#2312 |
I Love custom Turbo kits
Drives: Limited BRZ
It is, specially when I crank up the reggeaton songs...
Boooomm, booom boom boooom booooommm...
#2313 |
| The Following 3 Users Say Thank You to sklimo For This Useful Post: |
#2314 |
Done
Drives: WRB BRZ
pitbull.......GTFO
my visual erotica is now on overload.... |
| The Following 2 Users Say Thank You to ftc~brz For This Useful Post: | sklimo (05-15-2014), Sportsguy83 (05-15-2014) |
#2315 |
Done
Drives: WRB BRZ
David, you should be Pitbull for halloween.....that would be epic
| The Following User Says Thank You to ftc~brz For This Useful Post: | sklimo (05-15-2014) |
#2316 |
Drives: Limited BRZ
DALE!!
#2317 |
NASA SpecE30 Racer
Now you need to relocate the battery to the other side of the trunk for dat 50/50 weight split. JUNIOR!!!
- King Tut
Street/Track Car: 2006 Honda S2000 TT3 || Race Car: 1987 BMW 325is SpecE30 || Tow Vehicle: 2014 RAM 1500 EcoDiesel Sold Cars: 2012 BMW M3 || 2013 Subaru BRZ || 2012 Porsche Cayman R || 2009 Chevrolet Z06 || 2009 BMW M3 || 2004 BMW M3 || 2004 Nissan 350Z |
| The Following 3 Users Say Thank You to King Tut For This Useful Post: |
#2318 |
Drives: Limited BRZ
Shiberu should have put dat SW on the passenger side...
#2319 |
Weight Nazi
Drives: 13 FRS -399lb, 11 335is, 05 Tiburon
My balls are broken.
| The Following 2 Users Say Thank You to Anthony For This Useful Post: | sklimo (05-15-2014), Sportsguy83 (05-15-2014) |
#2320 |
Drives: Limited BRZ
#2321 |
Drives: Limited BRZ
Thanks man. Went to the Dyno last night to see if it was true @Rev Works Dyno is as heartbreaker as it seems (20%) lower than Dynojet.
I did not run Map4 as I don't think I'll run it again ever without building. ( 460 WHP +20% =552 WHP Dynojet). However, I did run Map3 17 psi (calculation was 416 WHP +20%= 499 whp Dynojet).... Well Rev Works Dyno IS as heartbreaker as advertised. I made 496 WHP on that map we had calculated 499.... Dat tune doe... so SMOOTH! @jamesm The Wizard hard at work. @KAB-FRS on the hardware See below. ![]() I'll get a better pic later tonight.
#2322 | |
Drives: white subaru brz
#2323 |
Drives: Limited BRZ
I already did..read above
![]() Sent from my SM-N900A using Tapatalk
#2324 |
Drives: Limited BRZ
Had the scare of my life last night car wise... Thought I blew it!! After dyno was giving a ride to shop owner. Everything great on map 1, move to map 2 punch it, out of nowhere oil in the windshield, rear view mirror, only smoke could be seen. Oil pressure gauge... 2 psi.... dash light on... Car DOES NOT turn off by button until low speeds... I was frantically hitting it and nothing happened.
I said it blew and he was like nope, has to be a hose... It was one of the oil cooler hose. Pop it back in, fill it with 4 quarts of motul, drive 3 miles home. Go to walmart at 1 am to get simply green to clean it all, move the car to light, spray it. Get on car to move it to my house to hose it with water.. FUCKING hose blew off again. It was cracked. Spent cleaning till 3 am and still left a bad mess. Got a new smaller filter to allow hose to take different route cut it and push it in and it seems to be holding fine.... What a bad night ending.. I also had to push car by myself and getting it over a steep part of the driveway took a lot of effort. ![]()
| Volk Racing TE37SL - Mag Blue/ Hyper Blue/ Flat Black/ Red/ Gold IN STOCK!!! | Speed Element | Wheels and Tires | 151 | 09-26-2013 05:56 PM |
| Dream Mod For FR-S/BRZ | JPxM0Dz | Other Vehicles & General Automotive Discussions | 22 | 03-08-2013 11:35 PM |
| Have You Had A Dream About Your Car? | chanomatik | Scion FR-S / Toyota 86 GT86 General Forum | 7 | 01-29-2013 03:38 AM |
| Sonic Blue 86, Galaxy Blue deleted? | 450hp/tonne | AUSTRALIA | 14 | 09-01-2012 08:10 PM |
| I had a dream... | ashtray | Off-Topic Lounge [WARNING: NO POLITICS] | 1 | 03-13-2012 12:35 AM |
