#57 |
bite has a big difference compared to stock and the other brake pad i've tried, when braking at the track at my normal spots, i have a couple of meters left than usual.. only issue is that it tends to fade after 2-3 laps of hard braking
after 2 light trackdays, i gave up on them and sold it to a friend for a cheap price like less than $100 for a set (front and back) and he did feel also the brake fade and used a diff set
2013 Toyota 86
Sterling Silver Metallic IG: @pcuerpo.images |
#58 | |
#59 | |
I've since switched to a dedicated track pad and they are wearing much better. If you track frequently, I'd skip these pads and go with something designed for track use.
2022 BRZ Build 2013 FR-S Build |
#60 | |
#61 |
Haha or I'm just slowing down more for corners than everyone else!
| The Following User Says Thank You to DarkSunrise For This Useful Post: | CSG Mike (10-08-2015) |
#62 |
Drives: BRZ WRB Pearl Limited Manual
How do you turn OFF the ABS of BRZ/FRS? Doing the pedal dance will turn off the ABS of this car?
#63 | |
Drives: 2015 CWP BRZ Limited
EDIT: To clarify, I don't mean that turning off your ABS is always a bad idea. I just don't think it's necessary for brake bedding. Good threshold braking has been sufficient on every car that I've bedded brakes on. There's sometimes a thin margin before lock-up, past where the ABS would usually engage, but it's a very small margin, if at all, so I don't ever bother to disable the ABS to bed brakes. Last edited by jawn; 10-08-2015 at 01:38 AM. |
#66 |
Drives: Acura TSX
Sorry to bump an old thread but what is the proper breaking in process for these? Bought a set someone had BNIB. Also are you guys running them without a backing plate?
I have almost the same setup as the OP except running the DBA T2 on all 4 corners |
| Megan Racing Coilovers - Street / Track / EZ STREET - Starting at $699 Shipped | GuerillaRacing | Brakes, Suspension, Chassis | 149 | 05-12-2015 06:53 PM |
| Project Mu HC+800 Pads | Anthonytpt | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 22 | 04-08-2013 03:48 PM |
| Street/Clubsport brake pads for your BRZ and FR-S | HP Autowerks | Brakes, Suspension, Chassis | 4 | 02-20-2013 02:34 PM |
| Street/Clubsport brake pads for your BRZ and FR-S | HP Autowerks | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 2 | 10-15-2012 08:03 PM |
| Different pads for street and track | Captain Snooze | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 11 | 08-01-2012 03:55 PM |
