| FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum All photos, videos and other media related to the Scion FR-S and Toyota 86 |
#15 |
I bet if you pressed down on the edges while peeling the tape away would help. Or maybe even lightly cutting across the tape line. I wouldn't do that one, because I wouldn't trust myself to not fuck up the paint.
#16 |
#17 |
Diesel Tech
Drives: 2013 FR-S Hot Lava 6MT
Im doing this when it gets warmer out. Ill post some pics how I did it. Plasti dip has many videos on youtube, just do a search. They are very good, tells you how to do perfect lines. You spay it on heavy on the edges, then pull your tape when its still wet. They also plasti dip entire high end cars, lambos, GTRs, etc. No need to worry about hurting the finish. Hope this helps.
#18 |
Drives: 5th Gen Toyota 4Runner
Looks good. Thinking about doing the same.
#20 | |
Drives: Lava FR-S
I gave it about 4-5 coats total. Just let it sit there for about 20-30mins and get a razor blade (brand new recommended) VERY VERY lightly start slicing along the masked cut off line. Don't be dumb slicing it with a full pressure where you're going to hurt the paint. A very little amount of pressure will rip the plasti dip right off
HOT LAVA FR-S
| The Following User Says Thank You to EPIKsung For This Useful Post: | DBacon1052 (04-09-2013) |
#21 |
Drives: Lava FR-S
HOT LAVA FR-S
#22 |
Diesel Tech
Finally did mine, pulled tape off while it was still wet. No worries about your paint and a razor blade! First time Ive used this, was worried about the finished look while it was drying. Turns out great, dont second guess it.
#23 |
Drives: tC
^^wow that does look factory
#24 |
Drives: Argento FR-S
#25 |
Diesel Tech
Thanks guys. It turned out amazing. I started with one full light coat, did a second just in the middle, then a heavy 3rd coat and pulled the tape lines off right away. Got one hardly noticeable run under the front edge. Nobody would ever notice. I'll post a close-up of the edge when I get on the laptop.
#27 |
FRS Adept
Drives: Firestorm FRS
beautiful. how many coats ? is there a clear coat you can apply ?
| Plasti-Dipped Wheels | hobojoker | Cosmetic Modification (Interior/Exterior/Lighting) | 274 | 07-24-2015 11:02 AM |
| Plasti Dipped Gold Wheels | Khalis | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 72 | 07-10-2014 01:37 PM |
| Plasti-dipped my side mirrors | mike_ekim1024 | Cosmetic Modification (Interior/Exterior/Lighting) | 6 | 03-25-2013 11:00 PM |
| red plasti dipped rims on a FR-S/BRZ | terrypm | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 2 | 12-12-2012 06:53 PM |
| Dipped and De-badged | Jaylyons1 | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 2 | 12-02-2012 01:57 AM |
