#169 | ||
#170 |
Grip>Slip
Very nice. Looked very smooth out there when I was working the course third heat. Whose front bar did you go with? I'm going to be ordering the Strano bar soon, then alignment. Not sure I'm ready to go with full coilovers just yet though.
#171 |
Thanks, I thought all the ft86club folks were in our heat. My front bar is from Hotchkiss.
#172 |
Grip>Slip
Yeah, I ended up registering outside of the ptuning group and was planning on heading out early because i had prior plans last night, those got cancelled at the last minute though, so i was in heat 2 by myself. no worries though, still had a blast, and had a great view of all the 86's on course.
#173 |
Drives: 13 WRB BRZ
anyone have pics of my car? #27 wrb brz..
I was running KW V3 and 33psi front and 32psi on michelin pss and was understeering a lot and front tires were rolling over at the sweeper at the end. I suppose what I need is a stiff front sway bar? |
#174 | |
Grip>Slip
This was on 245/40/17 Continental ExtremeContact DW's. Stock shocks, Eibach ProKit springs. I'll be adding the Strano front bar soon. In theory it should allow me to get on the throttle much sooner than I am currently able to. Hopefully it works out that way in practice. |
| The Following User Says Thank You to xjohnx For This Useful Post: | VoiD (04-23-2013) |
#175 | |
Drives: WRB BRZ
My girlfriend took some pics too. I'm sure at some point she confused your car for mine, so I'll post them if I find any. I was getting a lot of understeer at the sweeper at the end too. 32/30 felt the most stable for me, but I don't have all of the fancy suspension stuff you guys have. Seriously considering it, though. |
| The Following User Says Thank You to warman For This Useful Post: | VoiD (04-23-2013) |
#176 |
Drives: Subaru BRZ
Had a great time - although punctured coolant pipe led to this on my friend's e30
#177 |
Drives: 2013 Whiteout FR-S
No Ductape? that solves everything!
#178 | |
Drives: WRB BRZ
I took a look at the navigation and had it show the route on the screen and that sweeper looked a lot tighter than it seemed on track. I'll post a pic when I get home. |
#179 | |
Grip>Slip
I SoloStorm may have some minor advantages for autox (vs track use), but I'm not sure i can justify $200 for the app itself, $200 more for an android tablet, then another couple hundred for a high speed BT GPS sensor and OBD2 adapter. Especially when I consider that I've got a spare ipad mini and the kiwi iOS OBD2 adapter, the app is only $27 for the top end version of Harry's Lap Timer vs $200 for the only version of SoloStorm. It doesn't hurt that I have 2-3 extra iphones laying around can all be configured to start/stop video recording automatically at the beginning/end of each run for various playback angles. It has this same functionality with 1 GoPro (multiple gopro support coming next version). [ame="http://www.youtube.com/watch?v=bviIV7SnU7k"]Harry's LapTimer Overlay featuring Picture in Picture Reference comparison - YouTube[/ame] |
#180 |
Drives: xA
what was camber?
PTUNING ; Tuned for Competition
#181 | |
Drives: WRB BRZ
Here are a couple pictures of my runs on the stock nav: ![]() ![]() ![]() I have no idea which runs were my best, I did notice my top speed on my first run was only 52 MPH, and then the rest were all 57-58. It's really interesting to see how differently I took some of the corners, but I have no idea how any of that helped or hurt me. So an app like what you mentioned would definitely be huge in figuring out what you did differently and if it actually helped you or not. If you could access that data between runs at an AutoX, and actually make sense of it without overthinking, that could be a huge advantage. |
#182 |
Grip>Slip
| PTUNING: 2013 Scion FR-S R&D Car | Mrc@ptuning | Member's Car Journals | 67 | 04-18-2015 09:42 PM |
| Ptuning Spring Cleaning Meet March 23, 2013 | Events@Ptuning | Mid-Atlantic | 58 | 05-09-2014 01:26 AM |
| Brakes unless at high speed - what to tackle? | empower-auto | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 44 | 10-12-2012 06:06 PM |
| Video: BRZ / FR-S High Speed Run to 124 MPH (200 km/h) | Levi | BRZ Photos, Videos, Wallpapers, Gallery Forum | 43 | 05-16-2012 01:37 AM |
| Casey Stoner high speed cornering at 1000fps | tranzformer | Off-Topic Lounge [WARNING: NO POLITICS] | 6 | 08-01-2011 05:20 PM |
