Old 05-16-2014, 06:17 PM   #71
mike156
Drives: EVO
FWIW, you should be measuring bumpsteer and adjusting it with the tie-rod height to match your particular setup. To some degree, every alignment setting and the ride height setting affects bumpsteer so it is very car specific on where the spacers need to go on the tie-rods to properly set them up. To do this properly, you need everything to do an alignment, a bumpsteer guage and a lot of free time and knowledge to do it.
mike156 is offline   Reply With Quote
Old 07-19-2014, 03:40 AM   #72
Staf00
Drives: SWP DZE
Where does one purchase a Robispec LCA?
Staf00 is offline   Reply With Quote
Old 07-19-2014, 01:34 PM   #73
dradernh
Drives: Used to Drive:Grand-Am GS #54 E36M3
That's detailed further back in the thread.
dradernh is offline   Reply With Quote
Old 04-04-2015, 10:08 PM   #74
Kosmos
Kosmos
Kosmos's Avatar
Drives: Scion FR-S
Originally Posted by Anthony View Post
So I finally started working on these last night. I used this photo as a guide:
That got me pretty far, but now I'm confused about the tapered bolts. I still haven't called him, as I at least wanted to try first. If I could just figure out how these tapered bolts are supposed to be used and where all these specifically-sized spacers go, I would be in great shape.
Has anyone installed these things? Surely anyone who's installed them will know how the bolts are meant to be used.
Hey how were you able to take the ball joint off the hub? And is the bolt and nut seperate from the bushing? Because mine have rusted through and I was just going to cut em
Kosmos is offline   Reply With Quote
Old 04-05-2015, 10:32 AM   #75
Anthony
Weight Nazi
Anthony's Avatar
Drives: 13 FRS -399lb, 11 335is, 05 Tiburon
I'm not sure what you're talking about. I haven't even bothered with these in months though. I've still go the stock ones on there. But I have taken my hubs off, for other projects. I'm not sure what ball joint you're talking about though. My shit was SUPER rusty too.
Build Thread | The Venus Project | Any car which holds together for a whole race is too heavy.
Anthony is offline   Reply With Quote
Old 04-05-2015, 10:36 AM   #76
wparsons
wparsons's Avatar
I think you mean the knuckle?
Is there a pinch bolt on our front knuckles?
flickr
Search this Thread:
Advanced Search
Adjustable rear upper control arms??? Supermassive Suspension | Chassis | Brakes -- Sponsored by 949 Racing 28 09-29-2013 10:17 AM
Lower Control Arms- offset/angles comparision Huehuecoyotl Suspension | Chassis | Brakes -- Sponsored by 949 Racing 40 03-08-2013 10:20 AM
Delete driver01 Brakes, Suspension, Chassis 11 02-06-2013 02:56 PM
cusco rear lower control arms for FR-S BRZ driver01 Canada Classifieds 3 02-01-2013 06:28 PM
