#57 |
Drives: BRZ Limited, WRB, 6 MT
#58 |
Drives: car
I don't like to usr carnauba waxes anymore, I think they're old technology. I like to use polymer waxes like McGuiar's ultimate wax
#59 | |
Because Racecar
Drives: 2013 Asphalt FRS
I use a carnauba (Adams patriot paste wax) on top of a glaze (adams brilliant glaze) and polymer sealant (Adams machine super sealant). Much better look and more durable with the sealant underneath. |
#60 | |
First 86
Drives: Scion FRS Argento Automatic
Life is short...NO BORING CARS |
#61 | |
Drives: car
With factory clear coats being much softer and less resilient and less easier to detail, I prefer a polymer like Meguiar's Ultimate Wax because they wipe off easier when dried. Compare that to a pure carnauba wax like Meguiar's #16, which was super hard to remove and probably put light scratches in the finish due to having to wipe more aggressively. The reason why the carnauba wax you're talking about looks wetter and deeper is because your wax (probably something like Gold Class or similar) has pure polish oils added to it. This makes it even more of a job to wipe off since you're also chasing polishing oils around. Compared to Gold Class (carnauba), Ultimate Wax (polymer) is half the work required when wiping it off. *edit* sorry just read your whole post and saw you use different products, but pretty similar situation with what I'm talking about. Last edited by radroach; 04-18-2013 at 05:46 PM. |
#62 | |
Because Racecar
#63 |
Drives: ex500r
what do you guys recommend to use with 3m clear bra?
#64 |
Because Racecar
I just use a cheaper liquid wax I'm assuming the clear bra is on the front and since the front bumper takes a eating compared to the test of the car no sense in dropping more expensive than you need onto it.
Adams buttery wax is what I use |
#65 |
Drives: 13 Hot Lava, 01 Miata, 09 Outback
I don't know if this is common with pro detailers, but I know some of the home guys who prefer the look of carnauba wax will actually apply a polymer sealer like blackfire and then 'top' it with a coat of their favorite carnauba.
-Justin
#66 |
Drives: 2013 SWP BRZ
Poorboy's World EX (wax and sealant) if I'm feeling lazy, otherwise Poorboy's World EX-P (sealant only) topped with Poorboy's World Natty Paste Wax (carnuba wax).
I've had good luck with all of their products; their trim restorer is really good for the black plastics, and their Super Swirl Removers work really well on my rotary. However I like to experiment with different products, and am going to try out the Optimum products next. Honestly, pick whatever is on sale on autogeek.net, I've never found a product on their site that isn't decent. A lot of it is personal preference. I chalk this discussion up there with the "what brand oil to use" threads. |
| The Following User Says Thank You to smbstyle For This Useful Post: | russv (04-24-2013) |
#67 |
Drives: car
After the tail of the dragon run I had my GBS BRZ washed, clay, and cleaned / polished using a dual action polisher with meguiar's DA microfiber system polishes.
I use Meguiar's Ultimate Wax. It's a polymer wax, and has good results, and very easy to remove, which is easier on the car's finish. It costs about $20, and the kit includes a foam applicator and high quality microfiber towel. I use a quick detailer spray and that also helps with the final buff using a microfiber towel. Last edited by radroach; 04-25-2013 at 01:34 PM. |
#68 |
Drives: 2013 BRZ SPORT TECH
Swissvax makes amazing carnubas but quite expensive, application and removal is so easy and it smells so nice
| The Following User Says Thank You to 5th 86 For This Useful Post: | tuckdaddy (04-26-2013) |
#69 |
'Senior' Junior Member
Drives: 13 FR-S,08 Mustang Bullitt,06 MX-5
Whew, I guess they are expensive, at least the special formulations. Would love to try the one made especially for my car but I can think of better uses for $3500!
"You'll never know if you don't try" - Shinroko Momose |
#70 | |
Praise Helix!
