on experience and testing. Most people don't have the time or education to be bothered with figuring out how to make their car "better". They trust the Tuner. When the tuner is barely more knowledgeable than the customer, it makes for a lose-lose situation where everyone is mad because crappy products were used.
My proposal? Full disclosure of how the aftermarket offering makes the car better and worse than stock.
Take for example KW coilovers. Their Suspension Techniques line takes V1 valving and builds it from cheaper components. This might be fine for someone on a tight budget in the arid southwest USA, but will be a failure waiting to happen in the Rust Belt. Furthermore, the valving and oil used in V2 and V3 dampers are significantly better than V1, making them more consistent and better overall performers. This is a case where money buys you quality, but as some of us know, this is rarely the case.
So, "doing research" rarely involves the internet, and usually involves simply buying everything and figuring out the one or two products that actually work. It would be helpful if the Tuner actually helped the customer instead of simply offering a wall of products with zero knowledge of them.
Food for thought.
Old 01-23-2012, 02:38 PM   #95
Roger that....I agree.
We do plan to do our best to educate where we can and explain how things work, along with advantages and disadvantages. Having been in this line of work for 7 years now (add a lot more for Myles the owner) it used to bother me to see the reality of how the suspension tuner market operates....with most "suspension" companies having no clue what works and what doesn't and still managing to control the market simply through saturation and advertising. It bothered me when we unwittingly did some (really basic) R&D for some of them....and I don't mean that in a ****y egotistical sense because it was basic suspension 101 stuff. But being open and educating people is good for us and good for everyone.
Those that really care about function and improving handling is a niche market that we are happy to cater to. And a growing number of people are getting it. Makes me happy. Ha. I'll stop ranting.
- Andrew
Old 01-23-2012, 04:32 PM   #96
Dimman
Kuruma Otaku
Dimman's Avatar
The geometry has a bit to do with roll-centers. The assorted points and pivots in the suspension form a variety of intersections/centers that affect how the forces play on the car. And since the suspension moves, the centers move too. The engineers jobs seem to be minimizing how much they squirm around as the suspension cycles through its designed travel. Then there is also how the camber changes as it moves.
Umm, kind of realizing that I'm out of my league explaining this...
Any of the more knowledgeable suspension guys want to expand on Roll Centers and Camber Gain/Loss?
Because titanium.
Old 01-23-2012, 04:54 PM   #97
MrVito
Grumpy Old Man
MrVito's Avatar
If you REALLY want to learn about suspension, (not to mention metallurgy and other interesting automotive info) pick up "Engineer To Win" by Carrol Smith. He's written a number of technical books on the subject of race cars, but a lot of that information can be taken and applied to your toy car. I have to admit it's a heavy read, but I still refer back to that book on a regular basis.
Old 01-23-2012, 05:31 PM   #98
Ryephile
Hot Dog
Ryephile's Avatar
Originally Posted by MrVito View Post
... pick up "Engineer To Win" by Carrol Smith....
His whole series is great. Fundamental reading IMO.
We do plan to do our best to educate where we can and explain how things work, along with advantages and disadvantages. ........
- Andrew
PM returned
We can do our best to intelligently inform consumers, but in the end, clearly communicating the expectations to the customer will result in a happy sale.
Search this Thread:
Advanced Search
Toyota FT-86 II Concept Height Estimate Study Sea1monkey2 Scion FR-S / Toyota 86 GT86 General Forum 49 06-20-2012 02:36 AM
Lower ride height in NYC? blur NY / NJ / CT / PA 9 01-19-2012 07:31 PM
please explain the different lower front lights on US spec BRZ torquemada BRZ First-Gen (2012+) -- General Topics 30 12-04-2011 01:18 AM
quick question about the height.. VenomRush Scion FR-S / Toyota 86 GT86 General Forum 13 12-22-2009 11:42 PM
