Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > FT86CLUB Shared Forum > Regional Forums > AUSTRALIA
AUSTRALIA Australia and New Zealand
Old 04-03-2013, 10:42 PM   #15
SkullWorks
Drives: SSM LT MT BRZ
On the DBA subject,
I have always thought DBA to be a superb manufacturer of Rotors, I recommended a friend who tracks his stock drivetrain 350Z to buy DBA's he did his research came to the same conclusion as me...good stuff...bought the full set.
Now we are not strangers to brake systems, pads were properly bedded to rotors, driven on for about 1 week of DD use until our next track day. he almost made it through the 3rd session before the rotors were THRASHED, they didn't even last as long as the factory set of rotors, we were not using a necessarily abrasive brake pad (can't recall the compound we used but it was a dual purpose track pad)
I still don't want to think it was just bad rotors but we eliminated every variable we could and the brake system was otherwise 100% rebuilt when the rotors went on, and functioning perfectly...he gave up and now has the 370Z brakes (akebono or akenobo...whatever i always get it wrong) those actually work...
EDIT: ALL FOUR were thrashed
SkullWorks is offline   Reply With Quote
Old 04-03-2013, 10:55 PM   #16
keen as
keen as's Avatar
Drives: 86 GT MT
I installed second hand GTS brakes to my GT.
All good. And fit under stock 16" rims.
I feel slight firmer brake pedal that is probably due to brake fluid flush and braided stainless lines.
I haven't tested it at the track to see if any difference in fade after a few laps. I expect only a marginal improvement. It is a very mild upgrade.
keen as is offline   Reply With Quote
Old 04-03-2013, 11:08 PM   #17
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
I've got a set of GTS front rotors sitting in my garage waiting for my GT to arrive. Was it a direct swap over without requiring any brackets/spacers?
Fizz is offline   Reply With Quote
Old 04-04-2013, 12:32 AM   #18
000 Racing
000 Racing's Avatar
Drives: 2012 86GTS Race Car #86
Hi guys, yes for the swap just a direct bolt on with the rotor upgrade to suit.. Quick and no issues. If you can get a set.. I do have a set of GTS front Calipers and GT front and rear plus GT factory rotors all new.
As for the DBA issues I will talk with them and have them look at the comments to see if there is any comment..
000 Racing is offline   Reply With Quote
Old 04-04-2013, 01:58 AM   #19
keen as
keen as's Avatar
Drives: 86 GT MT
I changed the whole rotor/caliper for front and rear. Bolt on, no problems.
It sounds like you have GTS front rotors and want to fit with the GT calipers. I did NOT test fit the GTS rotors with the GT calipers.
Regarding the front GTS calipers. It is easy to get a second hand set of these from the wreckers. I have a spare set from a forrester. Also available from outback/liberty/wrx that use the same size rotor.
The rear GTS calipers are more difficult to get second hand. I think they are the same as more recent WRX STI (using the sliding caliper) or Outback H6. This needs to be checked.
Old 04-04-2013, 12:30 PM   #20
Blue86
Drives: Sonic Blue 86GT Manual
So the master cylinder and all that shit is the same between the GT and GTS
Blue86 is offline   Reply With Quote
Old 04-04-2013, 12:42 PM   #21
Nezz
86DESU
Nezz's Avatar
Drives: 86 GTS, S13, CB9
I'm going to go braided lines and Essex fronts, after some investigation. And yeah, master cylinder is the same.
Careful. It's contagious!
Nezz is offline   Reply With Quote
Old 04-04-2013, 09:47 PM   #22
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
Thanks mate....yes correct. But just curious what made you swap over the calipers as well? Isn't the calipers on the GT and GTS exactly the same (100% identical)? I thought the only difference were the rotor size for the fronts, and vented rotors for the rear but again with same calipers across both models?
Old 04-04-2013, 10:17 PM   #23
000 Racing
000 Racing's Avatar
I think you will find the caliper brackets need to hold the caliper further away to accommodate the bigger diameter rotor..
From memory the calipers for the GTS looked different to the GT.. plus the bracket held it out further.. hope that makes sense
Old 04-04-2013, 10:44 PM   #24
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
Aah....ok yup gotcha....
Old 04-04-2013, 11:00 PM   #25
jello
Drives: DC5R
All this talk about upgrading GT rotors and calipers to GTS ones, or swapping GTS calipers to old WRX monoblocs, I did a bit of googling, and found these brand new reproductions of the MY99 era 4 pots...
http://www.ebay.com.au/itm/SUBARU-IM...-/261156802187
Thoughts? They would be a direct swap, right?
jello is offline   Reply With Quote
Old 04-04-2013, 11:57 PM   #26
keen as
keen as's Avatar
Drives: 86 GT MT
I test fitted a second hand set of front calipers. They bolt straight up and compatible with the GTS sized front rotor.
But the face of the caliper didn't fit the standard 16" rims. Need a spacer or different rim/offset to fit. (I think spacers are illegal in NSW)
Old 04-05-2013, 08:47 PM   #27
000 Racing
000 Racing's Avatar
Yup, I know they sell them in Auto Barn but don't trust spacers ... they will stop the hub from locating and if you get the cast alloy type they can crack.. also they can cause vibration and pad knock off... I needed a quick set of rear wets the other day so I went to Ozzy Tyres and got some XXR 227's I think in 17 x 7 and they were $250 each.. I know they do the 530 in 17 x 8 or 8.5... anyway I thought I would try them over my big AP calipers on the front and fitted no probs..
The Team Dynamic Race wheels I got specifically made with my 35 offset .. I know you can get them in QLD for about $282 for 17 x 7 and $378 for 17 x 9 if you offset.. these are the Pro Race 1.2 and likely to be the strongest wheels on the market.. Look for Racer Industries ... just a few more options .. except they all cost $$$$
Old 04-06-2013, 09:10 AM   #28
Turdinator
Seņor Member
Turdinator's Avatar
I picked up a set of GTS brakes today. When I get around to installing them I will post some comparison pics to the GT discs and calipers for future reference.
1974 TA22 Celica
2013 86 GT
Search this Thread:
Advanced Search
gc8 4 pot brakes wholeeoh Suspension | Chassis | Brakes -- Sponsored by 949 Racing 53 05-15-2022 05:38 PM
Who wants to see Wilwood Brakes vs. AP Racing Brakes ( Sprint Kit ) FT-86 SpeedFactory Suspension | Chassis | Brakes -- Sponsored by 949 Racing 119 12-17-2017 06:53 PM
Tundra brakes on frs? EZWood Suspension | Chassis | Brakes -- Sponsored by 949 Racing 42 08-31-2012 12:13 PM
OEM Brakes? marinjim Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 3 08-20-2012 11:26 PM
GT brakes jello AUSTRALIA 2 06-10-2012 10:10 AM
