#15 |
Dismember
Drives: 2013 Red Scion FR-S
You might have a weak battery. Cold mornings would make it apparent. Try a battery tender or block heater. You're on your own for the tire. I'd get a stock one until the rest are worn. Then I'd switch to Michelin super sports.
#16 |
Drives: DGM Limited BRZ
Ok thank you guys, I'll just eat this one.
#17 |
Sounds like the biggest problem with the car is that they put a transmission in it that shifts itself.
#18 | |
Member of the year - 2016
Drives: Scion FRS
I'm sure when you drop into 2nd you get a real adrealine rush! Don't be a douche nozzle, you'll only make your self look worse.
| The Following 2 Users Say Thank You to dem00n For This Useful Post: | chenshuo (04-01-2013), naikaidriver (04-01-2013) |
#19 | |
Drives: WRB BRZ
Start the car: i had this issue twice, but then i realized that if i hold the push button for 1-2 full seconds then release it, then i don't have hard time starting the car. Condensation: i don't have that. Metal clanking noise: completely normal. That happens when the engine is cooling down. Happens on every single car i owned. TPMS: Your BRZ has TPMS? Mine doesn't. Tire: It's gonna be hard to convince the dealer that the tire problem is not your fault. |
#20 |
Drives: WRB BRZ
wow you have the ability to shift a stick! You must be really smart and really cool!
#21 |
Drives: 2013 BRZ SWP 6AT Ltd
The tire warranties are generally for the first useable 2/32" of tread depth or 12 months which ever comes first.
Welcome to a first year car. There are going to be hiccups in any first model year and we are the lucky ones that get to work through them. Lemon Laws usually require a problem to render the vehicle immobile or unuseable after multiple attempts at fixing the same problem. |
#22 |
Drives: White Out FR-S
My rule of thumb: Take 30 seconds every fill up to check the tire pressure. I fill up every two weeks and tires need to be topped off every month and a half to two months.
Check under your hood, anything that is yellow are things you can check yourself and takes at most a minute to check everything. All the clear resevoirs have an indicator so most things can be visually checked. Pull out the dipstick, wipe, replace and pull out to check oil levels after you've stopped the car and let it cool down for 10 minutes. Coolant has a cold and hot indicator i believe, fill it up to what the status of your car is. It's not rocket science really. Do these things to minimize chances of failures. When you have done your due dilligence to reasonably maintain the car, then you have an issue that you can bring up with the dealer and you have a case to argue if you've done everything you could. If you neglect doing things yourself, you are most certainly shit out of luck with any service department. I just find it funny when preventable things could have been done but aren't and suddenly law this and law that start flying everywhere. |
#23 |
Drives: Scion FRS
As far as the tire goes it was run with low pressure. So in the words of Michael Jackson
Just Eat It, Eat It, Eat It, Eat It No One Wants To Be Defeated Showin' How Funky Strong Is Your Fight It Doesn't Matter Who's Wrong Or Right Just Eat It, Eat It Just Eat It, Eat It Just Eat It, Eat It Just Eat It, Eat It
We're not happy till you're not happy 2013 Scion FRS Whiteout 6MT SCCA RTR/Konis/RPF1's/Dunlop Z2's/Strano front bar/CG Lock/Crash camber bolts/JPM shift boot and Instrument panel cover. |
#24 | |
#25 |
Drives: 14' Monogram FRS, ulramarine, white
The lemon law comes into effect if the dealership has to repair or replace the same component 3 times in the first 3 years of the vehicles life... Or first year on the case of a used vehicle... For example... If the starter goes out after 3 months and they replace it and
6 months later it goes out a second time they replace it again... If it happens again in the next 2 years the lemon law comes into effect... Most dealerships are nice about it... Especially Toyota... They will most likely end up giving you a brand new car at that point... I hope this helps clarify to anyone the understanding of the lemon law.
whether it be low and slow, fast and loud, or riding on rails, make it unique and make it your own.
| So my FR-S is officially a lemon... | frsinpa | Scion FR-S / Toyota 86 GT86 General Forum | 90 | 01-19-2013 12:50 PM |
| Lemon law? Not sure what to do anymore. | yayforaddison | Issues | Warranty | Recalls / TSB | 19 | 12-05-2012 12:14 AM |
| Anyone thinking about lemon law? | Accurate Race Shop | Issues | Warranty | Recalls / TSB | 16 | 10-18-2012 10:11 AM |
| Lemon? | grgonium | Scion FR-S / Toyota 86 GT86 General Forum | 13 | 10-08-2012 11:13 AM |
| Lemon FRS in Tampa FL??? | ICEBONEZ | Scion FR-S / Toyota 86 GT86 General Forum | 44 | 08-27-2012 11:56 PM |
