Southern California SoCal
Old 05-10-2013, 09:25 PM   #85
JDKane527
JDKane527's Avatar
Drives: Asphalt Scion FR-S
Got all 8 kits to fit in my car. They put all clips and hardware together. Anyone know how many should be with each kit?
Thanks to @shiumai, there should be 16 small clips, 4 larger clips, 6 screws, and 4 nuts. Already met with a few guys, let's arrange this weekend to meet up. Shoot me a PM or text.
JDKane527 is offline   Reply With Quote
The Following 3 Users Say Thank You to JDKane527 For This Useful Post:
HotLeopardMama (05-10-2013), shiumai (05-11-2013), solidONE (05-11-2013)
Old 05-11-2013, 02:49 AM   #86
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
Originally Posted by JDKane527 View Post
I'm available to meet up Saturday around Pasadena.
I will be sending out updated totals, so check your PMs guys!
I'm down. Let me know when you will be available. Plus I really want to check out your car too.
Old 05-11-2013, 05:23 AM   #87
JDKane527
JDKane527's Avatar
Just finished install, took about 2 hours taking my time from start to finish.
Hardest part was getting the 8 outer plugs off the car. Once those were off it was quick to install all 4 underpanels.
This is probably common sense, but make sure the front under panel overlaps the long side panels you install. It was mentioned in the other thread, and is the only way to get them to really fit properly since they are shaped to fit one way. You'll end up with extra hardware if you reuse the original hardware on your car.
Easy mod that will help protect the undercarriage.
I'll be in Old Town Pasadena in the morning for breakfast/brunch and then be around South Bay later on in the day. You guys have my number I believe, so shoot me a text when you're available to meet up, trying to get all of these to their respective owners asap.
Old 05-11-2013, 07:26 AM   #88
B L U E S L A T E
Drives: BMW E84
I can meet in South Bay. Will you be around Torrance or Gardena?
B L U E S L A T E is offline   Reply With Quote
Old 05-11-2013, 10:43 AM   #89
Pekingduck
Drives: 4 wheels
Got my under panel, great experience and nice meeting you Jeff
Pekingduck is offline   Reply With Quote
Old 05-11-2013, 02:15 PM   #90
JDKane527
JDKane527's Avatar
Likewise sir!
It's on the way to where I'm going so we can meet up. Afternoon good for you?
Old 05-11-2013, 04:19 PM   #91
shiumai
shiumai's Avatar
Drives: 2013 DGM BRZ, 2020 C8 Corvette
got my panels installed this morning - also took a couple of hours at leisurely pace. thanks JDKane for putting this together!
as mentioned previously, it's all very straightforward. the eight side clips were of course the most time consuming. i had a panel clip removal tool, but the notch was too wide and it wouldn't pull the clips off. once i got a clip sticking out a bit, i then grabbed it with a mini vise grip, then just twisted and pulled till they came out. took about 5 mins to do each one once i figured out the technique. it also helped to use a tiny screwdriver to release one of the 'ears' on the clip, otherwise i'd be fighting both.
everything fits up perfectly - no issues with mismatched holes etc.
shiumai is offline   Reply With Quote
Old 05-12-2013, 01:48 AM   #92
JDKane527
JDKane527's Avatar
Everyone has received their under panels. It was cool meeting you guys, hope to run into each other at meets and events in the future.
Cheers :happy0180:
The Following 2 Users Say Thank You to JDKane527 For This Useful Post:
B L U E S L A T E (05-14-2013), solidONE (05-14-2013)
Old 05-14-2013, 03:57 AM   #93
solidONE
solidONE's Avatar
Thanks for running around to make sure everyone got their stuff, man! Cheers!
The Following 2 Users Say Thank You to solidONE For This Useful Post:
B L U E S L A T E (05-14-2013), JDKane527 (05-17-2013)
Old 05-15-2013, 07:25 PM   #94
Pekingduck
Drives: 4 wheels
Thanks JDKane
The Following User Says Thank You to Pekingduck For This Useful Post:
Old 06-20-2013, 02:16 AM   #95
solidONE
solidONE's Avatar
So I finally got around to installing the panels today. How the hell do you get those painted over plastic clips on the sides? Will using a trim remover tool make it any easier?
Old 06-20-2013, 02:36 AM   #96
JDKane527
JDKane527's Avatar
Use a knife to seperate the clip from the sealant sprayed on the underside of the car. I found using a small flathead to push the feet holding it in helps to slide out one side of the clip and pull it out that way.
You can follow this DIY:
http://www.ft86club.com/forums/showthread.php?t=38946
Old 06-20-2013, 07:30 PM   #97
solidONE
solidONE's Avatar
This is what I did and it was still a bitch to remove.. that's why I was hoping a panel remover tool or another specialty tool will just magically make it a easy process. lol I guess there is no way around it.
Thanks again. BTW Buttonwillow with Speedtrial this weekend, yo. Going sunday.
Old 06-23-2013, 06:22 AM   #98
solidONE
solidONE's Avatar
So I went ahead and picked up a trim remover tool from autozone. Along with a small flat tipped screwdriver to help the tool to slide under the clips, I was able to remove them very cleanly and very quickly. Might even be able to reuse the clips if you bend back the slightly mangled retaining prongs. Well worth the $6 spent.
http://www.autozone.com/autozone/acc...questid=357918
The Following User Says Thank You to solidONE For This Useful Post:
JDKane527 (06-23-2013)
Injen Short Ram Intake Groupbuy! genometuning Groupbuys 192 12-06-2013 04:49 PM
GoPro Hero3: Black Edition -- Groupbuy 86_ZN6 Audio/Visual, Electronics, Infotainment, NAV 7 02-18-2013 02:04 AM
PDX Groupbuy from ReflectiveAuto Detailing m.box.design Northwest 12 02-11-2013 01:49 AM
J2 Motorsports- GROUPBUY-Blox shiftknobs J2 Motorsports Groupbuys 0 11-08-2012 02:46 PM
Groupbuy Toyota 86 VIC tlp AUSTRALIA 17 04-27-2012 11:16 AM
