#85 | |
Drives: nissan frontier, DGM MT BRZ
| The Following User Says Thank You to Lee358 For This Useful Post: | chuchutrain (07-16-2013) |
#86 |
Drives: Firestorm
#87 |
Drives: 86 GTS
Without camber they will poke a little and you can't dial in any negative camber as the tyre is too close to the std strut. But they effectively just fit.
#88 |
Drives: Firestorm
Camber is the wheel axis angle relative to the ground right? Would 17x8 or 17x8.5's with less than +45 offset be better?
#89 | |
| The Following 2 Users Say Thank You to Lee358 For This Useful Post: | chuchutrain (07-17-2013), David L (11-12-2017) |
#90 |
Drives: Firestorm
Man. That looks great. And there's no rubbing, it just looks super close? Do you recommend a +38 if they make them?
Sent from my LG-E970 using Tapatalk 4 Beta |
#91 |
Drives: 2013 WRB BRZ
The only +38 I ever saw in RPF1's were a limited run of 17x8.5's and they list them but have none on the market I know of except that limited run.
I have 17x9 +35 and it will rub up front unless you get some negative camber (I am running coilovers with camber plates so it fits just right). In rear the 17x9 +35 fit flush already on 245/40/17 all around. |
#92 |
Drives: FR-S [Hot Lava]
@chuchutrain
A 17x9 +45 won't rub except on a full lock as I mentioned above. A +35 would be like adding a 10mm spacer to a +45 which is what my car has on it in the photos on the earlier posts. +35's would be pushed out toward the fenders. The photos where the car is in the garage not in the driveway shows what I'm talking about. I have no idea about the 8 inch wide wheels... |
#93 | |
Drives: 86 GTS
they only come in 17x8+45 not 8.5, this would be the best size if you are not modifying suspension at all. you could go 17x8 +35 if you want to add a little front camber, it will both be more functional and look like it fits better. |
#94 |
"Patience young Padawan"
Drives: 2017 Crystal White BRZ
Wheels
Are your hubs 5x100? or did you convert them?
#95 |
#96 |
#97 |
17x9 +45 tirerack or any normal wheel store... +35 special order from a vendor on the forum.
#98 |
Drives: 86 GTS
17x8 & 17x9 in both +35 and +45 are present in the Enkei catalogue
| Wheel Directory: Enkei RPF1 17x9.0 +35 | D1cker | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 800 | 10-22-2023 01:00 AM |
| Wheel Directory: Enkei RPF1 18x9.5 +38 | FRS8SIX | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 297 | 02-15-2018 04:50 PM |
| Wheel Directory: Enkei Kojin 17x9.0 +45 | Clipdat | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 42 | 08-02-2016 05:18 PM |
