#43 | |
Drives: 2013 FR-S Ultramarine
Would I run these? Not unless I did the calcs for the bias. But if the bias isn't shifted negatively, I don't see how there's any reason they should fail compared to using them on a WRX. Cheers Nathan |
#44 |
Drives: Attitude
Referring to Wilwood's post? It sounds like marketing bullshit. Tire compound has more to do with braking than tire diameter...
| The Following User Says Thank You to OrbitalEllipses For This Useful Post: | 2013GTRNate (02-02-2015) |
#45 |
#46 |
Professional Smartass
Drives: White Out FRS
This has to be the most asinine thread I've ever seen. The FRS/BRZ uses the same brakes as the 08 WRX. So naturally a user purchases a wilwood kit for an 08 WRX. People lose their shit and a wilwood rep comes in here and specifically says they will fail if tracked.
This doesn't make any sense. People are tracking their car with stock brakes and upgraded fluids and they aren't out right failing. How on earth could a wilwood kit be that shitty that it's only marginally better than stock? Wilwood is just trying to scare everyone with a BRZ or FRS into buying "86" designed rotors and calipers. I bet most people, myself included, don't track their car hard enough for these to fail. If you're that scared of the heat run brake ducts. I'm just going to keep face palming. |
| The Following 9 Users Say Thank You to post_break For This Useful Post: | andrew4554 (11-08-2020), Anthony (11-18-2014), DAEMANO (12-10-2014), diss7 (10-28-2013), mfbmike (10-30-2013), Scooby South (04-04-2013), SuperTom (06-08-2018), swift996 (04-04-2013), Wayno (05-26-2016) |
#47 | |
Drives: Attitude
Wilwoods probably fail because they're Wilwoods, lawl. |
| The Following 2 Users Say Thank You to OrbitalEllipses For This Useful Post: | 2013GTRNate (02-02-2015), Sammakko (07-25-2015) |
#48 | |
![]() Most kits use a 28mm thick rotor, and 16mm pad. The Essex "Sprint" kit uses a 32mm thick rotor and 21mm pads. Are there published specs for the Wilwood?
#49 | |
Drives: Attitude
![]() "Width (In.): 0.81" Thin rotors. |
#50 | |
20-21mm rotors... wow. |
#51 |
Drives: Attitude
#52 | |
Conedancer
Drives: 2013 Subaru BRZ SWP
Bill
Join my BRZ/FRS FB Group ![]() Thanks to:Kartboy/Wheeldude/Nameless Performance /Gaurd Transmission LSD |
| The Following User Says Thank You to Scooby South For This Useful Post: | DAEMANO (12-10-2014) |
#53 | |
Drives: Attitude
#54 |
Conedancer
^^^ yep.. thats why the personal interest.....Trust me I had these researched LONG before I was able to purchase them.. just didn't realize the rotors were thinner than stock by 1.5 mm.. everything else would have worked according to the rules.
Bill
#55 |
WRX Kit:
Type: Dynapro Radial Mount Piston Count: 4 Piston Area (In²): 4.12 Piston Type: Aluminum Mount Type: Radial Brake Pad Area (In²): 6.36 Brake Pad Volume (In³): 3 BRZ/FRS Kit: Type: Forged Narrow Superlite 6R Piston Count: 6 Piston Area (In²): 4.04 Piston Type: Stainless Mount Type: Radial Brake Pad Area (In²): 8.2 Brake Pad Volume (In³): 3.8
2010 Cadillac CTS-V Sedan M6 w/550whp (Build Thread) ![]() |
| The Following 2 Users Say Thank You to swift996 For This Useful Post: | DAEMANO (12-10-2014), Scooby South (04-04-2013) |
#56 |
Drives: Attitude
Looks like the 6pot moves bias even further rearward, with 12.88" rotors that are 1.1" thick.
| Wilwood Big Brake Kit Installed | msile | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 52 | 03-03-2014 03:00 PM |
| FS: WISC. BNIB Wilwood Front BBK | Scooby South | Brakes, Suspension, Chassis | 4 | 03-10-2013 04:22 PM |
| Wilwood BBK | Slartibartfast | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 59 | 01-08-2013 10:12 PM |
| help on Wilwood brakes brackets | Turbo Den | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 0 | 10-01-2012 09:14 PM |
