#71 |
The FA20 is a beefy motor. If you're not shooting for more than 350hp and not planning on endurance racing the thing, I wouldn't bother with more than a new OEM short block. This isn't the engine's fault; this is the fault of improper installation.
Current: 2005 Porsche 911 Carrera S 6MT Previous: 2 BRZ's, 997 C2S, C5 RS6, C4 S6, B8 S4, GDB STi, S30 240Z, FC3S RX-7 TII, AW11/SW20 MR2, E30 318is/325i, etc. |
| The Following User Says Thank You to Turbowned For This Useful Post: | TRD_07 (04-01-2013) |
#72 |
Drives: Pile of junk
Tansey i had already asked about that before it even blew up
#73 | |
Drives: .
#74 |
im in florida fullblown is in minnesota. so that was out of the question. looking back i should have went that route. would have spent a bit more money but my car would still be running. im sure they would have hooked me up on install with all the parts i purchased from them
cost of install hotel gas food |
#75 | |
Drives: 2013 raven black fr-s
#76 | |
I Love custom Turbo kits
Drives: Limited BRZ
Yeah, no point in keeping rehashing what could have been...
#77 |
Drives: 2013 FR-S Ultramarine
How are you finding 96 octane in the Bay Area?
@OP-Sorry for your loss. And not to kick you while you're down or anything, but I will say that spinning the tires in first and hitting 6000 rpm in second doesn't seem like "normal driving" to me, especially on a not fully setup or tested brand new turbo setup. I know the pull of boost and the excitement of your new setup is hard to resist, but I think this could have been avoided if you had waited to beat on the thing until you had all your sensors etc. setup and working. Heck, I wouldn't tune a factory turbo car much past stock without a wideband and some way to monitor the boost, much less a full aftermarket setup. Nathan |
#78 |
yes ill admit if i had a wideband and or boost gauge installed it might have been preventable. Still doesnt excuse the fact something was more than likely installed wrong
#79 |
Boostin'
Drives: FRS-T
@Frs300 out of curiosity, did your engine have any weird noise when you started it? my engine has a weird sound in that exact area where your hole is since i installed my turbo kit. at first, i thought it was my turbo that was dry and missing oil, after many checks and stuff its getting its oil but the weird noise is still there. i removed my serpentine belt and checked all my pulleys for a bad bearing and the alternator as well but all is fine. i started the motor again and it still sounds weird. i dont know if you are getting your oil feed from the same location as me and if your turbo uses an oil restrictor but mine doesnt. i am starting to wonder if its not a lack of oil in that area in the motor caused by the turbo oil feed.
i simply turned my car off and i am debating removing my whole turbo kit and going back to stock just to start the motor again so that i can compare the noise with or without the kit.
#80 |
no weird noise that i could hear...just bov opening and closing at idle
#81 |
Boostin'
Drives: FRS-T
maybe im just being paranoid since i built everything myself and its a brand new car...
#82 |
Drives: frs
I agree, i think your fuel pump wasn't properly installed. Hence why you werent getting the right power and putting strain on engine. It was only a matter of time. Next time park it up until you sort it out. Sorry to hear that you blew your engine and look at it in a good way, when you build back up go all out.
#83 |
#84 |
Boostin'
Drives: FRS-T
no heads though.... hope yours are still good! if they are just do it!!
| Swapping the motor. Either 3uz or 2gr | diss7 | Engine Swaps | 34 | 11-16-2015 04:31 PM |
| Motor swaps.. | Brian S | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 2 | 05-19-2012 04:18 PM |
| BMTV (Best Motor TV) HKS vs TRD vs 86 | KyShro | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 13 | 05-09-2012 10:48 AM |
| Will Lotus use the FR-S motor? | muffinman | Other Vehicles & General Automotive Discussions | 26 | 01-20-2012 09:24 PM |
