Old 03-18-2013, 03:26 PM   #29
GNS
Drives: .
Originally Posted by Imrac View Post
Leaving the car in first and with the handbrake is way too much stress on the vehicle. I make sure I have 4 sets of chocks with me at all times. I pull the handbrake, get out, place all 8 chocks around the car (Because I don't want to stress just one or two wheels with chocks). Then I release the handbrake so the cable doesn't stretch.
Hah, I do the same too, except I clear the little rocks from the parking space before driving in, don't want to stress the tires by having rocks pressing into the rubber under the car's weight.
GNS is offline   Reply With Quote
Old 03-18-2013, 03:45 PM   #30
lazyluka
Drives: GT86
Get used to leaving it in gear. When you go to the track the last thing you wan't to do after coming back off the track is park your car and pull the handbrake...
lazyluka is offline   Reply With Quote
The Following 3 Users Say Thank You to lazyluka For This Useful Post:
boredom.is.me (03-18-2013), KSC (03-18-2013), SkullWorks (03-18-2013)
Old 03-18-2013, 04:30 PM   #31
spyingwind
Drives: White '17 86
I had a MT truck, 4 banger, that the ebreak only worked very little. To keep it from rolling down the hill I had to put in gear. Most of the time the faulty ebreak and in gear would do, but sometimes the truck would slide down the hill a bit before finally stopping.
The compression of the engine wasn't enough. Some neighbors would freak out that the car started moving after I got inside the house.
spyingwind is offline   Reply With Quote
Old 03-18-2013, 05:24 PM   #32
KSC
KSC's Avatar
Drives: Ion Redline
I can't tell if Imrac and GNS are being sarcastic?!
"Bullshit, asshole! No one likes the tuna here!"
KSC is offline   Reply With Quote
Old 03-18-2013, 05:30 PM   #33
bcj
Geo Tyrebighter Esq
bcj's Avatar
Drives: '13 scion fr-s
Originally Posted by boredom.is.me View Post
The manual also has some pretty stupid conflicting stuff in it. I wouldn't consider the manual useful when it comes to common sense matters.
See here:
http://www.ft86club.com/forums/showt...ht=read+manual
<link>
Do not taunt Happy Fun Ball.
</link>
Caution: Happy Fun Ball may suddenly accelerate to dangerous speeds.
bcj is online now   Reply With Quote
Old 03-18-2013, 05:34 PM   #34
mkiisupra
mkiisupra's Avatar
Drives: 83 Toyota Supra, 16 FR-S RS2.0
17 comments in and nobody mentions that the manual says not to leave the car in gear unless parked on an incline, interesting...
The only issue with leaving in gear on flat surface would be an accident with the FR-S parked in gear, and the ensuing damage to the trans/clutch when moved/pushed/shoved in gear, not running.
Unless I am missing something?? (Perhaps this is the origin of the post to begin with)
Eric G
mkiisupra is offline   Reply With Quote
Old 03-18-2013, 05:39 PM   #35
strat61caster
strat61caster's Avatar
Eric G
Are you implying that if the vehicle was forcibly moved while in gear that components would be damaged?
If so, consider that to damage the transmission the tires would have to retain traction while being moved (causing the driveshaft to rotate against it's will) and the engine would have to resist turning over (because if it did, the force is relieved and no harm done, engines are meant to turn over), if that happens (tires roll, not slide, and the engine refuses to turn over) then yes there may be damage to the transmission/clutch.
I'm pretty sure the tires would slide before any significant damage would occur due to the vehicle being in gear.
ineedyourdiddly
Old 03-18-2013, 05:55 PM   #36
bdanisi
You Made Bro?
bdanisi's Avatar
Drives: Raven 86
This is a lot of food for thought and thanks to everyone who dropped some knowledge on me. I live in a very flat area and I basically never have to park on inclines. The car is new and I'm going to continue parking in neutral. If the handbrake fails then a ill be shocked and angry and b I'll take action against Toyota buy highly doubt that will happen. From now on tho if I park on an incline I will leave it in gear. And for those who asked my last vehicle was at and I Always parked in neutral with the parking brake then turned the car off and would put it in park. Never had any issues with anything 150k miles deep. I think a sub 3k weight brand new car will be fine in neutral lol.
bdanisi is offline   Reply With Quote
Old 03-18-2013, 05:56 PM   #37
mkiisupra
mkiisupra's Avatar
Agreed, this would be so slight, more damage to linkage or bushings, perhaps.
Then what would be the purpose of leaving out of gear on flat surfaces, as suggested by the manual? That was the only reason I could think of.
btw, have had damage to trannies when parked and hit, manual and auto. One major, others minor, as you describe.
Eric G
Old 03-18-2013, 06:15 PM   #38
wbradley
Sarcastic SOB
wbradley's Avatar
And here I thought first gear WAS the parking brake and that the parking brake was the drift initiator.
Old 03-18-2013, 06:23 PM   #39
spyingwind
I like your train of thought!
Old 03-18-2013, 06:26 PM   #40
Khyron686
Drives: 2011 Outlander XLS, 2013 FR-S Blue
Problem is, what you think is perfectly flat often is not.
[ame="http://www.youtube.com/watch?v=1U-gVZyvIsw"]Car rolls away from gas station - YouTube[/ame]
[ame="http://www.youtube.com/watch?v=hBEXtJIEjrw"]Police - Parking Brake - YouTube[/ame]
Khyron686 is offline   Reply With Quote
Old 03-18-2013, 06:40 PM   #41
Black Tire
Black Tire's Avatar
Drives: Whiteout Scion FR-S
Originally Posted by Killerbee View Post
sorry, but you had me laughting there for a minute.
Park the car (foot on the brake and clutch, 1st gear or reverse, whatever) , pull the e-brake, stop engine, take the foot of the brake and clutch. Since the car is already secured with the e-brake, why should that now put added stress on the transmission? It would only if your car begins to roll because your e-brake does not work, and I'd rather take that chance than my car rolling into god knows what because I did not secure it properly.
My guess is you're new to manual transmission, so yes, cars can handle 1st/reverse gear parking since... ever.
^^ This, or close to it. Stop the car in the parking spot, foot on clutch and brake. Pull the parking brake. Ease off the foot brake to make sure the parking brake is holding the car. Put it in 1st or reverse if it isn't already. Shut off the ignition. Let your foot off the clutch pedal. No stress at all on the transmission since you made sure that the parking brake was actually holding the weight of the car. Transmission and engine compression is a backup in case the parking brake breaks. On a hill also turn your steering wheel into the curb for downhill parking and away from the curb for uphill parking for an additional backup.
Personally, on a flat surface, I put my car up on jack stands so it doesn't roll away. I also remove the wheels and tires and put them in the car so they won't get stolen. On a hill, I take out my 3-foot steel stake, pound it through the asphalt with my sledge hammer, and attach it with a chain to a tow hook so the car does't roll downhill just in case everything else breaks.
Old 03-18-2013, 07:05 PM   #42
nataku
Negative Mass
nataku's Avatar
Drives: Orange Metallic AVO Turbo GT86 6MT
Don't leave it in gear while illegally backed-into a space.
nataku is offline   Reply With Quote
Search this Thread:
Advanced Search
Best Parking Job Ever Mr.Bobbino Off-Topic Lounge [WARNING: NO POLITICS] 15 01-17-2013 09:30 PM
FR-S backed into in parking lot tvpr Scion FR-S / Toyota 86 GT86 General Forum 29 01-06-2013 03:20 PM
parking in gear jarviz Scion FR-S / Toyota 86 GT86 General Forum 47 11-10-2012 01:22 PM
New Parking Spot raul Scion FR-S / Toyota 86 GT86 General Forum 7 09-05-2012 01:42 AM
Hit and Run in parking lot PoRco Scion FR-S / Toyota 86 GT86 General Forum 39 08-17-2012 02:44 AM
