#15 |
Drives: 2012 BRZ Premium WRB 6MT
So what is Wilwood's official position on the use of this '08+ WRX brake kit on the FT86 chassis (the subject of this thread)? Is it safe? Has it been tested? How does it impact bias? Is it recommended?
Jeff Ritter|Mgr.- High Performance Division
Exclusive Importer AP Racing and Ferodo Racing www.essexparts.com ![]() |
#16 |
Drives: B9 S4/ND2
I'm not seeing the giant benefit to these. I understand they look good and the weight savings are there, but if the rotor is barely bigger and actually thinner then you're not really increasing thermal capacity?
If the bias is preserved or put more towards the rear then you're in good shape, but I see this as not being worth doing until that is figured out. |
| The Following User Says Thank You to D1cker For This Useful Post: | CSG Mike (04-02-2013) |
#17 |
Drives: 2013 FR-S Ultramarine
The aluminum hat has the potential to increase thermal capacity and efficiency but that depends on the amount of material there. Also, if the disc is floating it will be subjected to less stress as it heat cycles.
#18 |
Drives: 2013 Scion FRS
A WRX kit that has a 5 x 100mm bolt pattern will fit but it’s not the best option for the FT86. Although the car is lighter than the WRX, the wheels and tires on the FT86 are larger in diameter. If the WRX kit 140-9193 was used for the street only and some autocross, it would survive; however, if you tracked this kit on this car, it would fail…. We want customers to use the 12.88” kit engineered specifically for the BRZ/FR-S and coincidentally don’t show kit 140-9193 as an option for the FRS/BRZ even though it can be bolted on.
| The Following 21 Users Say Thank You to WilwoodDiscBrakes For This Useful Post: | acro (03-22-2015), Anorexic 86 (04-03-2013), Anthonytpt (04-03-2013), ATL BRZ (08-28-2013), Brzzee (04-03-2013), CSG Mike (04-04-2013), D1cker (04-02-2013), DAEMANO (11-25-2014), fred_boosted (10-12-2013), FT-86 SpeedFactory (04-03-2013), G-Man (10-29-2013), industrial (04-02-2013), Lee358 (04-02-2013), mfbmike (09-12-2013), Pat (12-21-2014), PWBRZ (03-18-2015), rs999 (08-21-2014), schtebie (04-04-2013), Spartan65 (04-02-2013), Touge Factory (04-04-2013), Trap63 (09-12-2013) |
#19 |
Out of curiosity, how does a larger wheel diameter affect the brakes? AFAIK most WRX's run 225/45-17 or 205/55-16 which have practically the same outer diameter as our car's 215/45-17's (actually, ours are slightly smaller than the 225/45's). So if someone upgraded the wheels on the older WRX's to 17's (Extremely common) these brakes would fail? That doesn't seem right.
I'm not questioning that the bias etc isn't correct for this car, but a mechanical failure seems odd. Nathan |
#20 | |
2010 Cadillac CTS-V Sedan M6 w/550whp (Build Thread) ![]() |
| The Following 2 Users Say Thank You to swift996 For This Useful Post: | DAEMANO (11-25-2014), Scooby South (04-03-2013) |
#21 |
Trim the Fat & add Boost
Drives: sometimes I fly
I think it's closer to 11.5 lbs. weight savings per corner... not 16 lbs.
Complete OEM front: rotors, pads and calipers weigh 60 lbs. all together. Complete Wilwood WRX front kit weighs around 37 lbs. And the new front 6 pot FRS/BRZ Wilwood kit weighs 48 lbs. all together... saving 6 lbs. per corner. |
#22 |
Drives: 2013 Whiteout FR-S
Whoa nice
#23 |
Conedancer
Drives: 2013 Subaru BRZ SWP
You guys realize...that the FT86 Stock front brakes ARE 08 plus WRX Brakes ..don't you??? Same calipers...and same MC... and Same Rotors.. after 13 years of experience in Subaru's...WRX/STi and now the FT86... I can say without one Shadow of a doubt..the the Wilwood kit will work on FT86's chassis.. Just like an 08 plus WRX/STi Rear Sway bar will work also.. You guys can criticize dynamics all you want.. and you can make all the assumptions that you want.. manufacturer or otherwise.. Of course they want you to buy Specific FRS/BRZ fitment... but fact of the matter is there's alot more options out there than people Realize. Just like the Factory 86 Rotors... you can interchange them with 02-07 WRX Rotors... that are 2.6lbs lighter per corner than the stock 86 rotor.. Same exact diminsions...
Marketing is a wonderful thing... Bill
Join my BRZ/FRS FB Group ![]() Thanks to:Kartboy/Wheeldude/Nameless Performance /Gaurd Transmission LSD |
| The Following 14 Users Say Thank You to Scooby South For This Useful Post: | andrew4554 (11-08-2020), Anthony (11-18-2014), Anthonytpt (04-03-2013), DAEMANO (11-25-2014), DAN_BRZ (10-29-2013), diss7 (10-28-2013), mfbmike (10-30-2013), niceguy21 (10-29-2013), Pat (12-21-2014), SubieNate (04-03-2013), swift996 (04-03-2013), Turbo Den (04-04-2013), Wayno (05-26-2016), why? (10-14-2015) |
#24 | |
Conedancer
Not true... I have the proof.. 16.75 lbs per Corner.. Stock brakes are about 31lbs per corner.. ![]()
#25 | |
Conedancer
YOU ...need to relax... not my first rodeo.... ![]() Bill
#26 |
I unfortunately didn't get any performance data points from the OEM brakes but will try to find another OEM BRZ/FRS local to do a comparison.
The brakes are feeling great. They just renew my confidence in the car. It gives it a very inspired feeling. I wish this is how the OEM brakes were. Also the noise that I spoke of has gone away, I'm guessing it was just the pads bedding.
| The Following 3 Users Say Thank You to swift996 For This Useful Post: |
#27 |
Drives: 2021 Supra / 2022 Tundra
Interesting about the diameter since most BRZs are using the same diameter we use on WRXs for autocross AND street use, 255/40/17. I find it interesting the concern of using a brake package designed for a heavier, more nose biased car with more power inappropriate. I'd love to see the math that could back up the claim so we could all understand.
TomR
| The Following User Says Thank You to ABQautoxer For This Useful Post: | Scooby South (04-03-2013) |
#28 | |
Drives: Attitude
| Wilwood Big Brake Kit Installed | msile | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 52 | 03-03-2014 03:00 PM |
| FS: WISC. BNIB Wilwood Front BBK | Scooby South | Brakes, Suspension, Chassis | 4 | 03-10-2013 04:22 PM |
| Wilwood BBK | Slartibartfast | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 59 | 01-08-2013 10:12 PM |
| help on Wilwood brakes brackets | Turbo Den | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 0 | 10-01-2012 09:14 PM |
