#43 | |
Sarcastic SOB
I go a step further in that I remove the ECU (behind the glove box) every time I leave the car unattended for a while to counter any attempted theft. Pulling the engine just got way too bulky and time consuming with having to haul a winch setup behind the car everywhere I go. Plus all the questions I used to get while riding up the elevator with the engine on a dolly...
#44 |
Drives: '13 Ultramarine
Another thing to note... The recommendation of 1st or reverse is because they are the lowest gears. If you are on an incline, the car will roll easier in the higher gears than in the lower ones. I don't trust parking brakes alone...I've seen them fail. I use the brake and 1st gear.
#45 | |
Drives: 13 SWP BRZ Prem
Oh and.. "Block the wheels as needed"
JDL UEL Headers, Nameless Res&Cat Over&Front, Invidia Q300 Catback, AVO Dry Panel Filter, Custom ECUTek Tune by DriftOffice 191WHP/151 ft-lb on 92 |
#46 |
Grip>Drift
Drives: FRS
I live mine in reverse. I don't know about the FR-S manual gear box but many have a stright cut reverse gear which is much more robust that your forward drive gears. Plus I figure if your going to let your car rest on a gear might as well be the one you use the lest.
At any rate there's absolutely no reason not to leave your car in some gear.
#47 | |
First 86
Drives: Scion FRS Argento Automatic
Life is short...NO BORING CARS |
#48 |
Red wine
Drives: Subaru BRZ(R.I.P)
If a thief tries to steal your car, leaving it in 1st gear will make a very loud squeaky sound that will wake the neighbors up. If you leave it in neutral, then well...your tires will just keep rolling freely.
#49 |
Drives: 2013 Raven FR-S
In every manual car I've owned (which have been a lot), I leave it in gear when I park. I thought that was standard practice? It's never broke anything in any of my cars.
#50 |
Drives: Toyota Auris
It is standard practice (at least around here, where most cars by far are manual); and, as we can see, there's nothing in the manuals that says not to do it.
People not used with it must be extra careful (when releasing the clutch), but it won't break anything; it just adds safety. |
#51 |
Drives: 2013 White Out Scion FR-S Manual
I checked the manual too. I wonder if the booklet doesn't tell you because they think you should know? I have no idea.
I was always taught to put the car in 1st gear when parking and to think of it like 1st gear is Park. Automatics have Park and an emergency brake. You wouldn't drive your automatic and park without setting the gear into to Park and just using the emergency break. My motto, 1st gear is park for manual drive. What I was surprised about in the booklet is it teaches you how to start off from a steep hill when driving manual. That was something I learned and never knew they would put it in the booklet. |
| The Following User Says Thank You to TKinWhiteOut For This Useful Post: | Bonburner (03-21-2013) |
#52 | |
Drives: Toyota 86 ZN6
#53 | |
Drives: 2013 Ultramarine FR-S
Incidentally, automatics should always use the parking brake, as well, since a brake is far better at keeping a car from moving than the parking pawl in the transmission, not mention easier to repair. |
#54 |
Drives: '13 FR-S Raven 6MT
#55 |
Drives: Nissan Murano
I'm learning to drive stick this summer. So should I always leave it in gear last on hills? Or is there no particular order?
#56 |
Leave it in gear (1st or reverse) when ever you want, but the manual recommends at least on hills. Just be sure to get into a habit of making sure the car is in neutral before releasing the clutch after starting the vehicle.
| Best Parking Job Ever | Mr.Bobbino | Off-Topic Lounge [WARNING: NO POLITICS] | 15 | 01-17-2013 09:30 PM |
| FR-S backed into in parking lot | tvpr | Scion FR-S / Toyota 86 GT86 General Forum | 29 | 01-06-2013 03:20 PM |
| parking in gear | jarviz | Scion FR-S / Toyota 86 GT86 General Forum | 47 | 11-10-2012 01:22 PM |
| New Parking Spot | raul | Scion FR-S / Toyota 86 GT86 General Forum | 7 | 09-05-2012 01:42 AM |
| Hit and Run in parking lot | PoRco | Scion FR-S / Toyota 86 GT86 General Forum | 39 | 08-17-2012 02:44 AM |
